An existing thread where I'm asking for help with heating systems, I've described how I'm struggling to get my new USB Z-Wave adaptor to work on my Domoticz system.
http://www.domoticz.com/forum/viewtopic ... 455#p69754
Can anyone give advice on what I need to do to fix the problem and get it working again please
New to Z-Wave - can't get USB to initialise in Domoticz
IDANIT
Re: New to Z-Wave - can't get USB to initialise in Domoticz
your port is ACM0 instead USB...
Scones
I tried changing it to USB but had no success so I changed it back to ACM0.IDANIT wrote:your port is ACM0 instead USB...
The key to the solution was patience. Z-Wave seems to be VERY slow in doing things, but with patience everything gets there in the end
- nayr
- Domoticz version: github
its is slow to start.. especially as your network grows.. thats because its querying all non-sleeping nodes at start... one at a time and waiting for a response.. look in the logs for All Nodes Queried, Z-Wave Ready or something like that before you start sending it more commands.
once its up and going its pretty quick as long as you have it setup correctly.
- Westcott
As Nayr says, it's "OpenZWave: Awake Nodes queried" hopefully within a minute.
Up to a day later you'll get "OpenZWave: All Nodes queried"
- nayr
yep thats the log... my network takes alot longer than a minute now with dozens of devices.. really a pain trying to fix z-wave bugs, spend alot of time waiting on the network to come back before you can actually test anything.. much longer than it takes to rebuild domoticz. I may have to get me another stick and setup a 1 device test network.
