Also noticed this, and wated to report it, but you were fasterMarcelMAH wrote:I just updated (premium non beta) and the first big bug I found is the setpoint for temperature does not work correctly. When I click set the number shown is 0.5 lower than it really is and when pressing - it goes up by 0.5 until I press +, when I press + it goes down by 0.5 for the first time. When iI press OK the final number is 0.5 higher then what I set it to.
- LouiS22
Re: Domoticz app 2.0
frotsen
setpoint for temperature was better the way it was (with + and -), new is fancy but it involves one more tab to set temp
bvduijv
But it was difficult to go quickly 5 degree up? Or set it to 'off' (minimal temp).frotsen wrote:setpoint for temperature was better the way it was (with + and -), new is fancy but it involves one more tab to set temp
It would be nice to set min and max Temps. Now it is from 0 to 100, which is weird.
And maybe it would be nice to be able to type the desired temperature.
- RickDB
Thanks for adding EvoHome supports!
Only a few small issues with it so far:
- Can set global temperature mode however the green "SET" icon is misaligned in potrait mode as it overlaps the text label (name) and adds a an empty white space below (like it expects more info in a new row)
- Missing per zone temperature control, can see the temps of every EvoHome thermostate (zone) however no option to control it yet.
Tested on Xperia Z5 (1920x1080).
- RoadXY
- Domoticz version: 2.2331
Could you please provide screen shots?RickDB wrote:Thanks for adding EvoHome supports!
- RoadXY
Great suggestions.bvduijv wrote:But it was difficult to go quickly 5 degree up? Or set it to 'off' (minimal temp).frotsen wrote:setpoint for temperature was better the way it was (with + and -), new is fancy but it involves one more tab to set temp
- RoadXY
Also noticed this.LouiS22 wrote:Also noticed this, and wated to report it, but you were fasterMarcelMAH wrote:I just updated (premium non beta) and the first big bug I found is the setpoint for temperature does not work correctly. When I click set the number shown is 0.5 lower than it really is and when pressing - it goes up by 0.5 until I press +, when I press + it goes down by 0.5 for the first time. When iI press OK the final number is 0.5 higher then what I set it to.
Will look into it.
- RoadXY
We receive all crashes and have been fixing them right away.ceedebee wrote:Updated the app by goole play and now it chrashes at start up.
Could you provide details like app version, if your on premium or free and if you opted in to the beta testing.
- RoadXY
Scenes in Domoticz are also one button.maluko wrote:dont know if it is on list of implement but i think that the scenes will be better with on/off buttons because:
- i have 6 blind with a scene "open morning" that open only 3 blind at morning, but if i want to close all blind with android app i have to close one by one or open the group with all and close.
- supose that you want open the blind to the midle with group, with my x10 module or DIO we have to click on and wait x seconds until blind arrive to midle and next click ON again to stop, so have to click 2x ON that with app we cant.
good work
You'll have to edit the scene and change to group then.
Jango
Don't know if it's already on the todo list.
Can you please change the graphs like they are in domoticz. In the left row a scale for temp, in the right the humidity.
Now it is very hard to read.
pepeEL
Good suggestionJango wrote:Don't know if it's already on the todo list.
maluko
this is quite equal that i said about group button.Chakkie wrote:This app is amazing.
I was wondering if you can give us the option to choose between slide and seperated button for Group type Scenes.
One of my group type is several lights on and off. When some of the lights are already on and I wanted to activate the group to turn off the lights in the group. I have to slide the button to ON and then OFF. I would prefer to have the group type scene to have seperated ON and OFF button.
Thanks and keep up the good work
group dont seem to be the solution, because domoticz has 2 button (on and Off), and on app it has a slide button so you cant push off or on twice.
ztocken
I just updated the android app and noticed its now in swedish, is there any way for me to change it back to english?
Or is this controlled by the language defined on my phone?
pepeEL
Maybe in future developeer add option change language. Now language is set as in phone.
Dev please add this feature to list to do...
- RoadXY
Already did thatpepeEL wrote:Maybe in future developeer add option change language. Now language is set as in phone.
- RoadXY
Help me understand. Why do you need to push on twice?maluko wrote:this is quite equal that i said about group button.Chakkie wrote:This app is amazing.
pepeEL
ThanksRoadXY wrote:Already did thatpepeEL wrote:Maybe in future developeer add option change language. Now language is set as in phone.
Wysłane z mojego SM-G920F przy użyciu Tapatalka
bvduijv
In case of a mixed status?RoadXY wrote:Help me understand. Why do you need to push on twice?maluko wrote:this is quite equal that i said about group button.Chakkie wrote:This app is amazing.
- RickDB
Sorry about that, here you goRoadXY wrote:Could you please provide screen shots?RickDB wrote:Thanks for adding EvoHome supports!
For the temperature zones it displays the data like before with no option to set temperature (believe EvoHome control is slightly different) however the mode control there ("Honeywell - huis modus") works perfectly fine now except for the label alignment.
maluko
yes, like i said:bvduijv wrote:In case of a mixed status?RoadXY wrote:Help me understand. Why do you need to push on twice?maluko wrote:
i have a scene with :
blind A- close
Blind B- open
Blind C- Close
Blinde D- Open
if they are all close only open B/D but if all open, the A/C goes closed, then if i want close/open all when are mixed?
i had a group with all blind that in domoticz i can click on or off when they are mixed, that not happen on app because if the status of group on app are off and the blind are mixed how can i close? have to open group and then close? or close every blind individual?
other think is:
my blind system not have stop button, so if blinds are close and want to all stay at middle i have to click ON (group) to open,wait 10s and that click On again to stop at middle. this happen with close too, OFF to close and OFF again to stop.
thanks
