Grid Voltage meter
ciottomate
Grid Voltage meter
Post by ciottomate »
i'm really stuck looking for somenthing to measure (and import) voltage grid data 220V in domoticz using raspberry.
I had look on some wall socket energy meter like Revolt NC5461, that works with RFXcom 433Mhz but i'm not sure if voltage data is also sent. Can anyone advice ?
Thanks in advance
GP
Domosapiens
Domoticz version: V3.5981
Re: Grid Voltage meter
Post by Domosapiens »
The Z-Wave Philio Technology Corporation PAN04-1 Double Relay Switch 2x1.5kW with Power Measurement reports also Voltage in Domoticz
See also: http://www.domoticz.com/forum/viewtopic.php?f=50&t=9371
ciottomate
Domosapiens wrote:The Z-Wave Philio Technology Corporation PAN04-1 Double Relay Switch 2x1.5kW with Power Measurement reports also Voltage in Domoticz
Domosapiens, your help is much appreciated ! I'll have a look for this device in Italy (maybe Amazon ... i hope) :)
I'll let you know.
Cheers
EDIT:
I'm not sure about frequency; is this device 433Mhz?
Domosapiens
No it is not,
It's Z-Wave at 868.42 MHz
ciottomate
Nope,
I'll continue to search a way to easily import voltage data to raspberry. Thanks for your contribution.
Any suggestions is more than welcome!.
CHEERS
