In order to create this app i'm using html, javascript/jQuery-mobile,css. The issue is that it works in the navigator on the computer but not in the application. I'm using this url to update the value : /json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=TEMP. Here is the javascript :
var newTemp = eval(Number($('#1 p').text()) + operator + 0.5);
var jurl = $.domoticzurl + "/json.htm?type=command¶m=udevice&idx=4&nvalue=0&svalue=" + newTemp;
$.getJSON(jurl,
format: "json"
function (data) {
alert("test");
if (data.status = "OK") {
showData();
