I found an error in setting the temperature. New version 1.1.1 availablepepijn wrote:NEW VERSION v1.1.0 of the Node is available
sudo npm -g update node-red-contrib-nefit-easy
- Changed: the communication, only a single connection will be made and reused by all nodes.
- Implemented: Timeout setting to the Easy configuration node
- Changed: Flow-temperature output
- Some bugfixes
Nefit Easy™
Re: Nefit Easy™ Client/Node for Node-RED
- Domoticz version: 4.10982
Re: Nefit Easy™ client library (How to install on the Pi)
would be good to know the way forward. Same here. Have the client version installed, but not the new cli. Should I uninstall the old one and install the cli and then the node-red 1.1.0 version of your node-red flows/scripts?Holland wrote:Pepijn,
How would you advice me to update Robert's library? Now I only have the following, which is incomplete and outdated
pi@raspberrypi ~ $ sudo npm -g list | grep nefit
├─┬ [email protected]
│ └─┬ [email protected]
│ ├─┬ [email protected]
Should I first remove the old nefit-easy-client install, and then separately install in separate directories, the core, commands and cli libraries?
Thanks for you advice
The node has its own dependencies so they are not used for the cli. If you want to use the cli (I can't imagine why) you should install it separately.
ok. Just to be clear. I will just uninstall the client (old 1st version) and delete the current node-red flow. Afterwards install your version of the node-red scripting. Enter parameters and done.
What do mean with node-red scripting? You don't need the old scripts (/opt/nefit) anymore.dorenberg wrote:ok. Just to be clear. I will just uninstall the client (old 1st version) and delete the current node-red flow. Afterwards install your version of the node-red scripting. Enter parameters and done.
I will delete those too. I meant the node-red-contrib-nefit-easy github package.
You should use npm instead of github. Just to be clear its not a script but a node, a native addition to Node-REDdorenberg wrote:I will delete those too. I meant the node-red-contrib-nefit-easy github package.
/newbie/
Hello, i started today with domoticz, and found the nefit part...
Now i am trying to install the nefit stuff, but am facing a problem:
After i install the node-v5.3 (or 5.4) i receive this:
pi@raspberrypi ~ $ node -v
Segmentation fault
pi@raspberrypi ~ $
My image is the domoticz-raspberrypi-sdcard-3530...
Segmentation fault
pi@raspberrypi ~ $
- kraades
- Domoticz version: Stable
Did you install the correct node binaries? Pi1 or Pi2? ARMv6 or ARMv7?
Just to be complete, the node is (automatically) published on nodered.org http://flows.nodered.org/node/node-red- ... nefit-easy
as far i know i have a Pi2,but will look closer when i am at home.kraades wrote:Did you install the correct node binaries? Pi1 or Pi2? ARMv6 or ARMv7?
I followed these steps:
1 sudo ps -ef | grep node
2 sudo /etc/init.d/nodered stop
3 node -v
(VERSIE 0.10.4 OID ZOU ER MOETEN STAAN)
4 wget https://nodejs.org/dist/v5.3.0/node-v5. ... v7l.tar.gz
5 tar -xvf node-v5.3.0-linux-armv7l.tar.gz
6 cd node-v5.3.0-linux-armv7l
7 sudo cp -R * /usr/local/
8 node -v
(VERSIE 5.3.0 ZOU ER MOETEN STAAN)
I am able to copy the files to /usr/local/ But the command node -v gives a segmentation fault.
edit:
Found it: I thought i had a Pi2, but i have a Pi1 B+
the command node -v gives the right output
I managed to get it running:
pi@raspberrypi ~/node_modules/nefit-easy-commands/example $ node status.js
Temperature is set to 17.0°C, current is 18.3°C.
Outside temperature is 6.0°C.
System pressure is 1.4 bar.
But how do i get this data in Domoticz/Dashboard?
I promised to give some results:
From the outside everything looks fine and is working like it should which is great. When taking a look at the log I found a few errors; really a few: 12 to be exact in over 30 hours runtime. I found: INVALID_RESPONSE: 8x; REQUEST_TIMEOUT: 3x and 1 other error with the log text '[error] [nefit-easy:f5e93b14.0a16c8] Error: error:0606508A:digital envelope routines:EVP_DecryptFinal_ex:data not multiple of block length' where [nefit-easy:f5e93b14.0a16c8] is 'nefit-update'.
From another thread I learned that the timeout is harmless, for the other errors I don't know. But it doesn't seem to bother much since everything functions like it should. So thanks again for a great job.
Mark
PS. I made a little lua script that updates the setpoint widget once per hour with the same value to prevent that the widget turns red. It would be a nice feature if that could be built into the node. So pass the setpoint on change but at least once per hour. If its possible...
Mark
Mark: Domoticz Beta on Raspberry Pi 4 running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - MySensors - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (plugin) - Zwave-js-ui - dzVents - Nodered
What is the version of the node you are using?Doler wrote:Hi,
Mark
Most of the problems mentioned above should already be solved
The latest, 1.1.1
Mark
Mark
- Domoticz version: 3.5877
I made a little script in php to get these data in domoticz.jakkes72 wrote:I managed to get it running:
If you can handle that I can send you the script.
Otherwise you can use node-red:
https://domoticz.com/forum/viewtopic.php?f=4&t=9653
- Domoticz version: Beta Ch
hi kc27,
Maybe you can post the script on the forum
This is the php-script, I use for importing nefit-easy values:
This only works when:
When you save the script in /var/www/update.php you can test it in your browser with http://raspberrypi/update.php, or with the commandline:
I made a cronjob for it which runs every 5 minutes:
When there are problems you see it in /home/pi/update/update_out.txt
<?php
$jsondata = shell_exec("easy -V --serial=xxxxxx --access-key=xxxxxx --password=xxxxx status");
$data= json_decode($jsondata);
var_dump($data);
$data_array= get_object_vars($data);
if (array_key_exists('in house temp', $data_array)){
$temp_current = $data_array['in house temp'];
echo 'current temp '. $temp_current."\n";
$result = file_get_contents('http://raspberrypi:8080/json.htm?type=command¶m=udevice&idx=1&nvalue=0&svalue='.$temp_current);
echo $result."\n";
if (array_key_exists('temp setpoint', $data_array)){
$temp_setpoint = $data_array['temp setpoint'];
echo 'setpoint temp '. $temp_setpoint."\n";
$result = file_get_contents('http://raspberrypi:8080/json.htm?type=command¶m=udevice&idx=2&nvalue=0&svalue='.$temp_setpoint);
echo $result."\n";
- node.js v4 or higer is installed
- nefit_easy_client (commandline) from Robert Klep is installed
- php5 is installed
- I have in Domoticz created
- a dummy thermostaat (Settings/Hardware)
- in that thermostat I created two virtual sensors with idx=1 en idx=2 for room temp and setpoint temp
- When you run this script on your raspberry and you have access to the website secured with username/password then you have to enhance your whitelist with your machinename (for instance raspberrypi) (viewtopic.php?f=6&t=9890)
object(stdClass)#1 (22) {
["user mode"]=> string(5) "clock"
["clock program"]=> string(4) "auto"
["in house status"]=> string(2) "ok"
["in house temp"]=> float(19.5)
["boiler indicator"]=> string(3) "off"
["control"]=> string(4) "room"
["temp override duration"]=> int(0)
["current switchpoint"]=> int(15)
["ps active"]=> bool(false)
["fp active"]=> bool(false)
["temp override"]=> bool(false)
["holiday mode"]=> bool(false)
["boiler block"]=> NULL
["boiler lock"]=> NULL
["boiler maintainance"]=> NULL
["temp setpoint"]=> int(19)
["temp override temp setpoint"]=> float(18.5)
["temp manual setpoint"]=> int(20)
["hed enabled"]=> NULL
["hed device at home"]=> NULL
["outdoor temp"]=> int(6)
["outdoor source type"]=> string(7) "virtual"
current temp 19.5
"status" : "OK",
"title" : "Update Device"
setpoint temp 19
"status" : "OK",
php /var/www/update.php
*/5 * * * * sudo php /var/www/update.php >/home/pi/update/update_out.txt 2>&1
Thanks, looks good. Will give it a try when I have a moment
Pepijn,
Kind request. Can you maybe post a new version of your flow, which includes the single connection feature. Just want to see how to get this running properly. Thanks
