Selectors are implemented in one of the next releasesthomasb89 wrote:Just wondering if your planning to add functionallity for the 'selector' SwitchType.
- galadril
- Domoticz version: latest
Re: Domoticz app 2.0
marcpos
Hi,RoadXY wrote:Do you experience the same issues as stated above?Jan- wrote:I have the same experience it is not always working correctly.
I'm using your premium version from the start. Great app!!
On my phone geofence stopped working too, since last update after reboot of the phone. I hope you can find the solution for this.
Thanks for your work on this great app!
Marc
- galadril
This matter wil be solved by the next versionOn my phone geofence stopped working too, since last update after reboot of
the phone.
alfred_j_kwak
- Domoticz version: 2.3530
I can't see temperature trend from last couple days. Could -25 degrees Celsius cause problems?
pepeEL
I also has this problem that for some sensor temp , graph is not show. On web domoticz all works ok and graph is show ok.
- RoadXY
- Domoticz version: 2.2331
There are several fixes in alpha and beta right now which could solve this issue.alfred_j_kwak wrote:I can't see temperature trend from last couple days. Could -25 degrees Celsius cause problems?
Please test when you receive this update later or apply for the beta testing *klik here*
(only for Premium users!)
pepeEL
I am beta tester and have latest app. And problem still have. My version is 0.1.210
Next bug is that in Switches is not show Virtual Switches type SELECTOR.
Next bug:
When i delete from menu Welcome Wizard it is hide in menu. But when i close app and close from task manager and open again, after open app in menu again is show Welcome Wizard. Also when i disable in settings again come back.
Next bug:
- galadril
Have you read my post??pepeEL wrote: Next bug is that in Switches is not show Virtual Switches type SELECTOR.
galadril wrote: Selectors are implemented in one of the next releases
maluko
hi guys
This is not a bug but can be a improvement so:
When we open any tab like switch which have a lot devices and if you want turn off and next turn on( like reboot) the screen goes alway to the begining, next have to scroll or "find".
this happen too when i want to open or close the blinds (not all because have a scene), i have ordered all next to each other.
- RoadXY
Made an issue, thanks!maluko wrote:hi guys
- Alle
I really love to monitor my gas and electric statistics , but they are hard to read in the app with the current chart lines..
Is there a possibility to replace them with bars or have a choice to use lines or bars in the future?
ESXi/Ubuntu - Z-wave.me USB Stick - Domoticz Beta - EvoHome - Nest Protect - Logitech Media Server - Netatmo Weather Station - Everspring - Aeonlabs
- RoadXY
We're thinking on a way how to improve the graphs.
Bars is one of the options.
darkrain
Became a beta tester yesterday.
I want to use the geofencing option to determine if I'm home or not, but at the moment the geofencing seems unreliable.
After the update to the beta version yesterday I left the house, but the switch never switched off.
After I switched the switch myself and when I came back it did work.
I will do some more testing today.
I hope this functionality will improve in future releases.
- RoadXY
We already pushed an update which should make Geofence more reliable by starting Geofence on boot of the phone and on start of the app.
It's still not clear when the issues arise.
darkrain
Just now it worked fine, leaving the house switched the switch off and when I came back the switch turned on.RoadXY wrote:We already pushed an update which should make Geofence more reliable by starting Geofence on boot of the phone and on start of the app.
Just as you would expect.
Let's see what happens the next few days..
- RoadXY
It could be possible that, after this update, the fences has to be registered again to work finedarkrain wrote: Just now it worked fine, leaving the house switched the switch off and when I came back the switch turned on.
darkrain
Just to let you know, I did that yesterday right after the update.RoadXY wrote:It could be possible that, after this update, the fences has to be registered again to work finedarkrain wrote: Just now it worked fine, leaving the house switched the switch off and when I came back the switch turned on.
- RoadXY
Ok, thanks for the heads up!darkrain wrote:Just to let you know, I did that yesterday right after the update.
tomson
- Domoticz version: Latest
Under the server connection settings, my local SSIDs are always empty. Is this maybe a bug?
Sent from my Nexus 5 using Tapatalk
