I have done this now. Now I don't have an error with the CP command but when I do node-v I get: segmentation fault.you have to stop node-red first before you can issue that command.
sudo ps -ef | grep node
sudo /etc/init.d/nodered stop
node -v
(VERSIE 0.10.4 OID ZOU ER MOETEN STAAN)
wget https://nodejs.org/dist/v5.3.0/node-v5. ... v7l.tar.gz
tar -xvf node-v5.3.0-linux-armv7l.tar.gz
cd node-v5.3.0-linux-armv7l
sudo cp -R * /usr/local/
node -v
(VERSIE 5.3.0 ZOU ER MOETEN STAAN)
Nefit Easy™
Re: Nefit Easy™ client library (How to install on the Pi)
I published the node on NPMjs so for installation use:
sudo npm install -g node-red-contrib-nefit-easy
Doler wrote:I have the same problem, 7 minutes after a restart of red-noderostyk wrote:@pepijn
i got once per hour a error with crash of node-red:looks like connection are closed (dropped by nefit easy) after a 40-50 minutes.Code: Select all
Error: read ECONNRESET at exports._errnoException (util.js:870:11) at TLSWrap.onread (net.js:544:26)
i will report after clean reinstall (probably caused by mine changes in a code)MarkCode: Select all
6 Jan 17:26:26 - [red] Uncaught Exception: 6 Jan 17:26:26 - Error: read ECONNRESET at exports._errnoException (util.js:855:11) at TLSWrap.onread (net.js:544:26)
Should be fixed in the new version:
Upgrade:
sudo npm un -g node-red-contrib-nefit-easy
sudo npm i -g node-red-contrib-nefit-easy
sudo service nodered restart
Thanks for the solution but you have to help me once more before I can test. Before I saw your message I decided to do a new install on a saved image since I felt a little uncertain on all try-and-error of last few days.pepijn wrote: Should be fixed in the new version:
Upgrade:Code: Select all
sudo npm u -g node-red-contrib-nefit-easy sudo npm i -g node-red-contrib-nefit-easy sudo service nodered restart
So I started with updating nodejs:
sudo service nodered stop
node -v
wget https://nodejs.org/dist/v5.3.0/node-v5.3.0-linux-armv7l.tar.gz
node -v
sudo service nodered start
sudo npm cache clean
sudo npm install -g --unsafe-perm node-red
sudo npm i nefit-easy-client -g
What did I forget? How can I check what is missing?
Thanks, Mark
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
Try to remove and reinstall node-red-contrib-nefit-easy. There was an issue with earlier versions.Doler wrote:Thanks for the solution but you have to help me once more before I can test. Before I saw your message I decided to do a new install on a saved image since I felt a little uncertain on all try-and-error of last few days.pepijn wrote: Should be fixed in the new version:
So I started with updating nodejs:Then updated node-RED:Code: Select all
sudo ps -ef | grep node sudo service nodered stop node -v wget https://nodejs.org/dist/v5.3.0/node-v5.3.0-linux-armv7l.tar.gz tar -xvf node-v5.3.0-linux-armv7l.tar.gz cd node-v5.3.0-linux-armv7l sudo cp -R * /usr/local/ node -v sudo service nodered start
Installed nefit-easy-client:Code: Select all
sudo npm cache clean sudo npm install -g --unsafe-perm node-red
Then installed nefit-easy node:Code: Select all
Imported your example script and added necessary nefit easy and device data. After deploying the script the only debug messages I get is "Error: REQUEST_TIMEOUT".Code: Select all
Thanks, Mark
Did that and it's looking far better now (happy that it wasn't mepepijn wrote: Try to remove and reinstall node-red-contrib-nefit-easy. There was an issue with earlier versions.
Thanks again, Mark
The new error handling in the library generate these errors. Right now I use a static timeout setting, this will be modified in a future version.
- mvveelen
Hi guys, just following this thread and hoping there will be something I could use on my Synology NAS. I'm not using Domoticz anymore on the RPi, but really want to integrate my Nefit Easy in Domoticz. Wishful thinking perhaps, but a guy can dream right
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
What about my suggestion on Tweakers? Run Node-RED on your Pi? Maybe there's also a nodejs package for Synologymvveelen wrote:Hi guys, just following this thread and hoping there will be something I could use on my Synology NAS. I'm not using Domoticz anymore on the RPi, but really want to integrate my Nefit Easy in Domoticz. Wishful thinking perhaps, but a guy can dream right?
https://www.synology.com/en-us/dsm/app_packages/Node_js
- Domoticz version: Beta Ch
Pepijn.
Got the uninstall working by adding the letter n. npm version 3.3.12
Oeps... Thanks for correcting my typoHolland wrote:Pepijn.
- mvveelen
There isn't a package with the right version, but I installed it manually and can use the deprecated script. So maybe I'm nearly there already ?pepijn wrote:What about my suggestion on Tweakers? Run Node-RED on your Pi? Maybe there's also a nodejs package for Synologymvveelen wrote:Hi guys, just following this thread and hoping there will be something I could use on my Synology NAS. I'm not using Domoticz anymore on the RPi, but really want to integrate my Nefit Easy in Domoticz. Wishful thinking perhaps, but a guy can dream right?
This "Node-RED" is abracadabra for me though. Is this necessary for the newer scripts to work with Domoticz? I'd love to try it.....
Last edited by mvveelen on Thursday 07 January 2016 22:34, edited 1 time in total.
Just wondering what is the svalue for flowtemp. I tried both flowtemp and actualSupplyTemperature, but that didn't work
domoticz_msg.payload.svalue = "" + NefitJSON['flowtemp'];
- Domoticz version: 2.4028
in current realisation:Holland wrote:Just wondering what is the svalue for flowtemp. I tried both flowtemp and actualSupplyTemperature, but that didn't work
you will receive json code like this:
{ "topic": "nefit-flowtemp", "payload": { "id": "/heatingCircuits/hc1/actualSupplyTemperature", "type": "floatValue", "recordable": 0, "writeable": 0, "value": 36, "unitOfMeasure": "C", "minValue": 0, "maxValue": 100 }, "_msgid": "830e9319.7cf17" }
"" + NefitJSON['value']]
in mine previus post i suggest to edit a nefit-easy-commands to receive it in more "human-friendly format" what we have for example for pressure
This is just the full output from the boiler. Off course I can minimize the amount of data displayed in the jsonrostyk wrote:in current realisation:Holland wrote:Just wondering what is the svalue for flowtemp. I tried both flowtemp and actualSupplyTemperature, but that didn't work
you will receive json code like this:so just use:Code: Select all
The newer 'scripts' are exactly the same as the depreciated one, only split into some parts.mvveelen wrote:There isn't a package with the right version, but I installed it manually and can use the deprecated script. So maybe I'm nearly there already ?pepijn wrote:What about my suggestion on Tweakers? Run Node-RED on your Pi? Maybe there's also a nodejs package for Synologymvveelen wrote:Hi guys, just following this thread and hoping there will be something I could use on my Synology NAS. I'm not using Domoticz anymore on the RPi, but really want to integrate my Nefit Easy in Domoticz. Wishful thinking perhaps, but a guy can dream right?
You need something to translate between the script and Domoticz. I use Node-RED for that but it can also be done in other ways like perl or lua
Robert added a supplyTemperature command to the library, I will implement this in the next version.pepijn wrote:This is just the full output from the boiler. Off course I can minimize the amount of data displayed in the jsonrostyk wrote:in current realisation:Holland wrote:Just wondering what is the svalue for flowtemp. I tried both flowtemp and actualSupplyTemperature, but that didn't work
I still have feeling that for every "nefit-easy node" we execute full authorisation session from beginning. thats not good because we overuse connections (which are limited up to five, according to Nefit documentation).
upd: thats good because for that purpose i modify status.js command include code for flow temperature just five minutes ago
As said before I'm working in session pooling. This is not that easyrostyk wrote:I still have feeling that for every "nefit-easy node" we execute full authorisation session from beginning. thats not good because we overuse connections (which are limited up to five, according to Nefit documentation).
The connection overuse you are talking about has nothing todo with the limit in Nefits documentation. The session is closed after every command so the number of concurrent sessions does not grow.
I do not advice to change Robert's library files because it's used as a dependency. Everything you do can be done within the nefit-easy.js (you are free to issue a pull request to add your modifications to the node)
Thanks Rostyk,
Btw I have created 6 sessions concurrent sessions and now I'm getting these;
-1-2016 01:06:5585298a82.9f76fmsg : errorError: REQUEST_TIMEOUT
8-1-2016 01:06:5785298a82.9f76fmsg : errorError: REQUEST_TIMEOUT
8-1-2016 01:07:13502a77ba.9da608msg : errorError: REQUEST_TIMEOUT
8-1-2016 01:07:13e193b188.2daddmsg : errorError: REQUEST_TIMEOUT
8-1-2016 01:07:1385298a82.9f76fmsg : errorError: REQUEST_TIMEOUT
8-1-2016 01:07:17502a77ba.9da608msg : errorError: REQUEST_TIMEOUT
8-1-2016 01:07:2585298a82.9f76fmsg : errorError: REQUEST_TIMEOUT
8-1-2016 01:07:2785298a82.9f76fmsg : errorError: REQUEST_TIMEOUT
I have removed the new sessions I created, hopefully the connection comes back up.
