Hi.
I need to buy a couple of dual relay switches and I would like to know if there is any that can do power measuring and is compatible with Domoticz. I was thinking about buying Fibaro FGS-221 if I don't find any other, but it would be nice to have power measurement.
The purpose is to actuate 4 1200W radiators, so FGS-221 should work fine as it does 2 x 1500w.
Thanks and regards.
[Need advice] Dual switch with power meter
ThinkPad
Re: [Need advice] Dual switch with power meter
Qubino has a dual relay module, and as far as i know, all Qubino modules have power measuring (at least the two kinds of Qubino modules i have do).
ZMNHBA2 seems to be the older version (non-Zwave plus), the ZMNHBD1 seems to be the newer Z-Wave Plus version.
But i don't know about the max. load of these, please check for your self.
dagasoft
Thanks for your reply, Thinkpad.
Yes, afaik Qubino modules do power measurement, but I need to know if they are fully compatible with Domoticz.
Do the ones you have work fine?
IDANIT
Also Philio PAN04 and PAN07 are 2x1500W with Meter. Have them both and no problems.
dagasoft
Oh, ok. I had read something about Zipato not working fine and I discarded them.IDANIT wrote:Also Philio PAN04 and PAN07 are 2x1500W with Meter. Have them both and no problems.
So are they ok? Can you switch relays individually or you have to switch both at the same time?
Thanks.
IDANIT
I see 4 devices (one Philio)
. First switches 1 relay, second switches 2 relay, third switches them both and fourth also switches them both
. I delete the third and fourth one cuz I don't need them. But it's up to You and Your needs.
dagasoft
Thanks. That behaviour is perfect to me. So what's the difference between PAN04 and PAN07? Both are 2 x 1500w with power measurement?
dagasoft
Thanks IDANIT. I should go for PAN04, because PAN07 is only 2x1100w
