Nefit Easy™
- kraades
- Domoticz version: Stable
Re: Nefit Easy™ client library (How to install on the Pi)
I am not familiar with Node-RED but is it also possible to "exec" bin/easy directly without the intermediate bash scripts?
jannl
- Domoticz version: 2026.1.x
Yes, you only need to set the 3 environment variables.
pepijn
You can also add them as command line parameters.
jannl
Correct. When using a crontab script you will need te set them in the script.
pepijn
This is how it looks like within Domoticz:
jannl
How often do you refresh?
pepijn
Temperature : 30 secondsjannl wrote:How often do you refresh?
Status Code : 10 seconds
Pressure : 5 min
The setpoint is changed real-time, if some other device changed the setpoint (thermostat, clock program, Easy app) the setpoint in Domoticz will be updated when updating the temperature.
jannl
That should be sufficient indeed. Gives me something to do next week.
- kraades
Great! I will give a try later this week.
pepijn
Here is my current Node-RED flow, have fun.
[{"id":"22a46350.4b5c8c","type":"mqtt-broker","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":15,"cleansession":true,"willQos":"0","birthQos":"0"},{"id":"8b0bfef4.74f4","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-update","payload":"","payloadType":"date","repeat":"30","crontab":"","once":true,"x":210.92857360839844,"y":72.4285717010498,"wires":[["b358d0b9.4ca73"]]},{"id":"b358d0b9.4ca73","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-status","addpay":false,"append":"","useSpawn":"","name":"Nefit Status","x":366.3730163574219,"y":72.09524345397949,"wires":[["6ebefa6b.914104","5ddfad82.a22054"],[],[]]},{"id":"3876c9bf.c78936","type":"debug","z":"b83a61b3.47c5a","name":"","active":true,"console":"true","complete":"true","x":1248.1825561523438,"y":201.17855834960938,"wires":[]},{"id":"1caaaa11.e35556","type":"mqtt in","z":"b83a61b3.47c5a","name":"domoticz/out/#","topic":"domoticz/out/#","broker":"22a46350.4b5c8c","x":195.92855834960938,"y":371.4285717010498,"wires":[["577c156d.a883ec"]]},{"id":"577c156d.a883ec","type":"function","z":"b83a61b3.47c5a","name":"de-jsonify","func":"var payload = JSON.parse(msg.payload);\nreturn payload;","outputs":1,"noerr":0,"x":361.9285583496094,"y":371.4285717010498,"wires":[["342ad05e.cbd53"]]},{"id":"23467d6a.dcb982","type":"debug","z":"b83a61b3.47c5a","name":"","active":true,"console":"false","complete":"true","x":1073.1785583496094,"y":357.1785717010498,"wires":[]},{"id":"50e0c648.af1f38","type":"function","z":"b83a61b3.47c5a","name":"Get SetPoint Value","func":"msg.payload = msg.svalue1\nreturn msg;","outputs":1,"noerr":0,"x":741.1230239868164,"y":370.5118885040283,"wires":[["a97981c8.56868"]]},{"id":"342ad05e.cbd53","type":"switch","z":"b83a61b3.47c5a","name":"filter Setpoint IDX","property":"idx","rules":[{"t":"eq","v":"160"}],"checkall":"true","outputs":1,"x":540.3729858398438,"y":370.9841136932373,"wires":[["50e0c648.af1f38"]]},{"id":"a97981c8.56868","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-set","addpay":true,"append":"","useSpawn":"","name":"Nefit Set Temp","x":930.9285697937012,"y":370.17857551574707,"wires":[["23467d6a.dcb982"],[],[]]},{"id":"6440aca2.9bbf54","type":"comment","z":"b83a61b3.47c5a","name":"Read changes from Domoticz and send to Easy","info":"","x":296.9285583496094,"y":334.4285717010498,"wires":[]},{"id":"6ebefa6b.914104","type":"function","z":"b83a61b3.47c5a","name":"Domoticz MQTT","func":"// Configuration\nconst IDX_SetPoint = 160;\nconst IDX_RoomTemp = 161;\nconst IDX_Pressure = 162;\nconst IDX_StatusCode = 163;\n\n\nvar domoticz_msg = {};\ndomoticz_msg.topic = \"domoticz/in\";\ndomoticz_msg.payload = {};\n\nif (msg.topic == 'nefit-update') {\n var NefitJSON = JSON.parse(msg.payload);\n domoticz_msg.payload.idx = IDX_RoomTemp;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + NefitJSON['in house temp'];\n}\nif (msg.topic == 'nefit-pressure') {\n var NefitJSON = JSON.parse(msg.payload);\n domoticz_msg.payload.idx = IDX_Pressure;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + NefitJSON['pressure'];\n}\nif (msg.topic == 'nefit-setpoint') {\n domoticz_msg.payload.idx = IDX_SetPoint;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + msg.payload;\n}\nif (msg.topic == 'nefit-statuscode') {\n domoticz_msg.payload.idx = IDX_StatusCode;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + msg.payload;\n}\n\nreturn domoticz_msg;","outputs":1,"noerr":0,"x":1028.4285354614258,"y":140.78571891784668,"wires":[["5bc7035e.a438fc","3876c9bf.c78936"]]},{"id":"5bc7035e.a438fc","type":"mqtt out","z":"b83a61b3.47c5a","name":"Domoticz MQTT","topic":"","qos":"","retain":"","broker":"22a46350.4b5c8c","x":1273.1785507202148,"y":142.53571319580078,"wires":[]},{"id":"2f2db332.d0d24c","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-pressure","addpay":false,"append":"","useSpawn":"","name":"Nefit Easy Pressure","x":393.9285659790039,"y":211.17857551574707,"wires":[["6ebefa6b.914104"],[],[]]},{"id":"baf3b005.450c5","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-pressure","payload":"","payloadType":"date","repeat":"300","crontab":"","once":false,"x":208.67857360839844,"y":211.17857551574707,"wires":[["2f2db332.d0d24c"]]},{"id":"2b4dca2.fd4b236","type":"comment","z":"b83a61b3.47c5a","name":"Publish data from Nefit Easy Client to Domoticz","info":"","x":289.9285583496094,"y":24.428571701049805,"wires":[]},{"id":"906bc261.6f944","type":"rbe","z":"b83a61b3.47c5a","name":"","func":"rbe","gap":"","x":794.1428527832031,"y":40.42856979370117,"wires":[["6ebefa6b.914104"]]},{"id":"5ddfad82.a22054","type":"function","z":"b83a61b3.47c5a","name":"Get Setpoint","func":"var NefitJSON = JSON.parse(msg.payload);\nmsg.topic = 'nefit-setpoint';\nmsg.payload = NefitJSON['temp setpoint'];\nreturn msg;","outputs":1,"noerr":0,"x":632,"y":40.571428298950195,"wires":[["906bc261.6f944"]]},{"id":"2296752e.dd698a","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-statuscode","payload":"","payloadType":"date","repeat":"10","crontab":"","once":false,"x":200.57141876220703,"y":145.6785717010498,"wires":[["4e5066ef.b1af98"]]},{"id":"4e5066ef.b1af98","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-code","addpay":false,"append":"","useSpawn":"","name":"Nefit Status Code","x":386.1785659790039,"y":145.92857360839844,"wires":[["8e61f998.719e08"],[],[]]},{"id":"8e61f998.719e08","type":"function","z":"b83a61b3.47c5a","name":"Get Status Code","func":"var NefitJSON = JSON.parse(msg.payload);\nmsg.topic = 'nefit-statuscode';\nmsg.payload = \"\"+\"[ \"+NefitJSON['code']+\" ] \"+NefitJSON['description'];\nreturn msg;","outputs":1,"noerr":0,"x":586.4285888671875,"y":132.92857360839844,"wires":[["8553f832.7aac08"]]},{"id":"8553f832.7aac08","type":"rbe","z":"b83a61b3.47c5a","name":"","func":"rbe","gap":"","x":741.5714111328125,"y":138.14286041259766,"wires":[["6ebefa6b.914104"]]}]
jannl
I now update the values once a minute, is the easiest frequency with crontab.
One file to update them all.
dorenberg
- Domoticz version: 4.10982
Maybe somebody can help me.
Want to have the same as pepijn has but I am already stuck with upgrading Node.js to version 5.3.0. With the command sudo cp -R * /usr/local/ I get the following error.
cp: cannot create regular file `/usr/local/bin/node': Text file busy
Cannot delete or change permissions of this file.
Can somebody help me with this?
pepijn
You need to stop all running node processes (like node red). Please note that nodejs 4 or higher will break the homebridge support
- kraades
Nefit Easy™ thermostat support
Robert Klep has developed a client in nodejs that can access the Nefit Easy™ thermostat. It would be great if this can be integrated natively in Domoticz.
https://github.com/robertklep/nefit-easy-client
More info @ viewtopic.php?f=4&t=9653.
geezerrr
Hope someone can make a wiki once there is a stable solution for the Nefit easy. I'm not a programmer but learning by the day!!
. Unfortunately I'm stuck with the red-node part..
I'm getting syntax errors., so for now I give up... Thanx in advance for all the hard work.
I'm getting syntax errors., so for now I give up... Thanx in advance for all the hard work.-
pepijn
Can you execute the scripts manualy?geezerrr wrote:Hope someone can make a wiki once there is a stable solution for the Nefit easy. I'm not a programmer but learning by the day!!. Unfortunately I'm stuck with the red-node part.. I'm getting syntax errors., so for now I give up... Thanx in advance for all the hard work.
geezerrr
The example script was working.. But I need to set my serial;acces-key and code each time I ssh to my Pi 2..
I think I have not enough program skills to solve it myselve
pepijn
Thats why you need to edit the script and replace the XXXX's
geezerrr
Of course I've replaced the XXX's
I think it has to do that i run Dz on the prepared image and the Nefit client is installed in home/Pi/Nefit-easy-client. And not in opt/Nefit/nefit-easy
pepijn
If you place the scripts in a different location you have to edit the 'EXEC' nodes in Node-RED.
Do you have MQTT enabled on your Domoticz setup?
