Domoticz tells the temperature
Sebbienl
Post by Sebbienl »
i just started with my Domoticz project.
For sounds i user the TTS from voicerss.org. Works fine with the simple actions but now i'm looking for a script that tells me the temperature.
It will tell me the temperature every hour or.... just on evert or trigger.
maybe someone has seen or found it?
regards!
Raspberry Pi 2B
RFXtrx433E USB 433.92MHz Transceiver
Wi-FI 300 MBPS
DutchHans
Re: Domoticz tells the temperature
Post by DutchHans »
See my next message
DutchHans
Post by DutchHans »
Hi, i have domoticz sent all notifications to my android phone. There is a free app which speaks notifications out loud. Here's a little script i created. I use Utter! On my android to recognize voice commands and send them as json commands to Domoticz. I can ask Domoticz what the temperature of my beer is..it replies with the following script. I guess its what youre looking for. Beercheck is a virtual switch.
Happy Newyear...
Happy to share, Hans
--script_device_sensorFridge.lua
local sensorBeer = 'Fridge Temp' --name of the sensor that gets created when you add the Cresta device (and that contains multiple values like temperature, humidity, barometer etc)
if otherdevices[sensorBeer] and otherdevices['BeerCheck'] == 'On' then
   sBeerTemp, sBeerHumidity, sBeerPressure = otherdevices_svalues[sensorBeer]:match("([^;]+);([^;]+);([^;]+)")
   sBeerTemp = tonumber(sBeerTemp)
print('Fridge Temperature is ' .. sBeerTemp)
BeerAlarmText = "Hans, The temperature of your beer is " .. sBeerTemp .." degrees Celcius. Cheers!!"
BeerAlarmURLtext = string.gsub( BeerAlarmText, " ", "%%20")
  commandArray['OpenURL']='https://autoremotejoaomgcd.appspot.com/sendnotification?key=xxxxxxxxxx--OhaJQBEbHld-eG1DjwC-Srt9miElajPslmlvYTno7MlRfy12WkDPgeM0KpPycN2XNjBMv0PT3MIWcBWrAlmOsQUK3Og5H_ptGCl7v26zlDdIkSsNnc33HQeYb_D1GOrpoaNFj9xP-bR0XHD7Cn-5XcJtUIh8sw&title=Message%20of%20the%20house&text='..BeerAlarmURLtext..'&url=ysrbXxxx.myfritz.net:8080'
  commandArray['BeerCheck']='Off'
print('-- ' .. BeerAlarmText )
  --end
