StellaZ Direct Mode?
kaivalagi
Post by kaivalagi »
Now I see there have been some mods to incorporate thermostat mode setting has anyone managed to use the direct valve control of a Trv yet? E.g. StellaZ
I am waiting on my delivery and am trying to figure out the best way to control the Trv using a philio multi sensor's reported temp. I can use setpoint adjustments but I would rather have more granular control.
Thanks in advance
wligtenberg
Re: StellaZ Direct Mode?
Post by wligtenberg »
I would also like to know how to set the Stella to direct valve control.
For now, I will also resort to setting set points, which is apparently also not very easy to do, since you cannot seem to set the set point using blockly.
cato
Domoticz version: 2.25
Post by cato »
Same here. I am setting the temp only by changing the 'comfort' setpoint (to a fake value since the achieved temp is always 1-2 degrees below what I set). Looking forward to a way to use the direct mode. I have set up the corresponding slider control but can't be used to control the valve (it is only supposed to report back how open it actually is, even if I have never seen it above 80% ...)
RPi 2 + RazBerry
