i have a weird question/trouble.
I have a group, with 3 dimmers in it.
They are working perfect, but now i want to change the dim state of 1 dimmer to 80% instead of 35.
Example, when we are at home, watching tv the dim group is activated and they are working perfect.
Now, my wife wants to set the lightin the kitchen to a higher value, with a remote control (channel 2).
I allready tried to setup a virtual switch, with a 80% function, as well a new group with the correct settings.
But, when i use the remote with the virtual switch, the light goes to 80% and after some seconds back to its normal state (35%).
When using another group, switching both of them (group 1 is on/group 2 is off, and when group 2 is on, group 1 is off), the group is working correct but the lights stays off after switched off the remote.
What is going wrong in here?
Light Group (Dim) and change 1 dim status
locogek
Re: Light Group (Dim) and change 1 dim status
The group is still active if you push the remote switch. Make a blocky when pushing the remote control turn of the script/group
Verstuurd vanaf mijn ONE A2003 met Tapatalk
BarryT
- Domoticz version: 2024.3
thanks loco...
still not finished this little error.
when i make another blocky, it is working but in the time switching from group 1 to group 2, it will cost 30 seconds or something.
in the meantime the lights are off!
locogek
I have something what's almost the same. The problem is if you use a switch to set the group and then use it in blocky the blocky script checks every minute if the switch is still on the same position. So you switch dimmer group on your wife change dimmer position and domoticz looks again if dimmer switch is still active domoticz will put the value back.
- Egregius
- Domoticz version: v2024.7
Let the script look at the current dim level and only set it to 35% when the level is lower.
Then, when you set it manually or with another script to 80% it will ignore it.
