Re: Domoticz app 2.0
Maybe we can start implement multilanguage ?
Wysłane z mojego SM-G920F przy użyciu Tapatalka
I also bought the premium version. It works very good! Thanks for that. Maybe the following suggestion's makes it even better:
* the dimming slider is very small, maybe this can be bigger. Difficult to adjust
* I have ordered the switches in domoticz, would be nice if that order can be used in the app
* security panel
* with geofencing maybe it is possible to check if the switch is toggled. When switching between WiFi and mobile network there is a small amount of time where the switch is not toggled
* it takes a long time to load the dashboard, even on a octa core tablet
* integration with Google Now for voice command
Verstuurd vanaf mijn SM-T700 met Tapatalk
* security panel
Hello
I use version premium and i have one problem. I have for me definied in Domoticz user set up as ADMIN and name Piotrek with pass, but for mi wife i have defined user setu up in domoticz as NORMAL USER with password and selected switches, plans, weather and temperature.
WHen i login by web by PC i see only this tab...and devices. But when go by Domoticz app 2.0 with setup login Iza and pass i see all devices with all tabs. Why ? How i can configure to my wife see only tabs secified in setting Domoticz ?
- RoadXY
- Domoticz version: 2.2331
Multi user isn't implemented yet.pepeEL wrote:Hello
It's on our extensive to-do list
Ok i am waiting...but what with multilanguage ?
- RoadXY
We're working on integration with Crowdin
looks great,
one thing that would be nice ,if it would update status switches etc. automagically!
I like domoticz a lot, the one thing where domoticz lags behind is in the app department, the html5 webinterface is way to slow on mobile device.
Keep it up!!!
Keep it up!!!
- RoadXY
I'm sorry, I don't know what you mean.djazzz wrote:looks great,
If you reopen the app it should refresh itself.
I totally agree!djazzz wrote:I like domoticz a lot, the one thing where domoticz lags behind is in the app department, the html5 webinterface is way to slow on mobile device.
Keep it up!!!
That's why I started on building this app
yeah I know, i noticed you can refresh status by swiping down on top of screen.
Perhaps it can be implemented through a setting eg: update interval 3/5/10/30 seconds?
In my android version 5.1 , if i switch to other apps and back to domoticz app, then the status is not updated...
I think android keeps apps in memory for a while, so you can switch faster.
If I had more time and had more experience with programming, I would make a iPhone version
- RoadXY
No, that's against Google Android best practices.djazzz wrote:yeah I know, i noticed you can refresh status by swiping down on top of screen.
And besides: what are the odds of having something changed through other ways while you have the app open.
Yes, Android keeps as much apps in memory for faster app switching.djazzz wrote:In my android version 5.1 , if i switch to other apps and back to domoticz app, then the status is not updated...
But we, developers, get notified in our app when our app is resumed.
That's why I said it should auto refresh on resuming the app.
- RoadXY
You should just start. I started like that!jadijkstra2000 wrote:If I had more time and had more experience with programming, I would make a iPhone version
Maybe better will be Transifex ?RoadXY wrote:We're working on integration with Crowdin
How i can support translation for Polish language ?
well i am sorry, but if i switch apps by using the square button in android, it does not update the status...
- RoadXY
I'll double check thisdjazzz wrote:well i am sorry, but if i switch apps by using the square button in android, it does not update the status...
- RoadXY
When the integration is done, I'll post it here.pepeEL wrote:Maybe better will be Transifex ?RoadXY wrote:We're working on integration with Crowdin
Bought premium. Thanks a lot for for your work! Now its time to test it!
Fantastic work. Have one bug as a lot of others. App crashes when trying to change value of a dimmable device. Convinced that I will like the app so done the same as other. Went pro.
Sent from my LG-D855 using Tapatalk
- RoadXY
Should be solved in next version.zait83 wrote:Fantastic work. Have one bug as a lot of others. App crashes when trying to change value of a dimmable device. Convinced that I will like the app so done the same as other. Went pro.
When you release new beta or stable version please add in change log google play what is new or change or fix to we know whatvwe can test
