I changed in 1 line, put in some more text in print to see it ii log better
print('test1=file===this will end up in the domoticz log')
this only change in this file from version 2.3530 (on Raspberry pi)
-- demo time script
-- script names have three name components: script_trigger_name.lua
-- trigger can be 'time' or 'device', name can be any string
-- domoticz will execute all time and device triggers when the relevant trigger occurs
-- copy this script and change the "name" part, all scripts named "demo" are ignored.
-- Make sure the encoding is UTF8 of the file
-- ingests tables: otherdevices,otherdevices_svalues
What is wrong?
Sven Åke
-- otherdevices and otherdevices_svalues are two item array for all devices:
-- otherdevices['yourotherdevicename']="On"
-- otherdevices_svalues['yourotherthermometer'] = string of svalues
-- Based on your logic, fill the commandArray with device commands. Device name is case sensitive.
-- Always, and I repeat ALWAYS start by checking for a state.
-- If you would only specify commandArray['AnotherDevice']='On', every time trigger (e.g. every minute) will switch AnotherDevice on.
-- The print command will output lua print statements to the domoticz log for debugging.
-- List all otherdevices states for debugging:
-- for i, v in pairs(otherdevices) do print(i, v) end
-- List all otherdevices svalues for debugging:
-- for i, v in pairs(otherdevices_svalues) do print(i, v) end
t1 = os.time()
s = otherdevices_lastupdate['Garagedoor']
-- returns a date time like 2013-07-11 17:23:12
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
difference = (os.difftime (t1, t2))
if (otherdevices['Garagedoor'] == 'Open' and difference > 600 and difference < 700) then
commandArray['SendNotification']='Garage door alert#The garage door has been open for more than 10 minutes!'
return commandArrayCode: Select all
015-12-24 22:16:00.022 LUA: test1=file===this will end up in the domoticz log
2015-12-24 22:16:00.022 Error: EventSystem: /home/pi/domoticz/scripts/lua/script_time_test1.lua:33: bad argument #1 to 'sub' (string expected, got nil) in an other file
f_light =12.345
commandArray["Variable:Ljus"] = tostring(f_light)Code: Select all
Error: EventSystem: /home/pi/domoticz/scripts/lua/script_time_sac.lua:43: attempt to index global 'commandArray' (a nil value)
