Mobile Phone Online
Smartie
Mobile Phone Online
Post by Smartie »
Domoticz Mobile Phone Switch
To check if anybody is Home or not make a Dummy Switch an look at the IDX Number
now login to SSH an add a Script.
cd /home/pi/domoticz/scripts
sudo nano ping_by_ip.pl
now past the follow script at the file an change the IP and IDX Number
# Array of (device idx, IP)
my %IP=(24=>'192.168.178.23', # TV
23=>'192.168.178.32', # Me
25=>'192.168.178.30'); # Tablet
#!/usr/bin/perl
    use v5.14;
    use LWP::Simple;                # From CPAN
    use JSON qw( decode_json );     # From CPAN
    use Data::Dumper;               # Perl core module
    use strict;                     # Good practice
    use warnings;                   # Good practice
    use utf8;
    use feature     qw< unicode_strings >;
    # Configuration section, please update to your values
    my $domoticz = "127.0.0.1:8080";  # ip and port of your Domoticz server
    my $domo_cmd = "http://$domoticz/json.htm?type=devices&filter=all&used=true&order=Name";
    my $debug=0;
    # Get the JSON url
    my $json = get( $domo_cmd );
    die "Could not get $domo_cmd!" unless defined $json;
    # Decode the entire JSON
    my $decoded = JSON->new->utf8(0)->decode( $json );
    my @results = @{ $decoded->{'result'} };
    #Put JSON switch and status in a Table
    my @tab;
    foreach my $f ( @results ) {
      if ($f->{"SwitchType"}) {
            $tab[$f->{"idx"}]=$f->{"Status"};
    # Now we go all over the IP to check if they are alive
if you have done this save the script with STRG + O and Exit with STRG + X
HINT: STRG is the german Layout for US it is CTRL
now add a crontab with
crontab -e
add in the last line
*/1 * * * * /home/pi/domoticz/scripts/ping_by_ip.pl 2>&1 >> /dev/null
and save with STRG + O and Exit with STRG + X
Now you can using the switch at Domoticz for Programming Actions...
:D
gflvern
Re: Mobile Phone Online
Post by gflvern »
Hi Smartie,
I think your code block is missing some code that checks to see if the IP addresses in the array are alive.
Cheers
gfl
Smartie
Post by Smartie »
no it works by me i have only copy the part with the ip Adress so show what you must change.
This code Works fine by me so i habe a switch and can use Blocky
gflvern
Post by gflvern »
Smartie wrote:no it works by me i have only copy the part with the ip Adress so show what you must change.
But I would like to copy the rest of the script so I can try this for myself. To ping the IP addresses it needs the rest of the script surely?
Smartie
Post by Smartie »
Yes copy the script using you're in from phone or something then it works fine :) but you must change you're idx and ip address ;)
Try it
