Everspring
Website:
http://www.everspring.com.tw/AN158.aspx
Function:
Switch Meter Plugin 3500 W, reports Wh and kWh.
Z-Wave5
No
Rebranding:
Eminent e-Domotica EM6552 (thanks ThinkPad)
Device Library from http://www.pepper1.net
http://www.pepper1.net/zwavedb/device/54
Manuals from manuals.zwaveeurope.com and doc.eedomus.com:
manuals.zwaveeurope.com: PDF
doc.eedomus.com User doc PDF
Domoticz experience
Hardware: Remarks:
8 operational, no polling needed
During a year, 3 of them lost once their ID (blinking led) random in time (spark? power dip?)
They give a strong contribution to the Z-Wave network
Configuration: Devices zwcfg_0xaaaaaaa.xml sample:
<Node id="13" name="Wasmachine" location="" basic="4" generic="16" specific="1" type="Routing Slave" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="3" query_stage="Complete">
<Manufacturer id="0060" name="Everspring">
<Product type="0004" id="0002" name="AN158 Plug-in Meter Appliance Module" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4">
<Instance index="1" />
</CommandClass>
<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="4">
<Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
</CommandClass>
<CommandClass id="39" name="COMMAND_CLASS_SWITCH_ALL" version="1" request_flags="4">
<Value type="list" genre="system" instance="1" index="0" label="Switch All" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="3" size="1">
<Item label="Disabled" value="0" />
<Item label="Off Enabled" value="1" />
<Item label="On Enabled" value="2" />
<Item label="On and Off Enabled" value="255" />
</Value>
</CommandClass>
<CommandClass id="50" name="COMMAND_CLASS_METER" version="2" request_flags="2">
<Value type="decimal" genre="user" instance="1" index="0" label="Energy" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="147.9" />
<Value type="decimal" genre="user" instance="1" index="1" label="Previous Reading" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="-7424" />
<Value type="int" genre="user" instance="1" index="2" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="32768" />
<Value type="decimal" genre="user" instance="1" index="8" label="Power" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0" />
<Value type="decimal" genre="user" instance="1" index="9" label="Previous Reading" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0" />
<Value type="int" genre="user" instance="1" index="10" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="243" />
<Value type="bool" genre="user" instance="1" index="32" label="Exporting" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="button" genre="system" instance="1" index="33" label="Reset" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4">
<Value type="short" genre="config" instance="1" index="1" label="True Period" units="100ms" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="120" value="10">
<Help>This is the time the switching status needs to remain unchanged after a change to cause the device to send out a status message. 0 is Disabled.</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="2" label="Send Out Basic Command" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" value="0">
<Help>Enable or Disable Send Basic Command to Group 2 when the local button press changes the switching state.</Help>
</Value>
<Value type="short" genre="config" instance="1" index="3" label="Meter Report Period" units="10s" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="3240" value="6">
<Help>The device will report its meter value within the interval set. Set to 0 will disable the autoreporting function.</Help>
</Value>
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4">
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4">
<Associations num_groups="2">
<Group index="1" max_associations="1" label="Reports" auto="true">
<Node id="1" />
</Group>
<Group index="2" max_associations="4" label="Basic" auto="true">
<Node id="1" />
</Group>
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="6" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="2.64" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.01" />
</CommandClass>
</CommandClasses>
</Node>Gives a strong contribution to the network.
Reliable switch with instantaneous and cumulative energy usage.
Some ID glitches
Recommended.
Hope this helps
Domosapiens
