I will try using your script
-- ~/domoticz/scripts/lua/script_time_PIRs.lua
function timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
difference = os.difftime (t1, t2)
return difference
for i, v in pairs(otherdevices) do
timeon = 240
tc = tostring(i)
v = i:sub(1,3)
if (v == 'PIR') then
difference = timedifference(otherdevices_lastupdate[tc])
if (difference > timeon and difference < (timeon + 60)) then
tempdiff = tostring(difference)
c = i:sub(4)
tempmessage = c.." Light Off - after at least " .. (timeon+1) .. "secs up - actually - " .. tempdiff .. "seconds"
print(tempmessage)
commandArray[c] = 'Off'
So I guess that I have to modify your above script in order to tell Domoticz to switch Off device "Switch1" if no motions are detected during 120 sec.
Considering your suggestions I tried to modifify your script as follow
t1 = os.time()
return difference
timeon = 120
tc=next(devicechanged)
v=tostring(tc)
-- Look for a device name which ends in PIR
if (v:sub(-3,-1) == 'PIR') then
c = i:sub(4)
print(tempmessage)
return commandArraytimeon = 120
v=tostring(tc)
to set a period of 120 seconds and to tell Domoticz to serarch for a device name which ends in PIR (my "OcchioMagicoFibaro-PIR")
I don't know if I have done correctly until this point (please advice me) and furthermore I don't know how to modify the bottom part of your script to instruct Domoticz to switch Off device "Switch1"
Would you help me?
Claudio
