I have installed the Domoticz Rasp Image from the homepage.
Do I have to install and complie Open Zwave if I want to use an Aeon Lab stick or is open zwave included in the image?
Open zwave
- gizmocuz
Re: Open zwave
its included in the image (actually it is static linked in domoticz)
Rena
- Domoticz version: V 3.8153
Re: Open zwave
Thanks! So I just have to power off the Rasp and put the stick in an USB-port. Then start up and add hardware?gizmocuz wrote:its included in the image (actually it is static linked in domoticz)
Rena
Re: Open zwave
gizmocuz wrote:Yep
Doesn´t work on my Rasp. I think I need some help.
When trying to see if the Rasp have found the stick, it looks like this. I can see two things attached to USB-ports and that´s correct. I have the RFXTRX and Aeon stick attached.
When trying to add the stick under hardware, the only USB-port I have is the which is connected to the RFXTRX.
What should I do?
radem205
Re: Open zwave
Follow this guide and you'er done: http://www.vesternet.com/resources/appl ... es/apnt-85
Rena
Re: Open zwave
Thanks - just one question. I have both "TTYAMA0" and "TTYACM0". Is there any way to check which one is Aeon stick?radem205 wrote:Follow this guide and you'er done: http://www.vesternet.com/resources/appl ... es/apnt-85
