I'm getting a lot of problems to include my Fibaro FGK-101 door sensor into Domoticz. I've tried everything (include,exclude, reset ...) with no luck. Have someone any advise? I've tested the battery, and that's not the problem.
Enviado desde mi iPad utilizando Tapatalk
pvm
- Domoticz version: 4.10538
Re: Fibaro FGK-101 door sensor
What wave device are you using ? Aeonlabs?
ZME_UZB1
phitar
- Domoticz version: 2.2436
I have had a lot of problems with it as well. It stopped showing door openings a few months ago so I tried removing it from my z-wave network and reincluding it. Not sure exactly what did the trick but it seems I had to use the underside tmp button. The upper tmp button has to be clicked 3 times in a row twice before it can reset properly (from some forum post somewhere).
It was a pain to reinclude and I ended having to detach it from the door, messing with the dual sided tape...
