I already have an Elro DB286A Doorbell and I would like to know if I can get it to work with Domoticz.
I tried to learn the switch within Domoticz but it doesn't recognize the doorbell when I press it.
Does someone know if it is possible to use this doorbell?
Thanks in advance!
rednas
Re: Elro DB286A Doorbell
Does someone know whether this thing would work with Domoticz? (This is the one: http://www.bol.com/nl/p/elro-db286a-dra ... 0010646046)
At the back of the wireless chime is stated: 433.92MHz
However when I press "Learn Light/Switch" nothing is happening in Domoticz when I press the doorbell. So it looks like it is not recognized.
How is this possible?
Heisenberg
You should check the compatability list first: http://www.rfxcom.com/WebRoot/StoreNL2/ ... _Guide.pdf
If your device is not supported you can ask the owner of RFXcom for support.
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
rednas
I am using RFLink, not RFXcom. Does it matter?
Heisenberg
My bad. I didn't notice that. But in that case I suggest you ask for support by RFLink and share your findings hererednas wrote:I am using RFLink, not RFXcom. Does it matter?
Raspberry Pi Type B
RFXCOMtrx433e
RFXCOMtrx433e
