[Help] Variable Question for Quindor's Sample Project
jeremiahlandi
Post by jeremiahlandi »
I have followed the steps outlined by Quindor in his blog about setting up "ESP8266 WiFi LED dimmer Part 4 of X: Configuring Domoticz".
(http://blog.quindorian.org/2015/01/esp8 ... -of-x.html)
My question stems around the variables in the Domoticz Lua script:
DomDevice = 'GPIO-0_channel'
IP = '10.10.200.10'
Port = '43333'
LEDtarget = 'LED1_Target='
What are the targets of these variables and what should their values be (e.g. the ESP8266 or the Domoticz server)? I have them currently setup with my device IP and the same port; however, if i move my dimmer the LED doesn't dim on the device. Just want to make sure I am setting things up correctly.
jeremiahlandi
Re: [Help] Variable Question for Quindor's Sample Project
I believe I have figured it out after some more rereading.
I believe my original assumption to be correct. The Variables are used to send an echo command in the script, so it makes sense it is telling the server what the device IP is to send it to. If this doesn't make sense or I am wrong please let me know.
IP = '10.0.1.8'
Port = '43333'
 if devicechanged[DomDevice] then
   if(devicechanged[DomDevice]=='Off') then DomValue = 0;
   print ("Turning off " .. DomDevice);
   runcommand = "echo " .. (LEDtarget) .. "0  | nc " .. (IP) .. " " .. (Port) .. " ";
   print (runcommand);
   os.execute(runcommand);
    DomValue = (otherdevices_svalues[DomDevice]);
   CalcValue = DomValue * 33;
   print ("Value received from Domoticz was " .. (DomValue) .." ");
   print ("Calculated value for ESP is " .. (CalcValue) .." ");
   print ("Dimming "  .. (DomDevice) .. " to " .. (CalcValue) .. " ");
   runcommand = "echo " .. (LEDtarget) .. "" .. (CalcValue) .. " | nc " .. (IP) .. " " .. (Port) .. " ";
   print (runcommand);
