Anyone using the LEDENET Magic UFO LED WIFI Controller
Animeimp
Post by Animeimp »
I received one of these in last week, and while only a iPhone and Android client have been written for them, I got the documentation from China, and with much packet captures, have gotten it working from a PC, and now in Domoticz. The functionality within Domoticz is actually via a Node.Red configuration with a web interface, but if there is any interest, I will look at making a hardware module for Domoticz. It is a rather nice unit, runs about $25 USD, and can be either a AP or Client on wireless networks, and draws very little power for itself.
Domotiz 2.2276/Synology DS512+/Aeon Z Wave/Hue Lights
JelleD
Re: Anyone using the LEDENET Magic UFO LED WIFI Controller
Post by JelleD »
Hi Animeimp,
I am using 2 Magic UFO controllers, and i would like to use them zith Domoticz.
Did you make the hardware module? Or can you guide me in connecting the magic ufo to my Domoticz.
Thanks.
pvm
Domoticz version: 4.10538
Post by pvm »
A Ruby implementation is available at https://github.com/sidoh/ledenet_api/bl ... /README.md
Are you a programmer?
JelleD
Post by JelleD »
I am not a programmer, so this is new for me.
Do i need to install Ruby? Or is it already on the raspberry install?
emme
Domoticz version: latest
Post by emme »
Hi to all,
I've sucesfully installed the ledenet, but still get some issue about:
even if the --on parameter is given, it does not power on (status is_on:false always returned)
I'm unclear how to integrate it with Domoticz...
I assume I should have to create a virtual rgbw switch then assign a script that should gather the RGBW parameters... but the virtual RGB switch does not provide such information yet... correct?
thanks in advance
ciao
M
"We always done this way"
Derik
Post by Derik »
some have the api working?
And how to use it?
emme
Post by emme »
nope!
I still have the issue that the api works but it does not power ON/OFF...
so I moved to a Fibaro RGBWController :D :D :D
Derik
Post by Derik »
mmm And how can you control the Fibaro? can you set different scenes? and different colors? or start the fibaro in the last color-range?
emme
Post by emme »
yes I control the Fibaro via DOmoticz and Aeotec G5 stick
yes I control scenes with a virtual selector switch and a bit of help: http://domoticz.com/forum/viewtopic.php?p=69242#p69242,
of course I can select a specific color
and.... I think so, never tried, but I'm quite sure if you power off and back on the color will be still the same
just the animation programs will override your color settings
cherowley
Post by cherowley »
I tried using this (lua script):
commandArray = {};
DomDevice = '???'
IP = '192.168.2.180'
Port = '5577';
print("UFO LED Controller Script")
function send(msg)
runcommand = "echo "..msg .."| telnet "..IP.." "..Port.." "
print (runcommand)
os.execute(runcommand)
if devicechanged[DomDevice] then
if(devicechanged[DomDevice]=='Off') then
print("Turning OFF")
send(string.char(113,36,15,164))
send(string.char(113,36,15,164,255,0,65))
elseif (devicechanged[DomDevice]=='On') then
print("Turning On")
send(string.char(113,35,15,163))
print(devicechanged[DomDevice].." is neither ON or OFF")
end;
Derik
Post by Derik »
Someone have a How To... for the use of this UFO controller...
I will try...
Only i cannot understand the use of the Ha_gateway
sweup
Post by sweup »
Someone got Magic Ufo to play nicely with domoticz (on/off, colors etc)? Would really appreciate some guidance if someone got it working.
Derik
Post by Derik »
I do have 1 for sale..
Small price to pay with this..
Pm me
DickN
Post by DickN »
Derik wrote:I do have 1 for sale..
Pm me
Derik,
I Like to contact with you about some questions in Dutch. I can't Pm you at this moment
