Script to powercycle modem if ping fails?
ThinkPad
Re: Script to powercycle modem if ping fails?
I just used a Home Easy plug i had lying around doing nothing. My neighbours (age 60+) don't have home automation stuff.
ThinkPad
I see that my script has triggered once, this morning at 04:20
Probably has something to do with the DDoS attack at the Ziggo DNS-servers yesterday (and the day before also). But i didn't notice anything (loss of internet or so) this morning, so the script does its job
The DDoS was repelled by Ziggo around 4:00, so seems logically that there may have been issues that caused the script to trigger at that time.
And for the DNS-servers being unavailable... i was already using different DNS-servers (OpenNIC) so i didn't have any issues during the DDoS-attacks.
martjah
I've changed/updated your script so it turn a virtual switch on/off. I like to do everything with blockly
. (and logging of the connection availlability regardless of executing some action)
#!/bin/bash
FirstIP="8.8.8.8" #Google DNS
SecondIP="208.67.222.222" #OpenDNS Public DNS
IDX="491" #IDX of the outlet that controls power to your modem
DomoIP="192.168.0.204"
DomoPort="8080"
COUNTER=0
while [ $COUNTER -lt 3 ] ## Try 3 times before resetting the modem. Modify as needed.
do
if ping -c 1 -w 5 $FirstIP &> /dev/null ## Determine if second IP-address is reachable.
then
echo "First IP responds, we are connected"
curl 'http://'$DomoIP':'$DomoPort'/json.htm?type=devices&rid='$IDX'' | grep '"Status" : "On",'
if [ $? -eq 0 ]
then
echo "Switch was already on, so nothing has to be done"
echo "The switch was off, so we will turn it on"
curl 'http://'$DomoIP':'$DomoPort'/json.htm?type=command¶m=switchlight&idx='$IDX'&switchcmd=On'
fi
exit 1
elif ping -c 1 -w 5 $SecondIP &> /dev/null ## Determine if second IP-address is reachable.
then
echo "Second IP responds, we are connected"
if [ $? -eq 0 ]
then
fi
exit 1
let COUNTER=COUNTER+1
fi
done
curl 'http://'$DomoIP':'$DomoPort'/json.htm?type=devices&rid='$IDX'' | grep '"Status" : "Off",'
if [ $? -eq 0 ]
then
echo "Switch was already off, so nothing has to be done"
echo "The switch was on, so we will turn it off"
curl 'http://'$DomoIP':'$DomoPort'/json.htm?type=command¶m=switchlight&idx='$IDX'&switchcmd=Off'
fi
jannl
- Domoticz version: 2026.1.x
Just curious, why wait 5 seconds for the ping to return?
And why not ping the DNS server(s) of your ISP?
ThinkPad
You don't want the script to be TOO sensitive.jannl wrote:Just curious, why wait 5 seconds for the ping to return?
And pinging Google & OpenDNS is much better than pinging the DNS of your own ISP. If Google or OpenDNS are down, the internet will break
Few months ago there was a DDoS on the Ziggo DNS-servers. In this case the script would reboot your modem. But if you use OpenDNS & Google DNS like i do, you wouldn't even notice there was a problem with the Ziggo DNS-servers (which are crappy and slow anyway, just use OpenDNS & Google DNS, much more stable and faster responses).
jannl
Haha ok, ziggo is may be a bad example
, but I think(hope) they protected themselves against future ddos attacks.
But still, waiting 5 seconds for a ping to time-out is way too long in my opinion, even when pinging googles dns servers.
ThinkPad
Might be true. But the script is not aimed at speed. It is meant to be run every 15min or so, through cron.
It will run in the background, so those 5 secs of waiting are not interesting.
If you would check the uptime by hand, waiting 5 secs is too long indeed.
But feel free to adapt the script to your own likings
jannl
Not really needed. I can set my router to disconnect at a certain time each day if needed. But normally the connection comes back online automatically.
Evelen
- Domoticz version: 2.4538
why not pung several DNS's and make the script run only if non of them replay
ThinkPad
Have you read the script
? That is exactly what i do
Evelen
not until nowThinkPad wrote:Have you read the script? That is exactly what i do
- Siewert308SW
- Domoticz version: Stable
Total noob as it comes to bash and such.
But i hope some has a solution for my problem.
I have a new generation Cisco EPC3928AD EuroDocsis modem from ziggo with their custom firmware.
As out off curiosity i wanted to know if i could reboot my modem without the need of a extra wallplug.
After searching, copy and past i managed to create the below script.
It pings Google and if not reachable it will try to reboot my modem.
It does ping and then want to login in my modem.
And here it goes wrong.
As the page which is called is a .asp i get the message that my browser isn't supported as it is lacking java.
How to overcome this, any help is appreciated.
Is it even possible the fill-in a java form true bash?
#!/bin/sh
ping -q -c1 google.com /dev/null
if [ $? -ne 0 ] ; then
rm /var/log/cookie
curl -L -c /var/log/cookie -d "username_login=admin" -d "password_login=password" -d "login=Log+In" http://192.168.178.1/goform/Docsis_system /dev/null
curl --cookie /tmp/cookie --referer http://192.168.178.1/Devicerestart.asp -d "mtenRestore=Device+Restart" -d "devicerestart=1" http://192.168.178.1/goform/Devicerestart /dev/null
fiSetup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
- DS923+ Docker
ThinkPad
You had also responded on my blog, where i told you to change the user-agent that cURL uses.
Then you said that didn't work, which is a pity. I don't know how to work around this Java stuff...
Try looking if your modem has telnet, maybe you can then issue a reboot command with a script that connects to your modem with telnet.
Otherwise just put a 433Mhz / Z-Wave plug between that you control with Domoticz. That's exactly how i did it in my setup.
I'm not using this anymore now, i switched from Ziggo to Telfort. With xDSL it is recommended to leave the modem on for 24/7, otherwise the streetcabinet might think there is something wrong with the copperline and adjust your speed (downwards!
) to improve stability.
- Siewert308SW
No worries mate.ThinkPad wrote:You had also responded on my blog, where i told you to change the user-agent that cURL uses.
I'm not using this anymore now, i switched from Ziggo to Telfort. With xDSL it is recommended to leave the modem on for 24/7, otherwise the streetcabinet might think there is something wrong with the copperline and adjust your speed (downwards!) to improve stability.
Have been playing all day and it didn't had anything to do with the UserAgent.
I do have it working now, And the first part is based on your script except the reboot process...
Don't ask me why, but the problem was mainly caused by the cookie file which is needed for the ziggo login page.
This file was somehow not readable in /home/pi/domoticz.
So i set it to /var/tmp.
Also one variable for the login page /gotoform was wrong.
#!/bin/bash
#-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
# Ziggo_Modem_Reboot.sh
# @author: Siewert Lameijer
# @since: 23-12-2015
# @version: 1.0
# @Script for rebooting the ZIGGO Cisco EPC3928AD EuroDocsis 3.0 2-PORT Voice Gateway
# @Credits to Thinkpad for the first part of the script (Ping and counter)
#-- Modem Reboot Settings Begin
SecondIP="89.101.251.228" #Ziggo DNS
ModemIP="192.168.178.1" #Modem IP
DomoIP="127.0.0.1" #Domoticz local IP
DomoPort="8080" #Domoticz poort
#Modem Credentials
Modem_Username="<username>"
Modem_Password="<password>"
Count="5" #Aantal keren dat er gepinged moet worden voordat de modem word gereboot
#-- Modem Reboot Settings End
Counter=0
while [ $Counter -lt $Count ]
do
if ping -c 1 -w 5 $FirstIP &> /dev/null ## Bekijk of het eerste IP-address reageerd op de ping.
then
echo "Eerste IP-address reageerd, We gaan niks doen"
exit 1
elif ping -c 1 -w 5 $SecondIP &> /dev/null ## Bekijk of het tweede IP-address reageerd op de ping.
then
echo "Tweede IP-address reageerd, We gaan niks doen"
exit 1
let Counter=Counter+1
fi
done
#Reboot Modem
echo "Modem reageerd niet, we gaan de modem rebooten"
curl -L -c /var/tmp/modem_reboot_cookie.txt --referer http://$ModemIP/login_zig.asp -d "Zigloginnaam=$Modem_Username" -d "Zigpassword=$Modem_Password" -d "login=Log+In" http://$ModemIP/goform/login_zig > /dev/null
curl --cookie /var/tmp/modem_reboot_cookie.txt --referer http://$ModemIP/Devicerestart.asp -d "mtenRestore=Device+Restart" -d "devicerestart=1" http://$ModemIP/goform/Devicerestart > /dev/null
Setup:
- DS923+ Docker
- DS923+ Docker
ThinkPad
Nice that you got it working, that's the real spirit
How did you test if the script was really working? Putting in IP's that will never respond? (LAN range but not assigned to a device yet)
- Siewert308SW
Yep... once want to work i get it to workThinkPad wrote:Nice that you got it working, that's the real spiritHow did you test if the script was really working? Putting in IP's that will never respond? (LAN range but not assigned to a device yet)
Indeed, i put in two IP-Addresses on the internet and not lan based which will never respond.
But i have the feling i'm missing something in the check, don't know what it could be...
[edit]
i know what i'm missing.
It's a cooldown periode, i mean when the modem is rebooted it could take up to 15 min to get a internet connection.
Setup:
- DS923+ Docker
- DS923+ Docker
ThinkPad
If you run the script every 15 min through a cronjob, the modem has time enough to make the internet connection i think
