jumbotroll wrote:greuh wrote:Well, domoticz is running, but it does not see my Aeon labs GEN5 USB stick
No hardware is detected.
I also tried to add a new hardware manually, type= "OpenZwave USB", and tested for every USB port.
But each time, I have the following errors in my synology's log:
ERROR: Cannot open serial port /dev/ttyUSB0. error code 19
What am I supposed to do ?
If I understand you correctly, OpenZWave USB does not appear in the dropdown menu?
Have you downloaded the latest version domoticz_88f6281-4.3_2.0.3771-7.spk
http://jadahl.dscloud.me/sspks/index.php?fulllist=true
Jumbotroll
The "type" dropdown menu from the hardware page shows the "OpenZWave USB" line. No problem with that.
But I tried every USB port that is suggested and results each time the same:
or
ERROR: Cannot open serial port /dev/ttyUSB3. error code 19
for USB3, obviously...
This log message are from the synology logs.
In domoticz, I have the following log:
2015-12-05 16:27:31.000 OpenZWave: Starting...
2015-12-05 16:27:31.000 OpenZWave: Version: 1.3-565-gec4efa6
2015-12-05 16:27:31.000 OpenZWave: using config in: /usr/local/domoticz/Config/
2015-12-05 16:27:51.043 Error: OpenZWave: Driver Failed!!
I was using domoticz_88f6281-4.3_2.0.3619-7.spk, I have just tested with the latest domoticz_88f6281-4.3_2.0.3771-7.spk with the same results
