Guardband band value to avoid spike on graphs
patoche
Post by patoche »
I have sometime very strange and big values for rain, wind, electicity. It is not so easy to check every days the database to verify if all is ok and to do correction.
Maybe if we can define min and max values authorized by ID it will be usefull.
For example wind between 0 and 150 km/h, electricity between 0 and 20 KW,.... for the instant measurement.
All measurements out of range will be ignore.
gizmocuz
Re: Guardband band value to avoid spike on graphs
Post by gizmocuz »
There should be no 'strange' values
if there are, you can remove them by shift-click on the month/year data point that is to high
patoche
Post by patoche »
I know that, but the problem with shift + click month or year is i delete one day, not only one error measurement during the day. :(
PABben
Post by PABben »
Thats one of the few things i miss in domoticz, the option to drop false readings.
A way to define "if reading is X more/less than the previous reading, discard"
