Running time script every 30 secs
void
Post by void »
Anyone knows if it is possible to run the time based scripts more often?
For instance, twice per minute instead of 'only' one time?
I noticed my presence detection isn't fast enough.
Cheers.
Egregius
Domoticz version: v2024.7
Re: Running time script every 30 secs
Post by Egregius »
Run it by cron.
* * * * * /path/script
* * * * * sleep 30 && /path/script
void
Post by void »
Oh can LUA scripts be started from the shell as well?
I thought it was an interal domoticz thingy.
Egregius
Post by Egregius »
Don't know about lua, I don't use that :lol:
Php does everything I want :mrgreen:
jvdz
Domoticz version: 4.107
Post by jvdz »
void wrote:Oh can LUA scripts be started from the shell as well?
Yes you can but won't have the event tables available so need to use JSON call to request information or send commands from/to Domoticz.
Jos
void
Post by void »
Do you have an example Jos?
I thought it would be easyer to call a second bash script in the LUA that slept for x-seconds, but LUA is screaming in the logs that the script is running longer then 10 seconds.
Apparently that's a bad thing...
ThinkPad
Post by ThinkPad »
I don't know how your presence detection works, but maybe you can convert the script to a 'script_device_presence.lua' instead of a 'script_time_presence.lua' ?
A script_device is ran on EVERY device update, so much faster.
Then in the script, check for your device if it has changed:
if devicechanged(['switch1234']== 'On')
rest of your script...
rimram31
Post by rimram31 »
Perhaps both :-)
Having a shell script checking presence every xx s and, when happened, only setting on a domoticz dummy device so a domoticz lua script later make the rest of the job.
jvdz
Post by jvdz »
void wrote:Do you have an example Jos?
You could look at the scripts that simon (and me for the menu extension) build for DTGBOT. ( https://www.domoticz.com/wiki/Remote_Co ... legram_Bot)
There are several functions in there to retrieve device status and set devices.
Jos
void
Post by void »
ThinkPad wrote:I don't know how your presence detection works, but maybe you can convert the script to a 'script_device_presence.lua' instead of a 'script_time_presence.lua' ?
It's this one viewtopic.php?f=23&t=5256
Every <time based, so 1 minute> the LUA runs arp-scan and updates the dummy switches.
Perhaps changing to a device script might work, I'll check it out.
void
Post by void »
It works in basic, but it's running multiple times simultainiously now.
Log:
2015-12-03 11:42:25.233 LUA: SGS6; now:2015-12-03 11:42:24; last seen: 2015-12-03 11:39:23
2015-12-03 11:42:25.235 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_Presence.lua
2015-12-03 11:42:26.403 LUA: SGS6; now:2015-12-03 11:42:25; last seen: 2015-12-03 11:39:23
2015-12-03 11:42:26.405 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_Presence.lua
2015-12-03 11:42:27.564 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_Presence.lua
2015-12-03 11:42:27.572 LUA: *** No trusted phones connected to wireless, enabling alarm and turning off lights ***
2015-12-03 11:42:27.764 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_Arm.lua
2015-12-03 11:42:26.414 (DUMMY) Lighting 1 (SGS6)
2015-12-03 11:42:28.934 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_Presence.lua
2015-12-03 11:42:30.134 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_Presence.lua
2015-12-03 11:42:30.142 LUA: *** No trusted phones connected to wireless, enabling alarm and turning off lights ***
2015-12-03 11:42:30.289 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_Arm.lua
2015-12-03 11:42:28.942 (DUMMY) Lighting 1 (SGS6)
As you can see the detection of the phone (Device name is SGS6) gets triggered twice, with 200ms apart.
This results in a double notification from the Telegram bot and other triggers such as turning off all the lights being executed two times right after eachother.
