Sure we still need testers, PM me your email address... and I will get you started.thecosmicgate wrote:Still possible to test ? Or testers wanted?
Sent from my MotoG3 using Tapatalk
MyDomoticz - Testers wanted!
- chimit
- Domoticz version: master
Re: Testers wanted!
rgroothuis
Re: Testers wanted!
Let me know if you need more testers, I like the idea and willing to support this.
assenzuid
Re: Testers wanted!
I will also give it a try.
- chimit
Re: Testers wanted!
For people with concerns about being in the cloud, I made a compile-time option to build Domoticz with no cloud-code at all.
- jvdz
- Domoticz version: 4.107
Re: Testers wanted!
Having the code in the core Domoticz setup should not be a problem as long as it is disabled by default... right?chimit wrote:For people with concerns about being in the cloud, I made a compile-time option to build Domoticz with no cloud-code at all.
It would be a shame when everybody that doesn't want to use this feature, would not be able to use the standard build-in update facility and are forced to compile themselves.
Jos
- chimit
Re: Testers wanted!
True, the service is disabled by default. Only when you choose to, Domoticz will connect to the cloud.
- chimit
Re: Testers wanted!
There's a description of the service at http://domoticz.com/wiki/MyDomoticz
- thecosmicgate
- Domoticz version: newest
Re: Testers wanted!
As described in the wiki : You won’t see your domoticz instance yet. For this, you need to instruct your local Domoticz on the settings page. Scroll down to “MyDomoticz settings”. The MyDomoticz instance id will be empty.
This option is not available in the settings tab(running the latest beta)
It's nice to be important, but it's more important to be nice
Scooter ;)
Scooter ;)
fhwessels
- Domoticz version: latest
Re: Testers wanted!
chimit I don't see the MyDomoticz service in the Domoticz setup pages. Where will I get it? I am running ver 2.3713
- jvdz
Re: Testers wanted!
Probably because it isn't integrated yet as stated in the Wiki
JosAlpha phase
Note that currently the MyDomoticz service is in alpha phase and is not available through the normal beta release update. This will be changed as soon as we made sure that the service is bug free.
We happily welcome all alpha testers and if you want to join, send a pm to user "chimit" on the Domoticz forum.
fhwessels
Re: Testers wanted!
just a question how do update to the next beta release?
- chimit
Re: Testers wanted!
In the domoticz directory where you checked out the MyDomoticz branch, issue "git pull" and then "make" again. This will build a new beta release.
After that restart domoticz and presto.
== Rene
== Rene
fhwessels
Re: Testers wanted!
hi chimit I have the following issue I can log on via My.Domoticz.com without any problem and I can manage my system via the web. The next time I try to log to my system the icon of the man is now red and the only way that I can log onto my system again is to reboot the raspberrypi Why will this happen?
- chimit
Re: Testers wanted!
When did you do a git pull for the last time?
Apologies, I was working on a performance and code boost, but something must have gone wrong.
Try to do a git reset --hard 72b481e717bf70eaf222bbd08340be33aac10bb9
This commit should work well, meanwhile I find time to fix everything.
== Rene
== Rene
fhwessels
Re: Testers wanted!
I did a git pull about 20 min ago and now I cannot log on to the system it just comes up with "Domictz Offline". Also did git reset.
- chimit
Re: Testers wanted!
Could you do a git pull again? I reverted to an older version until I have time to fix this.
fhwessels
Re: Testers wanted!
tells me that I "Already up-to-date" when I do git pull
Skerved
Re: Testers wanted!
Would like to test, but unable to send PM just yet.
- chimit
Re: Testers wanted!
All beta testers are advised to update to the latest commit. A separate email to you all will follow.
fhwessels
Re: Testers wanted!
Hi chimit I did a get pull and make an now I get this error;
Linking CXX executable domoticz
CMakeFiles/domoticz.dir/webserver/proxyclient.cpp.o: In function `http::server:: CProxyClient::CProxyClient(boost::asio::io_service&, boost::asio::ssl::context&, http::server::cWebem*)':
proxyclient.cpp:(.text+0x456c): undefined reference to `boost::atomics::detail:: lockpool::scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text+0x4578): undefined reference to `boost::atomics::detail:: lockpool::scoped_lock::~scoped_lock()'
proxyclient.cpp:(.text+0x45bc): undefined reference to `boost::atomics::detail:: lockpool::scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text+0x45c8): undefined reference to `boost::atomics::detail:: lockpool::scoped_lock::~scoped_lock()'
proxyclient.cpp:(.text+0x462c): undefined reference to `boost::atomics::detail:: lockpool::scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text+0x463c): undefined reference to `boost::atomics::detail:: lockpool::scoped_lock::~scoped_lock()'
proxyclient.cpp:(.text+0x4664): undefined reference to `boost::atomics::detail:: lockpool::scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text+0x4674): undefined reference to `boost::atomics::detail:: lockpool::scoped_lock::~scoped_lock()'
CMakeFiles/domoticz.dir/webserver/proxyclient.cpp.o: In function `boost::lockfre e::detail::freelist_stack<boost::lockfree::queue<ProxyPdu*, boost::parameter::vo id_, boost::parameter::void_, boost::parameter::void_>::node, std::allocator<boo st::lockfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, boost::parameter::void_>::node> >::~freelist_stack()':
proxyclient.cpp:(.text._ZN5boost8lockfree6detail14freelist_stackINS0_5queueIP8Pr oxyPduNS_9parameter5void_ES7_S7_E4nodeESaIS9_EED2Ev[_ZN5boost8lockfree6detail14f reelist_stackINS0_5queueIP8ProxyPduNS_9parameter5void_ES7_S7_E4nodeESaIS9_EED5Ev ]+0x14): undefined reference to `boost::atomics::detail::lockpool::scoped_lock:: scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree6detail14freelist_stackINS0_5queueIP8Pr oxyPduNS_9parameter5void_ES7_S7_E4nodeESaIS9_EED2Ev[_ZN5boost8lockfree6detail14f reelist_stackINS0_5queueIP8ProxyPduNS_9parameter5void_ES7_S7_E4nodeESaIS9_EED5Ev ]+0x20): undefined reference to `boost::atomics::detail::lockpool::scoped_lock:: ~scoped_lock()'
CMakeFiles/domoticz.dir/webserver/proxyclient.cpp.o: In function `boost::lockfre e::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, boost::par ameter::void_>::~queue()':
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 24): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::scop ed_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 30): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::~sco ped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 58): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::scop ed_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 64): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::~sco ped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 88): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::scop ed_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 98): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::~sco ped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x ec): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::scop ed_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x f8): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::~sco ped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 104): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::sco ped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 110): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::~sc oped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 158): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::sco ped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 164): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::~sc oped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 19c): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::sco ped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 1a8): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::~sc oped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 1b8): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::sco ped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 1c4): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::~sc oped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 1e4): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::sco ped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 1f0): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::~sc oped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 238): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::sco ped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 244): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::~sc oped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 250): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::sco ped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_ED2Ev[_ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5_S5_ED5Ev]+0x 25c): undefined reference to `boost::atomics::detail::lockpool::scoped_lock::~sc oped_lock()'
CMakeFiles/domoticz.dir/webserver/proxyclient.cpp.o: In function `boost::lockfre e::detail::freelist_stack<boost::lockfree::queue<ProxyPdu*, boost::parameter::vo id_, boost::parameter::void_, boost::parameter::void_>::node, std::allocator<boo st::lockfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, boost::parameter::void_>::node> >::deallocate_impl(boost::lockfree::queue<Proxy Pdu*, boost::parameter::void_, boost::parameter::void_, boost::parameter::void_> ::node*)':
proxyclient.cpp:(.text._ZN5boost8lockfree6detail14freelist_stackINS0_5queueIP8Pr oxyPduNS_9parameter5void_ES7_S7_E4nodeESaIS9_EE15deallocate_implEPS9_[boost::loc kfree::detail::freelist_stack<boost::lockfree::queue<ProxyPdu*, boost::parameter ::void_, boost::parameter::void_, boost::parameter::void_>::node, std::allocator <boost::lockfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::vo id_, boost::parameter::void_>::node> >::deallocate_impl(boost::lockfree::queue<P roxyPdu*, boost::parameter::void_, boost::parameter::void_, boost::parameter::vo id_>::node*)]+0x18): undefined reference to `boost::atomics::detail::lockpool::s coped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree6detail14freelist_stackINS0_5queueIP8Pr oxyPduNS_9parameter5void_ES7_S7_E4nodeESaIS9_EE15deallocate_implEPS9_[boost::loc kfree::detail::freelist_stack<boost::lockfree::queue<ProxyPdu*, boost::parameter ::void_, boost::parameter::void_, boost::parameter::void_>::node, std::allocator <boost::lockfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::vo id_, boost::parameter::void_>::node> >::deallocate_impl(boost::lockfree::queue<P roxyPdu*, boost::parameter::void_, boost::parameter::void_, boost::parameter::vo id_>::node*)]+0x24): undefined reference to `boost::atomics::detail::lockpool::s coped_lock::~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree6detail14freelist_stackINS0_5queueIP8Pr oxyPduNS_9parameter5void_ES7_S7_E4nodeESaIS9_EE15deallocate_implEPS9_[boost::loc kfree::detail::freelist_stack<boost::lockfree::queue<ProxyPdu*, boost::parameter ::void_, boost::parameter::void_, boost::parameter::void_>::node, std::allocator <boost::lockfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::vo id_, boost::parameter::void_>::node> >::deallocate_impl(boost::lockfree::queue<P roxyPdu*, boost::parameter::void_, boost::parameter::void_, boost::parameter::vo id_>::node*)]+0x9c): undefined reference to `boost::atomics::detail::lockpool::s coped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree6detail14freelist_stackINS0_5queueIP8Pr oxyPduNS_9parameter5void_ES7_S7_E4nodeESaIS9_EE15deallocate_implEPS9_[boost::loc kfree::detail::freelist_stack<boost::lockfree::queue<ProxyPdu*, boost::parameter ::void_, boost::parameter::void_, boost::parameter::void_>::node, std::allocator <boost::lockfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::vo id_, boost::parameter::void_>::node> >::deallocate_impl(boost::lockfree::queue<P roxyPdu*, boost::parameter::void_, boost::parameter::void_, boost::parameter::vo id_>::node*)]+0xc4): undefined reference to `boost::atomics::detail::lockpool::s coped_lock::~scoped_lock()'
CMakeFiles/domoticz.dir/webserver/proxyclient.cpp.o: In function `bool boost::lo ckfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, boost ::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*&)':
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E3popIS3_EEbRT_[bool boost::lockfree::queue<ProxyPdu*, boost::parameter::voi d_, boost::parameter::void_, boost::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*& )]+0x44): undefined reference to `boost::atomics::detail::lockpool::scoped_lock: :scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E3popIS3_EEbRT_[bool boost::lockfree::queue<ProxyPdu*, boost::parameter::voi d_, boost::parameter::void_, boost::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*& )]+0x50): undefined reference to `boost::atomics::detail::lockpool::scoped_lock: :~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E3popIS3_EEbRT_[bool boost::lockfree::queue<ProxyPdu*, boost::parameter::voi d_, boost::parameter::void_, boost::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*& )]+0x7c): undefined reference to `boost::atomics::detail::lockpool::scoped_lock: :scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E3popIS3_EEbRT_[bool boost::lockfree::queue<ProxyPdu*, boost::parameter::voi d_, boost::parameter::void_, boost::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*& )]+0x88): undefined reference to `boost::atomics::detail::lockpool::scoped_lock: :~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E3popIS3_EEbRT_[bool boost::lockfree::queue<ProxyPdu*, boost::parameter::voi d_, boost::parameter::void_, boost::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*& )]+0xb4): undefined reference to `boost::atomics::detail::lockpool::scoped_lock: :scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E3popIS3_EEbRT_[bool boost::lockfree::queue<ProxyPdu*, boost::parameter::voi d_, boost::parameter::void_, boost::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*& )]+0xc8): undefined reference to `boost::atomics::detail::lockpool::scoped_lock: :~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E3popIS3_EEbRT_[bool boost::lockfree::queue<ProxyPdu*, boost::parameter::voi d_, boost::parameter::void_, boost::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*& )]+0xf0): undefined reference to `boost::atomics::detail::lockpool::scoped_lock: :scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E3popIS3_EEbRT_[bool boost::lockfree::queue<ProxyPdu*, boost::parameter::voi d_, boost::parameter::void_, boost::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*& )]+0x104): undefined reference to `boost::atomics::detail::lockpool::scoped_lock ::~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E3popIS3_EEbRT_[bool boost::lockfree::queue<ProxyPdu*, boost::parameter::voi d_, boost::parameter::void_, boost::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*& )]+0x190): undefined reference to `boost::atomics::detail::lockpool::scoped_lock ::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E3popIS3_EEbRT_[bool boost::lockfree::queue<ProxyPdu*, boost::parameter::voi d_, boost::parameter::void_, boost::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*& )]+0x1b8): undefined reference to `boost::atomics::detail::lockpool::scoped_lock ::~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E3popIS3_EEbRT_[bool boost::lockfree::queue<ProxyPdu*, boost::parameter::voi d_, boost::parameter::void_, boost::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*& )]+0x238): undefined reference to `boost::atomics::detail::lockpool::scoped_lock ::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E3popIS3_EEbRT_[bool boost::lockfree::queue<ProxyPdu*, boost::parameter::voi d_, boost::parameter::void_, boost::parameter::void_>::pop<ProxyPdu*>(ProxyPdu*& )]+0x254): undefined reference to `boost::atomics::detail::lockpool::scoped_lock ::~scoped_lock()'
CMakeFiles/domoticz.dir/webserver/proxyclient.cpp.o: In function `boost::lockfre e::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, boost::par ameter::void_>::node* boost::lockfree::detail::freelist_stack<boost::lockfree::q ueue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, boost::paramet er::void_>::node, std::allocator<boost::lockfree::queue<ProxyPdu*, boost::parame ter::void_, boost::parameter::void_, boost::parameter::void_>::node> >::allocate _impl<false>()':
proxyclient.cpp:(.text._ZN5boost8lockfree6detail14freelist_stackINS0_5queueIP8Pr oxyPduNS_9parameter5void_ES7_S7_E4nodeESaIS9_EE13allocate_implILb0EEEPS9_v[boost ::lockfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, b oost::parameter::void_>::node* boost::lockfree::detail::freelist_stack<boost::lo ckfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, boost ::parameter::void_>::node, std::allocator<boost::lockfree::queue<ProxyPdu*, boos t::parameter::void_, boost::parameter::void_, boost::parameter::void_>::node> >: :allocate_impl<false>()]+0x14): undefined reference to `boost::atomics::detail:: lockpool::scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree6detail14freelist_stackINS0_5queueIP8Pr oxyPduNS_9parameter5void_ES7_S7_E4nodeESaIS9_EE13allocate_implILb0EEEPS9_v[boost ::lockfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, b oost::parameter::void_>::node* boost::lockfree::detail::freelist_stack<boost::lo ckfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, boost ::parameter::void_>::node, std::allocator<boost::lockfree::queue<ProxyPdu*, boos t::parameter::void_, boost::parameter::void_, boost::parameter::void_>::node> >: :allocate_impl<false>()]+0x20): undefined reference to `boost::atomics::detail:: lockpool::scoped_lock::~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree6detail14freelist_stackINS0_5queueIP8Pr oxyPduNS_9parameter5void_ES7_S7_E4nodeESaIS9_EE13allocate_implILb0EEEPS9_v[boost ::lockfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, b oost::parameter::void_>::node* boost::lockfree::detail::freelist_stack<boost::lo ckfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, boost ::parameter::void_>::node, std::allocator<boost::lockfree::queue<ProxyPdu*, boos t::parameter::void_, boost::parameter::void_, boost::parameter::void_>::node> >: :allocate_impl<false>()]+0x90): undefined reference to `boost::atomics::detail:: lockpool::scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree6detail14freelist_stackINS0_5queueIP8Pr oxyPduNS_9parameter5void_ES7_S7_E4nodeESaIS9_EE13allocate_implILb0EEEPS9_v[boost ::lockfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, b oost::parameter::void_>::node* boost::lockfree::detail::freelist_stack<boost::lo ckfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, boost ::parameter::void_>::node, std::allocator<boost::lockfree::queue<ProxyPdu*, boos t::parameter::void_, boost::parameter::void_, boost::parameter::void_>::node> >: :allocate_impl<false>()]+0xb4): undefined reference to `boost::atomics::detail:: lockpool::scoped_lock::~scoped_lock()'
CMakeFiles/domoticz.dir/webserver/proxyclient.cpp.o: In function `bool boost::lo ckfree::queue<ProxyPdu*, boost::parameter::void_, boost::parameter::void_, boost ::parameter::void_>::do_push<false>(ProxyPdu* const&)':
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x58): undefined reference to `boost::atomics::detail::lockpool: :scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x68): undefined reference to `boost::atomics::detail::lockpool: :scoped_lock::~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0xbc): undefined reference to `boost::atomics::detail::lockpool: :scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0xcc): undefined reference to `boost::atomics::detail::lockpool: :scoped_lock::~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x108): undefined reference to `boost::atomics::detail::lockpool ::scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x118): undefined reference to `boost::atomics::detail::lockpool ::scoped_lock::~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x144): undefined reference to `boost::atomics::detail::lockpool ::scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x150): undefined reference to `boost::atomics::detail::lockpool ::scoped_lock::~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x17c): undefined reference to `boost::atomics::detail::lockpool ::scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x18c): undefined reference to `boost::atomics::detail::lockpool ::scoped_lock::~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x1fc): undefined reference to `boost::atomics::detail::lockpool ::scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x21c): undefined reference to `boost::atomics::detail::lockpool ::scoped_lock::~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x280): undefined reference to `boost::atomics::detail::lockpool ::scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x2a4): undefined reference to `boost::atomics::detail::lockpool ::scoped_lock::~scoped_lock()'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x30c): undefined reference to `boost::atomics::detail::lockpool ::scoped_lock::scoped_lock(void const volatile*)'
proxyclient.cpp:(.text._ZN5boost8lockfree5queueIP8ProxyPduNS_9parameter5void_ES5 _S5_E7do_pushILb0EEEbRKS3_[bool boost::lockfree::queue<ProxyPdu*, boost::paramet er::void_, boost::parameter::void_, boost::parameter::void_>::do_push<false>(Pro xyPdu* const&)]+0x32c): undefined reference to `boost::atomics::detail::lockpool ::scoped_lock::~scoped_lock()'
collect2: ld returned 1 exit status
CMakeFiles/domoticz.dir/build.make:3550: recipe for target 'domoticz' failed
make[2]: *** [domoticz] Error 1
CMakeFiles/Makefile2:64: recipe for target 'CMakeFiles/domoticz.dir/all' failed
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
Makefile:133: recipe for target 'all' failed
make: *** [all] Error 2
Users browsing this forum: cmisip and 1 guest
