Wall Mount Touchscreen - Show Your Designs
- 1bigwink
I've read with interest numerous posts on here about wall mount touchscreens. I'm looking for a similar 'permanently on' fixed solution but run the cables through the back of the wall into a cupboard behind. The drawback of all the 'tablet on the wall' solutions I have seen is that they tend to have side mounted power sockets, so inevitably you see a cable. Covering the tablet with a custom wooden frame means there's a large gap behind the frame and embedding the tablet into the wall is a significant amount of work (particularly if like me your walls are flint cob!). The Pi official touchscreen looks good and a nice low profile, but it's £60 just for the screen and the supplied lead isn't long enough to go through our cavity wall.
Has anyone managed to find an affordable 'low profile' solution for a wall mounted controller where the cables are fully hidden and that doesn't require half the wall to be knocked out to get a nice low profile finish!? I'd be interested to see any designs that anyone has! For me I'd like the screen to be 'always on' (albeit dimmed when not in use) - so powering from USB is a must (which is a problem for some tablets, as the chargers are unable to charge the battery quick enough to maintain the screen and wifi). I'll be using it with the fantastic frontpage.html.
1x RasPi, RFXtrx433e, v5 Aeon ZWave, MD210R Door Contacts, MC335R PIRs, MD326 Siren, 25 x MiLight RGBW Bulb (4 x WiFi Contoller), 12 IP Cam, Fibaro FGS221, 5x433mhz venetian blind, 433mhz TV ceiling lift.
Next: Touchscreen + frontpage.html
Evelen
- Domoticz version: 2.4538
Re: Wall Mount Touchscreen - Show Your Designs
My setup, no frame, just a tablet
- bizziebis
- Domoticz version: 3.8805
If you are going to use a dedicated tablet for the job you could remove the back cover, solder wires directly to the USB connector and feed them tru a hole that you drill in the cover. You won't see any wires
raym
Nice! Can you recommend an android tablet which allows the back cover to be removed?
jjnj
If you still have a nexus 7 2012 laying around, that one is very easy. But almost all other tablet have removable backs. They need to be repaired
peterk
In a totally different application (flight computer in a glider plane) I use a Nexus 7 tablet.
This tablet (and several others) can be charged with a with a wireless charger (also called QI charger).
I have bought such a charger from dealextreme.com for about $10. Search for "QI Charger".
When you remove the plastic housing you are left small coil and a small printed circuit board.
This coil and pcb, I've crafted in the tablet holder in my plane. They need only a few mm's space behind the tablet.
In this way you can mount a tablet against a wall, and make the wiring competely invisible, because the tablet's USB connector is no longer used.
By the way, i.e. the coil and pcb can also be found as a set of separate components.
Domoticz V2.3530 on RPi 2B, P1 Smart Meter, OpenTherm gateway, RFXtrx433 (KiKa, temp sensors)
- bbqkees
- Domoticz version: 4.1x
For a friend I did something similar.peterk wrote: By the way, i.e. the coil and pcb can also be found as a set of separate components.
You can buy general QI stickers with a micro USB plug on one end.
(Look on ebay for 'usb qi charging sticker').
So you just stick it to the rear of the tablet and connect the UB plug.
Then you position a 4 Euro QI charger pad from Ebay behind it on the wall mount and this way you can remove the tablet at wish and there are no wires visible (as long as you can hide the charger cable).
deennoo
Mine is a HPtouchpad and Touchstone charger, running Domoticz on Linux Déploy + Rflink Wifi
Front end is Vil1driver custom page, with personal mod.
http://domo-attitude.fr
thebeetleuk
I'm trying to do the same thing. and I agree, power is the pain. At the moment I'm trying to find the most discrete way of adding in the power without an ugly connector hanging out of the side. The only thing I can think of at the moment is to make my own cable that only sticks out a reaaallllly short distance. Let us know what you come up with!1bigwink wrote:Hi all,
My Setup: Pi, RFXtrx433, HomeEasy: 13 Dimmers & 4 Sockets, 2 motion-sensors, 3 magnetic switches, 1 OWL Electricity Sensor, 3 Oregon Temp Sensor.
tomeaton
The biggest issue I'm having is finding a suitable interface!
thebeetleuk
What have you tried?
tomeaton
Original, flatz, dashticz, myphpdomo so far. Mostly ok but none quite right. Can't put my finger on why.
thebeetleuk
What about imperihome? From what I can tell so far it looks great.
tomeaton
I'll give it a try. I liked the others but the fact that they don't use all the available screen space bugs me.
deennoo
Try vil1driver custom page, works like a charme, and fully customable.
To get it on full screen with Android, go on chrome, menu, add to desktop.
ArieKanarie
A great kick for this topicbizziebis wrote:If you are going to use a dedicated tablet for the job you could remove the back cover, solder wires directly to the USB connector and feed them tru a hole that you drill in the cover. You won't see any wires
The solution for the power is clear, but I was curious how you mounted the tablet itself to the wall?
- Lectere
I bought one of these cheap square qi chargers and put two stripes of velcro (klittenband) on the qi charger and the tablet. Drill a hole in the cheap qi charger to hide the cables. Big advantage of this approach is that you don't see any wires and you could take of the tablet to program it on the couch.
Effictent and redundant two-factor authentication? http://www.smspassword.com
