LUA - can't get Nightmode script to run
thorbj
Post by thorbj »
I have this script for turning off all lights when we have gone to bed. But I'm struggeling to get it to work.
It's supposed to check if one of three lamps are ON and motion, TV and an override-switch is off. Then if time is between 10PM and 6AM, it will activate a scene that turns off all lights. But this never happens.
I have checked that the scene works, and I've added a notification to the scene so that I get a message via Telegram if the scene is activated. That way I know that the scene is never activated by the script.
It would be great if someone could spare some precious time and check for errors or faults in my script:
-- ~/domoticz/scripts/lua/script_time_nightmode.lua
-- Function for calculating time
 function timedifference (s)
    year = string.sub(s, 1, 4)
    month = string.sub(s, 6, 7)
    day = string.sub(s, 9, 10)
    hour = string.sub(s, 12, 13)
    t1 = os.time()
    return difference
 time = os.date("*t")
-- SETTINGS --
local motion_switch = 'Bevegelse Stue' -- name of the motion switch
local lamp_switch = 'Dimmer stue sør' -- name of a lamp that this script should depend on
local lamp_switch2 = 'Oslo Wood' -- name of a lamp that this script should depend on
local lamp_switch3 = 'AJ Lampe' -- name of a lamp that this script should depend on
local media_device = 'Chromecast' -- name of a media device like Chromecast or TV.
local override_switch = 'Overstyr' -- Switch for activating system override
-- END SETTINGS --
-- Define hours for day and evening lights
h = tonumber((os.date('%H')))
if     (h >= 22 or h < 6)
   then
   x = 'Scene:Night'
   g = '(<b>Natt</b>)<font color="red">No movement in the livingroom and the TV is off. switching off lights...</font>)'
   i = '<font color="green">GOOD NIGHT!</font>'
   x = 'Not night'
-- Issue command "x" if motion_switch, media_device and override_switch is off after 10PM.
if    (otherdevices[lampswitch] == 'On' and otherdevices[motion_switch] == 'Off' and otherdevices[media_device] == 'Off' and otherdevices[override_switch] == 'Off' or otherdevices[lampswitch2] == 'On' and otherdevices[motion_switch] == 'Off' and otherdevices[media_device] == 'Off' and otherdevices[override_switch] == 'Off' or otherdevices[lampswitch3] == 'On' and otherdevices[motion_switch] == 'Off' and otherdevices[media_device] == 'Off' and otherdevices[override_switch] == 'Off') then
   print(g)
   commandArray[x]='On'
   print(i)
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
JuanUil
Domoticz version: 4.11083
Re: LUA - can't get Nightmode script to run
Post by JuanUil »
You should place the or functions between brackets ()
F. e.
if (device and device or (device and device))
succes
Jan
thorbj
Post by thorbj »
So I should change line 45 to this?
if    ((otherdevices[lampswitch] == 'On' and otherdevices[motion_switch] == 'Off' and otherdevices[media_device] == 'Off' and otherdevices[override_switch] == 'Off') or (otherdevices[lampswitch2] == 'On' and otherdevices[motion_switch] == 'Off' and otherdevices[media_device] == 'Off' and otherdevices[override_switch] == 'Off') or (otherdevices[lampswitch3] == 'On' and otherdevices[motion_switch] == 'Off' and otherdevices[media_device] == 'Off' and otherdevices[override_switch] == 'Off')) then
JuanUil
Post by JuanUil »
yes you should
success!
