Just wondering if someone could give me a few hints to start to develop a hardware plugin. I know it's to much work to explain the whole procedure, but I could at least start to try to understand an already existing hardware plugin that's able to read ASCII output of a device. Which plugin is good example to start with, is that maybe the P1Meter plugin? Which cpp file is the correct file to read, maybe P1MeterBase.cpp? Any other tips that are helpful to get me started?
The hardware I'm trying to develop for is a Alphatronic Visonic Wireless Interface (868,95 Mhz), it can receive signals from a Visonic alarm sensors. The device is connected to a raspberry via a serial to USB PL2303 interface. The output of the device is pretty simple, as is visible below, just plain vanilla ASCII output each time a response is received from one the sensors. In addition, the format is always the same.
Each response from a sensor can be transcoded as follows:
- P is message from a powercode sensor, K is from a keyfob
- the 8 numbers is an unique identifier for each sensor
- then bit 7 and 6 are never used (always a dot)
- bit 5, s, supervision messages
- bit 4, r, restore, e.g when a door sensor is put back on normal state (door closes)
- bit 3, low battery, when a B is displayed the battery power it to low
- bit 2, supervision, T a supervision timer
- bit 1, Alarm, when A a sensor is activated, PIR or door sensor
- bit 0, Sabotage, when S a sensor is opened
- @123, signal strength (a value between 20 and 130, 30 is weak but acceptable, 90 and above is a strong signal.
Output from my raspberry below....
pi@raspberrypi /dev $ screen ttyUSB0
#P14933113:..s.T...@060
#P14933113:..s.T...@061
#P10100117:..sR....@058
#P13865205:..s.T...@106
#P08776324:..sRT...@013
#P08776324:..sRT...@014
#P08776404:..sRT...@059
#P08776404:..sRT...@058
#P13850765:..s.T...@016
#P13865290:..s.T...@103
#P14933170:..s.T...@028
#P14933158:..s..B..@029
#P14933158:..s..B..@030
#P14933166:..s.T...@035
#P14933153:..s.T...@037
#P07553292:..s.T...@080
#P07738788:..sRT...@064
#P07738788:..sRT...@063
Some tips to develop a hardware plugin (visonic receiver)
- Dnpwwo
Re: Some tips to develop a hardware plugin (visonic receiver
I followed this guide: http://www.domoticz.com/wiki/Developing ... are_plugin
It seemed to cover off all the fundamentals. Good luck.
MichelHardonk
Hi Holland,
I have basically the same setup which I want to use (Alphatronic Visonic Wireless Interface (868,95 Mhz)) on my Raspberry PI with Domoticz software, however I am not at all skilled in programming (I am an electronics engineer).
So I am very interested in your development of the hardware plugin. Did you make any progress with it?
Michel
Michel
djgodlike
Re: Some tips to develop a hardware plugin (visonic receiver)
Hi Holland,
Thats a good idea! Did you make it work?
Keep up the good work!
Aeon Labs Gen5 USB
Greenwave Powernode 6 NS310
2x Greenwave Powernode 1 NS310
Philips Hue
Logitech media Server
Plugwise Smile P1
Philips Hue
Plugwise Smile P1
b_weijenberg
- Target OS: -
The RFXtrx868X supports also Visonic PowerCode sensors and is supported by Domoticz already.
A limited number of RFXtrx868X prototypes can be produced if enough users are interested.
Contact rfxcom.
Contact rfxcom.
RFX-433, RFX-433EMC, RFX-868
tiele004
- Domoticz version: 2.3530
I'm really curious if you got some results already. I also have the Powercode receiver and wouldn't like to buy aditional hardware. Could you please give us an update?
Holland
- Domoticz version: Beta Ch
Currently using the RFXtrx868X and it works reliable with Visonic. I would advice to let go the Alphatronic powercode receiver (assuming that you have that one), I don't think it will be integrated into domoticz
Users browsing this forum: willemd and 1 guest
