On the temperature tab i can see the linegraphs but
- Switches
- Fritzbox calls
- Smoke devices
Shows only "No data available in table"
I can't see any logs, there are no on/off records, nothing.... the logs stay empty for weeks
I did a power-off, reboot, restored an older database but it does not change
I use a Raspberry-PI-2B with Domoticz Version: 2.3530, Build Hash: 9eef872, Compile Date: 2015-11-01 11:41:18
Logs: "No data available in table"
- Domoticz version: 3.5837
Re: Logs: "No data available in table"
I'm having the same problem
Can anybody help?
Thank
Can anybody help?
Thank
Did you fix this problem?
I cant see the report logs for power...
The dashboard tells me that i am consuming so the date is available somehwere.
