Smart PIR Script Lua
Have tried some of the scripts here and can get the PIR light one to work with some success:-
https://www.domoticz.com/wiki/Smart_Lua_Scripts
My problem is that there is a script to switch the light on at certain times of the day (which works) but doesn't switch it off.
There is another that will switch on and off regardless of the time of day (which works) but what I want is a script that will turn on at certain times of the day and then turn off after x minutes of no PIR activity.
Can anyone help?
Edit - The log says the light is turned off, but domoticz switches panel says it is not. Light is lightwaverf with feedback.
Can anyone help?
Raspberry Pi2, RTX433e USB, Philips Hue, Nest, LightwaveRF.
- jvdz
- Domoticz version: 4.107
Re: Smart PIR Script Lua
I would help when you show the script that is not working correctly so we can see what might be going wrong.
Jos
Jos
Sorry, I put a link to the wiki page that had the script.
The script above switched on the light, but never switches it off (although the log says it does). The txt description for the script says that "The device script is purely concerned with turning the light on and so does not need to worry about the parameter which determines when to turn the light off. For "PIRxyzStudy", after the "PIR" in the name: x specifies what times of day to turn the light on so replace x with a for all day, d for daytime, n for nighttime and 1 for a custom time, any other letter will stop the light being turned on at all, while this may seem silly, in fact it is useful if you just want to stop room lights being left on unnecessarily. y specifies whether it is a single device or group of devices, with r being a single Domoticz switch and g being a Domoticz Group."
However why have a variable for how long the light has to stay on if it never acts upon it?
-- ~/domoticz/scripts/lua/script_device_pirs.lua
-- Each of the motion sensors in Domoticz follow this name convention:
-- PIRxrzSwitchName or PIRxgzGroupName
-- x speicifies when the PIR controls - a=all day, n=nighttime, d=daytime,
-- 1=custom timer 1 set to 22:00 to 07:30
-- y specifies what the PIR is controlling -
-- r = room (single Domoticz) switch and g = group
-- z specifies how long the ligth will stay on for in minutes, so z = 5 turns
-- the switch or the group on for 5 minutes
-- N.B. be carefully as currently there is little error checking so wrongly
-- named PIRs in Domoticz may cause an error
-- N.B. one wrongly named PIR may stop the script, check log for any issues
function customtest(nowhours, nowmins, starthours, startmins, endhours, endmins)
nowmins = nowmins + (nowhours * 60)
startmins = startmins + (starthours * 60)
endmins = endmins + (endhours * 60)
if (startmins > endmins) then
-- spans midnight
if ((nowmins >= startmins) or (nowmins <= endmins)) then
return true
return false
-- doesn't span midnight
if ((nowmins >= startmins) and (nowmins <= endmins)) then
return true
return false
function timetest(opertime)
if opertime == "a" then
return true
if opertime == "n" then
if timeofday['Nighttime'] then
return true
return false
if opertime == "d" then
if timeofday['Daytime'] then
return true
return false
if opertime == "1" then
time = os.date("*t")
return customtest(time.hour, time.min, 22, 0, 7, 30)
return false
tc=next(devicechanged)
v=tostring(tc)
if (v:sub(1,3) == 'PIR') then
if timetest(v:sub(4,4)) then
c=v:sub(7)
if v:sub(5,5) == "g" then
c="Group:"..c
commandArray[c] = 'On'
tmess = c..' On - time 0'
print(tmess)
Will try. However the issue is it never switches off, not a problem switching on.
Sorry, i misread your post.frizby66 wrote:Will try. However the issue is it never switches off, not a problem switching on.
In your script i do not see a commandArray[c] = 'Off' command, so that the light stays On is what you can expect
- jvdz
The script you posted is only switching lights On and there is a second script to switch them Off, when I understand the WiKi correctly.
Jos
Jos
Hi Jos, yes you are 100% right. Needed both scripts copied over.
Got it working a treat, but trying to do something different. I only want the lights to switch on between sunset and 22:00 (have dogs and don't want them turning the light on when we are sleeping). Any thoughts on how to edit the line:-
Fraser
return true
- Domoticz version: 3.8807
As a hack you could do:frizby66 wrote:Hi Jos, yes you are 100% right. Needed both scripts copied over.
FraserCode: Select all
if opertime == "n" then if timeofday['Nighttime'] then return true
if timeofday['Nighttime'] and time.hour < 22 then
return true
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
Got a more pressing issue with PIR and light control.
I am using HE-108 switch (Home Easy / Byron) 433 switch. Works a treat in Domoticz but these dimmers have a feature which makes them cycle through their dimmer levels if you send a second "On" command (this feature is used to set the dimmer level buy pressing "On" on Home Easy remote to start the cycle then press "On" again to stop at the desired level).
Problem I have is that every time the PIR detects movement, the script sends the "On" command and so the light starts to cycle up and down!
Any ideas of a work around? Rather than the script sending the "On" command every time the PIR detects movement, could the script check the state of the light in Domoticz and only send the "On" when it detects that the light is "Off"?
The script is designed to be general, so the workaround may have some catches I suspect, for example I am not sure whether groups respond with whether they are on or off, having said that the workaround should be easy enough, basically just check the status.frizby66 wrote:Got a more pressing issue with PIR and light control.
The code currently looks like this in script_device_pirs.lua:
v=tostring(tc)
c=v:sub(7)
c="Group:"..c
print(tmess)
v=tostring(tc)
c=v:sub(7)
c="Group:"..c
-- Only switch light / group on if it is currently off
if otherdevices[c] == 'Off' then
print(tmess)
Thanks Simon, will give it a try tonight and let you know.
BTW, found a reasonable supplier on ebay for the HE stuff. Will put a link on the main forum http://stores.ebay.co.uk/halx-home-automation?
Worked a treat Simon
Got another question about the script and trying to refine it.
Have some lights set to switch on when it is "Nightime", which works great, but wondered if there was a way of extending Nightime to be and hour before sunset and an hour after sunrise. There is a period of the day where is is dark but not technically nightime (hope that make sense)!
