Transfer primary from Aeon Labs S2 to Aeon Labs Gen5 - How ?
- Domoticz version: Latest
I have an S2 stick which is not working very well so I decided to Switch to the Aeon Labs Gen 5.
I am trying like **** but no success to transfer the primary. It crashes Domoticzs under the Raspberry Pi2.
Has anyone acheived this ? Any support would be appreciated !
Sam
Sam
- bbqkees
- Domoticz version: 4.1x
Re: Transfer primary from Aeon Labs S2 to Aeon Labs Gen5 - H
Domoticz can only use one ZWave stick at the same time.
You have to start over from scratch.
Thanks for your info.
I have 2 Raspberry Pi2 with Domoticz so it should work no ?
Is there a procedure I could follow ?
Sam
Sam
Lucky me !!!
I got this sh**y Vera Edge with all my Z-Wave setting and as I really don't like it and left it in a box.
BUT, the great thing of Vera Edge is that you can easily backup your Z-Wave network and restore it when you want. This is what you cannot do with Aeon Labs S2 or Gen-5....
So I got that Vera Edge, reinstall it all and the box became Primary. On the tool, you have an option to transfer the Primary to another controller and in Domoticz you have "receive" information from other controller.
AND IT WORKS. I am back to an Aeon Labs Gen 5 Primary with all working
I will post a question in a new post which is "How to get the most stable network, have enable backup and can restore a Z-Wave network" ?
- EdddieN
- Domoticz version: 4.9700
Re: Transfer primary from Aeon Labs S2 to Aeon Labs Gen5 - How ?
Hello there,
I just transferred from a Razzberry card on a RPI_A to a USB stick on a RPI_B. All seems to be working fine and can see/control all the devices... but how do I know that the new one (usb stick) is the primary?
If I look at the tables, I have the old controller as id 1 and the new one as id 63, do they need to change? if I look under control panel (z-wave), both show as slaves
11101101 - www.machinon.com
- EdddieN
Ok, a reboot fixed it
- gizmocuz
I think domoticz also supplies the option the transfer to a new primary controller.
These options are from the OZW setup dropdown.
You need two domoticz instances... maybe one on a raspberry, the other on windows...
Never tried it, but very interesting to know if that works indeed
That actually makes me thinking: would it be possible to have 2 controllers managing the same network? (1 primary on domoticz instance A and a slave controller on domoticz instance B?)gizmocuz wrote:I think domoticz also supplies the option the transfer to a new primary controller.
That would be great to make a redundant setup
Connected to:
-Pi3; Aeon Labs Z-Stick; Fibaro Switches, Roller Shutter and Motion Sensors; Qubino Dimmers; P1 Port + Youless, MiLight; HUE Bridge; Forest shuttle Z-Wave; RFLink + KAKU; Voltcraft CO20; Everspring floodsensors; GreenWave PN-6; NEO Sensors
- gizmocuz
No, and i also think that you can not use two controllers with OZW on the same machine.
OK thanks Gizmocuz... so that was a wishful thinking scenario
Anyway...I'm also interested if anyone is able to transfer the configuration of their primary device to a new Gen5 stick using 2 Domoticz instances.... I still have an old version here and would like to replace it, but that's too much much work if I need to exclude and include each device again.
Connected to:
I tried but could not get it working. I excluded everything and included 10 devices in max 15 minutes.
- EdddieN
Yes it did!gizmocuz wrote:I think domoticz also supplies the option the transfer to a new primary controller.
I had two RPI3s, one running Razzberry (old primary) and one Gen5 stick (new primary).
When I did the transfer both showed slave under OZW control panel. The I rebooted the new primary and it appeared as primary.
As for the z wave results: all mains powered devices perfect. The battery ones I lost them all, they are there but not reporting so probably need to re-add again.
In general my experience with batttery operated z-wave devices has been very mixed with razzberry. Let's see with Gen5
- EdddieN
Ok, just to add up a bit.
Re-adding the battery operated devices didn't work so I had to exclude them (which curiously enough were detected) and re-include them. My gut feeling here is that it was not something particular to the OZW or Domoticz but my own network as the previous install was my first ever attempt to this.
- Domoticz version: Stable
Hi guys,
This is an old article, but in my opinion inconclusive. Also because i tried it and and could not get it working as described here. Good news i got it working and want to share how i did it.
Considerations:
When changing the stick basically works, consider why you want to do this. Your devices (in the device tab) will be lost, although the Zwave network can be transferred. Also the Zwave node numbers stay the same. Can be my procedure, but got it working. Below in my explanation there can be an option to test if devices lost is avoidable.
My Setup:
2 Raspberry's and an Windows PC. An G2 Aeon stick and an G5.
What i did:
First you need to add the new Zwave (G5) stick to your existing zwave network. Whatever i did, i could not get it to work with Domoticz.
Therefore i downloaded Zensys Tools. G5 stick in the windows PC with Zensys tools and the G2 stick in my hand.
Pressing the inclusion button in Zensys and 1 short tap on the G2 stick resulted in adding the G5 in the G2 network.
Check if this worked:
Checked this with setting up the network, with 2 sticks in 2 separate Domoticx Instances.
The Zwave device list is seen and after a while all devices are correct reported.
Transfer role:
Now to transfer the Primary role from the G2 stick to the G5 stick. Also in Domoticz i couldn't get it to work.
Running the G5 stick in Zensys tools and the G2 stick on a Pi with Domoticz, i could set the stick via Zensys in receiving mode and Domoticz in transfer Primary mode.
Thanks for reading!
Arthur
Activating the G5 stick
After this i powered down the Pi, switched sticks and powered up my Pi. I added the new stick as new hardware. ** This is why my devices where lost. I do not know it this is avoidable by adding the stick as the old stick. And i was to fast with deleting the old devices in the device list.
The Node numbers in the Zwave console remain the same, so sorting out which device is which is doable.
Considerations:
My Setup:
What i did:
Transfer role:
Thanks for reading!
Arthur
Pi 3B, latest stable
RFXCOM, Z-wave, Zigate, Hue, Harmony hub, Netatmo Weather station, Opentherm Gateway, EnOcean,P1 SmartMeter, Plugwise Anna & Adam, Xiaomi Roborock, Sonos One, Google Home, Philips Hue, Homey, D-link and Bitron Video camera.
- emme
- Domoticz version: latest
Use ZenSys Tool from Aeotec and a Windows PC to transfer role from a stick to another
unfortunately the utility seems to be no longer unavailable as it's arrived to its EOL....
I should have a copy somewhere.... i fyou still need it I can provide it somehow
M
P.S.
here's a working link....
https://www.symcon.de/forum/attachment. ... 1373548171
..could it be possible to include such tool in the Official Wiki page?
M
P.S.
"We always done this way"
- C4rtm4N
I'm about to try this using Zensys. Has anyone managed to do it using the method @ahattink described without losing their devices?
- gizmocuz
You could try my method described here on "Tue Aug 01, 2017 1:28 pm"
Seems to have worked for Eddy, seems also a logical step to perform
- C4rtm4N
I plan on using the OZW control panel to transfer the primary to a zstick v5 that I have added to my network using zentools (which I used to add it into receive mode) so in essence I think that it's doing the same thing. My worry is that when I swap that stick onto my Pi it won't recognise it and I'll need to add it as new hardware, causing all of the devices to be lost as happened with ahattink.
I tried to add it to the same usb port of the Pi instead of the v2 zstick without transferring the primary but it didn't recognise it.
- gizmocuz
It should recognize it.. it's just a USB device
- C4rtm4N
Okay, so it's done but I'm confused.
Firstly, my PI did recognise the S5 stick, I just didn't realise that /dev/ttyACM0 is actually USB as well as ttyUSB0. The S2 stick showed as the latter, the S5 as the former. All I had to do was swap the s2 stick to Windows, change the serial port for the OZW hardware on my PI and it retained all of my devices for my new S5 stick
Transferring the primary role got no kind of acknowledgement so I span up another copy of Domoticz on my PC and tried again. Still no acknowledgement but then I noticed this in the OZW control panel.
My S2 stick showed SUC as the controller mode and 1 in the SUC Node but as far as I can remember it's always said this. Anyway I disabled OZW on the Windows copy of Domoticz and rebooted my PI.
This is what I've been met with. My new controller is node 32 and the old S2 one is node 1. What is strange is that the S2 stick isn't plugged in anywhere so I don't understand why it's showing as having any connections live. Could it still be communicating even though it's sat on my desk with no light lit?
Finally, will having no SUC node matter? this link seems to recommend it but I have no idea how to enable it via the OZW control panel.
