Aeon Labs DSD31 siren
strebor
- Domoticz version: 8007
Hi all, I'm new to Domoticz, Z-Wave, and Razberry and Raspberry Pi.
I have a test set up of a couple of flood detectors and a plug in switch. The Raspberry Pi/Razberry controller is doing it's stuff and thus I will be adding some events to poke the Aeon Labs DSD31 siren, when it arrives from the supplier.
As an unsupported (?) device what steps should I be taking to get Open-Z-Wave and Domoticz to control the siren?
I have found an xml scheme on pepper and added that to ..domoticz/Config/aeon_labs as siren.xml
what now ?
Cordialement Strebor
what now ?
Jasper
Re: Aeon Labs DSD31 siren
I just bought this siren and would also love to see some support on this.
Do you think it will be supported in the near future?
Jasper
No progress what so ever...
Still hoping for someone with the right knowledge of it all to present himself and be my all time hero.
Jasper
Anyone?
190 views noone who could help in order to make some progress here? :S ?
mdu
With the newest version I am able to turn the Siron On and of but I prefer to controll the volume and the type of sound. Jasper did you allready manage to get it working in Domoticz? If yes can you please describe what you did?
mdu
Can anyone answer?
strebor
After the gift of DUTs by Aeon Labs it seems that the siren is now supported.
I don't speak GIT ( as one possibly at times ) so I'm not 100% sure, perhaps somebody fluent in developer could interpret the banter on the OZW site for me please.
Strebor
Strebor
Jasper
With the newest version i'm also able to get the siren on and off.
Although the settings are in place for further tuning, manipulating these settings doesn't give me a different result in type of sound and volume.
strebor
As Jasper has written the Siren is now supported> ver 2.2563.
I have linked the siren to a detector and this will trigger the siren from the events script.
Now I would like to change volume and tone from within the script, passing decimal value doesn't work as the boolean 'on' does.
I can choose a default value from the devices menu but that's not per event.
Anybody know how I do this from within the event or external script for that matter?
Strebor
Strebor
u01pei
Hello DSD31 owners,
I am thinking about buying the same sirene. However I would like to know if I can control the sirene as if it was a light (or any switch for that matter).
Or does this Sirene more or less function like a smoke detector, which I can not turn on or off?
I hope some of you DSD31 owners can help me before I purchase this device.
Kind regards, Jeroen
mfranken
Hi Jeroen,
I just bought one, simple installation and 1 device shows up that you can switch (on/off)
u01pei wrote:Hello DSD31 owners,
Raspberry, RFX, Zwave, JeeNodes, MySensors, OTGW, Domotix iPhone App
- Marq
I was able to include this device in the network, and set the parameters (incl. volume and tone) in the hardware setup.
However I am not able to choose volume/tone by blocky or lua events.
In the overview of devices, it shows as an On/Off device. And not a multilevel device as would be expected.
(looking at the log when including the device, it says 'CommandClass: SWITCH BINARY')
strebor
Marq,
This script was posted by SilentNL in the tracker so I paste it here:
-- This script change a value of a Zwave (alarm) device. And after that it activates the Zwave (alarm) device. So it can be triggered in a Event.
-- How to:
-- Create a virtual on/off device
-- This script has to be named like the the new virtual device in the folder: ~/domoticz/scripts/lua for example "script_device_BeNext-Alarm-Sound-02.lua"
-- With the following command you can get the Zwave device information: "curl 'http://localhost:8080/json.htm?type=ope ... odes&idx=2'"
-- (2 = The Zwave device number, that you can find Setup --> Hardware)
-- With the following command you can test a Zwave config change: "curl 'http://localhost:8080/ozwcp/valuepost.html' --data '39-CONFIGURATION-config-byte-1-7=3' -v"
-- (39 = device index, 7 = index, 3 = value you want to set)
local VirtualDevice = 'BeNext-Alarm-Sound-02' -- Name of your new Virtual Device Name.
local AlarmDevice = 'BeNext Alarm Sound' -- Name of the Zwave (alarm) device.
local nodeID = ('39') -- nodeID of the Zwave (alarm) device.
local index = ('7') -- The setting that you want to change
local clock = os.clock
function sleep(n) -- seconds
local t0 = clock()
while clock() - t0 <= n do
if (devicechanged[VirtualDevice] == 'On') then
local indexvalue = ('2') -- The value you want to set for the setting
os.execute ("curl 'http://localhost:8080/ozwcp/valuepost.html' --data '" .. nodeID .. "-CONFIGURATION-config-byte-1-" .. index .. "=" .. indexvalue .. "'&")
print("Change " .. AlarmDevice .. " parameter: " .. index .. " to " .. indexvalue)
commandArray[AlarmDevice]='On'
if (devicechanged[VirtualDevice] == 'Off') then
commandArray[AlarmDevice]='Off'
sleep(1)
local indexvalue = ('3') -- The value you want to set for the setting
-- How to:
local t0 = clock()
sleep(1)
The Lua works, except for the important part: changing the parameter of the sound type. Changing indexvalue has no effect.
I have changed index from 7 to 37, because this is stated as the sound parameter in the hardware section of the sirene
result of 192.168.0.107:8080/json.htm?type=openzwavenodes&idx=6 in my laptop browser addressline:
"status" : "ERR"
local index = ('37') -- The setting that you want to change
"status" : "ERR"
