Countdown
Robban
Countdown
Post by Robban »
I am about to make an alarm system with domoticz and RpI and now i wonder
how do i make a countdown from 30 sek in blocky or Lua?
like..
if front door=open then start countdown
BakSeeDaa
Re: Countdown
Post by BakSeeDaa »
You can create a virtual switch device then set an Off delay of the desired time. After you turn it on it will turn itself off after it's reached the time for it's off delay. You can then trigger on the virtual device change.
rgroothuis
Re: Countdown
Post by rgroothuis »
You can check the "last modified status", this has a date/time in it. Compare the date/time against the current date/time and you know the time difference. Do this in a time based Lua script.
pluggin
Re: Countdown
Post by pluggin »
Robban wrote:Hi
like..
I do what you need with SET/AFTER
The rule do this:
If door or windows = open then wait 15 sec and turn on the Siren (This give me time to deactive the alarm)
If Siren = on then turn ON living room light for 5 minutes / turn it OFF SIREN after 5 minutes
Razberry + 4 Eversrping HSM02 + 2 Aeotec Multi-Sensor + 1 Aeotec Micro Dimmer + 4 Aeotec Micro Smart Energy Switch, 2nd + 1 Remotec ZXT-120 + 1 Aeotec Smart Energy Monitor + 1 Everspring SE812 indoor Siren + 2 fibaro motion sensor + Aeotec water sensor
Robban
Re: Countdown
Post by Robban »
ok, think i getting the hang of it,
however,
is it possible to make:
if door =open then countdown
if countdown>0 and <30 and pushbutton=on then stop countdown and deactivate alarm
