dtgbot - Domoticz TeleGram BOT
- jvdz
- Domoticz version: 4.107
Re: dtgbot - Domoticz TeleGram BOT
There clearly is an issue with the index of the room it is trying to retrieve the devices for. The idx field should be a number in stead of a name.
Could you post (or PM) the result of the json : http://192.168.1.XXX:8080/json.htm?type ... &used=true
Is "Planta Baja" a name of a room?
Jos
Jos
- Domoticz version: 4.9700
Hi!jvdz wrote:There clearly is an issue with the index of the room it is trying to retrieve the devices for. The idx field should be a number in stead of a name.
Jos
Thank you jvdz! PM send.
"Planta Baja" is a floor name not a room. It means low level in spanish.
I'm really very grateful jvdz.
Editing...
After jvdz help i got a new error in the dtb.log....
- Spoiler: show
Solved
Guys it may sound obvious, but do not use spaces in domoticz objects names.
Thnx to jvdz for the help. You are Jedi Master
Greetings from spain.
- Domoticz version: latest
Hi I just don't have any luck getting dtgbot stating. I dont use any password on Domoticz.
This is the error I am getting:
Here is the details from Domoticz:
/usr/bin/lua5.2: /home/pi/dtgbot//dtg_domoticz.lua:125: attempt to get length of global 'result' (a nil value)
stack traceback:
/home/pi/dtgbot//dtg_domoticz.lua:125: in function 'device_list_names_idxs'
/home/pi/dtgbot/dtgbot.lua:174: in function 'dtgbot_initialise'
/home/pi/dtgbot/dtgbot.lua:229: in main chunk
[C]: in ?
result: [
LastUpdate: "2015-11-16 16:33:29",
Type: "0",
Value: "1",
idx: "1"
LastUpdate: "2015-11-16 16:33:58",
Type: "2",
Value: "Off",
idx: "2"
LastUpdate: "2015-11-16 16:34:34",
Type: "2",
Value: "xxxxxxx",
idx: "3"
status: "OK",
title: "GetUserVariables"
result: [
Devices: 16,
Order: "1",
idx: "2"
Devices: 4,
Order: "3",
idx: "3"
status: "OK",
title: "Plans"
- jvdz
You probably do not have any Scenes defined yet in Domoticz and the Function is "complaining" about that.
Please edit your dtg_domoticz.lua and update the below function with this version which should skip in case no Scenes are available:
Jos
-- returns a list of Domoticz items based on type i.e. devices or scenes
function device_list_names_idxs(DeviceType)
--returns a devcie idx based on its name
local idx, k, record, decoded_response
decoded_response = device_list(DeviceType)
result = decoded_response['result']
devices = {}
devicesproperties = {}
if result ~= nil then
for i = 1, #result do
record = result[i]
if type(record) == "table" then
if DeviceType == "plans" then
devices[record['Name']] = record['idx']
devices[string.lower(record['Name'])] = record['idx']
devices[record['idx']] = record['Name']
if DeviceType == 'scenes' then
devicesproperties[record['idx']] = {Type=record['Type'], SwitchType = record['Type']}
return devices, devicesproperties
Jos
Thanks jvdz once I create my scenes dtgbot started.
I now have the bot up and running. When I type a command like "help" in from the telegram I don't get a response back from the bot. Why will that be?
6 - Starting Telegram api Bot message handler
2015-11-17 17:47:46 - -----------------------------------------
2015-11-17 17:47:47 - Domoticz returned getuservariables after 2 attempts
2015-11-17 17:47:47 - dtgbotLogLevel set to: 0
2015-11-17 17:47:47 - Loading command modules...
2015-11-17 17:47:47 - Loading module <utility>
2015-11-17 17:47:48 - found command <refresh>
2015-11-17 17:47:48 - Loading module <dtgmenu>
2015-11-17 17:47:48 - define LastCommand
2015-11-17 17:47:48 - found command <dtgmenu>
2015-11-17 17:47:48 - Loading module <list>
2015-11-17 17:47:48 - found command <list>
2015-11-17 17:47:48 - found command <dump>
2015-11-17 17:47:48 - Loading module <devices>
2015-11-17 17:47:48 - found command <devices>
2015-11-17 17:47:48 - found command <scenes>
2015-11-17 17:47:48 - Loading module <flick>
2015-11-17 17:47:48 - found command <flick>
2015-11-17 17:47:48 - Loading module <nflick>
2015-11-17 17:47:48 - found command <nflick>
2015-11-17 17:47:48 - Loading module <on>
2015-11-17 17:47:48 - found command <off>
2015-11-17 17:47:48 - found command <on>
2015-11-17 17:47:48 - Loading module <battery>
2015-11-17 17:47:48 - found command <batteries>
2015-11-17 17:47:48 - found command <battery>
2015-11-17 17:47:48 - Loading module <help>
2015-11-17 17:47:48 - found command <start>
2015-11-17 17:47:48 - found command <help>
2015-11-17 17:47:48 - Loading module <temperature>
2015-11-17 17:47:48 - found command <temperatures>
2015-11-17 17:47:48 - found command <tempall>
2015-11-17 17:47:48 - found command <temperature>
2015-11-17 17:47:48 - Decoded Off
2015-11-17 17:47:48 - TelegramBotWhiteListedIDs user variable does not exist in Domoticz
2015-11-17 17:47:48 - So will allow any id to use the bot
2015-11-17 17:47:48 - dtgbotLogLevel set to: 0
2015-11-17 17:47:48 - Getting TelegramBotOffset the previous Telegram bot message offset from Domo ticz
2015-11-17 17:47:48 - Decoded 1
- Domoticz version: 3.8807
Try a slash infront of help - /help - should then get a response.fhwessels wrote:I now have the bot up and running. When I type a command like "help" in from the telegram I don't get a response back from the bot. Why will that be?
Check out the Telegram generic pages, they document things like this behaviour.
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
hi I did try the /help as well and still don't get the response. Here is the info from the getUpdate log
update_id: 121932669,
message: {
message_id: 201,
first_name: "Francois",
last_name: "Wessels",
username: "fwessels"
chat: {
username: "fwessels",
type: "private"
date: 1447786998,
text: "/help"
- jvdz
Can you show me the dtb.log with the details about processing this message?
Jos
Jos
hi here is my dtb.log. where will I get the process message?
2015-11-18 15:17:09 - DomoticzIP: 127.0.0.1
2015-11-18 15:17:09 - DomoticzPort: 8080
2015-11-18 15:17:09 - BotHomePath: /home/pi/dtgbot/
2015-11-18 15:17:09 - BotLuaScriptPath: /home/pi/dtgbot/lua/
2015-11-18 15:17:09 - BotBashScriptPath: /home/pi/dtgbot/bash/
2015-11-18 15:17:09 - TelegramBotToken: xxxxxxxxxxxxxxxxxxxI
2015-11-18 15:17:09 - TelegramBotOffset: TelegramBotOffset
2015-11-18 15:17:09 - -----------------------------------------
2015-11-18 15:17:09 - Starting Telegram api Bot message handler
2015-11-18 15:17:10 - Domoticz returned getuservariables after 2 attempts
2015-11-18 15:17:11 - dtgbotLogLevel set to: 0
2015-11-18 15:17:11 - Loading command modules...
2015-11-18 15:17:11 - Loading module <utility>
2015-11-18 15:17:11 - found command <refresh>
2015-11-18 15:17:11 - Loading module <dtgmenu>
2015-11-18 15:17:11 - define LastCommand
2015-11-18 15:17:11 - found command <dtgmenu>
2015-11-18 15:17:11 - Loading module <list>
2015-11-18 15:17:11 - found command <dump>
2015-11-18 15:17:11 - found command <list>
2015-11-18 15:17:11 - Loading module <devices>
2015-11-18 15:17:11 - found command <devices>
2015-11-18 15:17:11 - found command <scenes>
2015-11-18 15:17:11 - Loading module <flick>
2015-11-18 15:17:11 - found command <flick>
2015-11-18 15:17:11 - Loading module <nflick>
2015-11-18 15:17:11 - found command <nflick>
2015-11-18 15:17:11 - Loading module <on>
2015-11-18 15:17:11 - found command <off>
2015-11-18 15:17:11 - found command <on>
2015-11-18 15:17:11 - Loading module <battery>
2015-11-18 15:17:11 - found command <batteries>
2015-11-18 15:17:11 - found command <battery>
2015-11-18 15:17:11 - Loading module <help>
2015-11-18 15:17:11 - found command <help>
2015-11-18 15:17:11 - found command <start>
2015-11-18 15:17:11 - Loading module <temperature>
2015-11-18 15:17:11 - found command <tempall>
2015-11-18 15:17:11 - found command <temperature>
2015-11-18 15:17:11 - found command <temperatures>
2015-11-18 15:17:11 - Decoded Off
2015-11-18 15:17:11 - TelegramBotWhiteListedIDs user variable does not exist in Domoticz
2015-11-18 15:17:11 - So will allow any id to use the bot
2015-11-18 15:17:11 - Getting TelegramBotOffset the previous Telegram bot message offset from Domoticz
2015-11-18 15:17:11 - Decoded 1
- jvdz
When sending a text message to the BOT you defined, the dtgbot should start processing it and it will show up in the log.
I believe that the new BOTs are by default in private mode, which means only commands prefixed with a slash "/" will be send to the BOT.
https://core.telegram.org/bots look for /setprivacy
Have you followed the https://www.domoticz.com/wiki/Telegram_ ... ur_chat_id section in the WiKi?
Does that work?
Are there any errors listed in: dtb.log.errors?
You also haven't set the TelegramBotWhiteListedIDs yet, which you might want to do to ensure nobody else can send commands to your Domoticz setup.
Jos
Does that work?
Jos
I done all of this in the wiki here is my info from the chat ID. I can also send message with curl command to the bod and that is working. There is no error dtb.log.error
update_id: 121932675,
message: {
message_id: 215,
chat: {
type: "private"
date: 1447856628,
text: "/help"
update_id: 121932676,
message: {
message_id: 216,
chat: {
type: "private"
date: 1447856670,
text: "/list"
update_id: 121932677,
message: {
message_id: 217,
chat: {
type: "private"
date: 1447856732,
text: "/dump"
- jvdz
DTGBOT.lua should be doing the same as what you have done manually.
Can you set the Domoticz uservariable TelegramBotLoglevel to 2, restart DTGBOT, send a command to the bot and show or send me the log (after removing any private info) ?
It should contain a lot more information about what it is doing exactly at startup.
Jos
Jos
here is my log.
2015-11-18 18:33:03 - -----------------------------------------
2015-11-18 18:33:03 - Starting Telegram api Bot message handler
2015-11-18 18:33:03 - Domoticz returned getuservariables after 1 attempts
2015-11-18 18:33:03 - Decoded 2
2015-11-18 18:33:03 - dtgbotLogLevel set to: 2
2015-11-18 18:33:03 - Loading command modules...
2015-11-18 18:33:03 - Loading module <utility>
2015-11-18 18:33:03 - found command <refresh>
2015-11-18 18:33:03 - function: 0x1f07d60
2015-11-18 18:33:03 - Loading module <dtgmenu>
2015-11-18 18:33:03 - define LastCommand
2015-11-18 18:33:03 - found command <dtgmenu>
2015-11-18 18:33:03 - function: 0x1ef0718
2015-11-18 18:33:03 - Loading module <list>
2015-11-18 18:33:03 - found command <list>
2015-11-18 18:33:03 - function: 0x1f4fe88
2015-11-18 18:33:03 - found command <dump>
2015-11-18 18:33:03 - Loading module <devices>
2015-11-18 18:33:03 - found command <devices>
2015-11-18 18:33:03 - function: 0x1f34ae8
2015-11-18 18:33:03 - found command <scenes>
2015-11-18 18:33:03 - Loading module <flick>
2015-11-18 18:33:03 - found command <flick>
2015-11-18 18:33:03 - function: 0x1f4f650
2015-11-18 18:33:03 - Loading module <nflick>
2015-11-18 18:33:03 - found command <nflick>
2015-11-18 18:33:03 - function: 0x1f50990
2015-11-18 18:33:03 - Loading module <on>
2015-11-18 18:33:03 - found command <on>
2015-11-18 18:33:03 - function: 0x1f345b8
2015-11-18 18:33:03 - found command <off>
2015-11-18 18:33:03 - Loading module <battery>
2015-11-18 18:33:03 - found command <battery>
2015-11-18 18:33:03 - function: 0x1ef2018
2015-11-18 18:33:03 - found command <batteries>
2015-11-18 18:33:03 - Loading module <help>
2015-11-18 18:33:03 - found command <help>
2015-11-18 18:33:03 - function: 0x1f46b68
2015-11-18 18:33:03 - found command <start>
2015-11-18 18:33:03 - Loading module <temperature>
2015-11-18 18:33:03 - found command <tempall>
2015-11-18 18:33:03 - function: 0x1f48960
2015-11-18 18:33:03 - found command <temperature>
2015-11-18 18:33:03 - found command <temperatures>
2015-11-18 18:33:03 - JSON request <http://127.0.0.1:8080/json.htm?type=command¶m=getuservariable &idx=2>
2015-11-18 18:33:03 - Decoded Off
2015-11-18 18:33:03 - WLidx 3
2015-11-18 18:33:03 - JSON request <http://127.0.0.1:8080/json.htm?type=command¶m=getuservariable &idx=3>
2015-11-18 18:33:03 - Decoded 54005199
2015-11-18 18:33:03 - WLString: 54005199
2015-11-18 18:33:03 - Name :54005199
2015-11-18 18:33:03 - JSON request <http://127.0.0.1:8080/json.htm?type=command¶m=getuservariable &idx=4>
2015-11-18 18:33:03 - Decoded XXXXXX
2015-11-18 18:33:03 - WLString: XXXXXX
2015-11-18 18:33:03 - Name : XXXXXX
2015-11-18 18:33:03 - Getting TelegramBotOffset the previous Telegram bot message offset from Domotic z
2015-11-18 18:33:03 - TBOidx 1
2015-11-18 18:33:03 - JSON request <http://127.0.0.1:8080/json.htm?type=command¶m=getuservariable &idx=1>
2015-11-18 18:33:03 - Decoded 1
2015-11-18 18:33:03 - TBO 1
2015-11-18 18:33:03 - https://api.telegram.org/botbotXXXXXXXXX/ WHY is there 2 botbot here is it right?
pi@raspberrypi ~ $
- jvdz
Did you add the bot prefix in this line in /etc/profile.d/DomoticzData.sh?WHY is there 2 botbot here is it right?
export TelegramBotToken="000000000:keykeykeykeykeykeykeykey"
yes it did when I copy it. I removed it and now it is woking. Thanks for you help
- jvdz
Great to hear.
Don't forget to change the debuglevel back to 0 or else the logfile will grow pretty fast.
Enjoy
Jos
Enjoy
Jos
Hello
I wonder if with Telegram Remote Control is posible to get the status of devices. I just get a list of devices and I can on/off them, but I dont know if they are on or off!!!.
I mean with Remote Control, no with the new "bots system".
The info about bots I've found is not clear, and it looks like the remote control is easier for me.
- Target OS: OS X
I've made a Dokerfile to easily build and run Telegram BOT on my Raspberry.
To build and run it
1 -Install docker
Depend of your Linux ARM distribution. For example, with Raspbian Jessie, you can fin a '.deb' file here, with last versions of docker : http://blog.hypriot.com/downloads/
2 - Build the container image
3 - Run the container with your Telegram parameters :
4 - Verify the logs to see if everything is OK
Please tell me if you like it!
To build and run it
1 -Install docker
docker build -t telegrambot git://github.com/macjl/dtgbot-docker
docker run -dt --restart=always --name telegrambot --env DomoticzIP=192.168.0.30 --env DomoticzPort=8080 --env TelegramBotToken="123456:ABCDEFG" --env TelegramChatId="987654321" telegrambot
docker logs telegrambot
