Yes, that too! Although I have some trouble figuring out the best way to implement it. Might have to do several notifications centers.Kroontje wrote:Good news, thanks! Do you have also a notification center widget on your roadmap?
OK I understand! Since you're on the phone, you have no DATA coverage, so your phone can't send the signal to your Domoticz server.rgroothuis wrote:patoo77 wrote:rgroothuis wrote:No that is not exactly what I mean. When I'm having a phone call and I leave home, Pilot detects that I'm leaving home and tries to update Domoticz. As I'm on a phone call there is no data connection, in other words Pilot cannot set the Phone@Home status in Domoticz. This is a pity as I'm having some scripts running to disable lights etc when I'm leaving home (while making a phone call), these lights are now on for longer then necessary.
It would be grate if Pilot tries it a couple of times (configurable) to update the status in Domiticz after it failed to update. This will make the user scenarios more robust.
Secondly it would be great if a certain intervals (configurable) Pilot checks if the status according to Pilot is the same as in Domoticz. I assume that Pilot checks the location regularly to verify if it is already within the at home range. When the check is done it would be good to verify if that location status is also set (the same) in Domoticz.
Both items are closely linked to each other and maybe can be the same solution/implementation. My view would be that this would make the total system more robust and my lights would not stay on the for the rest of the day until I'm at home again.
Thanks.
Might be able to implement some sort of "retry" when the sending fails. Good idea
Will try to get it done for 1.5 release
