Danfoss LC-13
HansHofman
Danfoss LC-13
Post by HansHofman »
Is it possible to implement this option for the Danfoss LC-13
COMMAND_CLASS_PROTECTION
Set or get living connect® local protection mode.Possible local protection values are: 0 = no protection 2 = fully locked (tamperproof)
I want to lock the Danfoss so people cannot change settings.
Hans Hofman
marczu83
Re: Danfoss LC-13
Post by marczu83 »
+1 :)
Wysłane z mojego SM-G925F przy użyciu Tapatalka
gizmocuz
Re: Danfoss LC-13
Post by gizmocuz »
in domoticz i think you can 'protect' this when editing the device,and check the protect checkbox ?
marczu83
Re: Danfoss LC-13
Post by marczu83 »
that's right but device is protected only from changes via website interface,
not from changes from device.
It would be nice to have such option :)
regards!
Egregius
Domoticz version: v2024.7
Re: Danfoss LC-13
Post by Egregius »
There should be a child lock on them, but I can't find how to activate it.
For me it doesn't mather. You may set whatever you want on the valve, my script will overwrite it within 10 seconds ;)
stlaha2007
Re: Danfoss LC-13
Post by stlaha2007 »
Seen some manuals, very short, on these Danfoss devices. Noticed the Childlock mentioned also.
Perhaps thats where the requested function comes in? Tried to find some info in Z-wave specs however didn't find it.
@egregius: nice your script rewrites the value. Its also temper prove then :D
Sent from my D6503 using Tapatalk
gizmocuz
Re: Danfoss LC-13
Post by gizmocuz »
Okey, i see what you mean, and it means i have to add the protection class to the configuration options.
I tagged this message, and is on my todo list
for now, you can go to the hardware setup of openzwave, from the node dropdown, select 'control panel',
select the node, at the bottom select information, and you can set the protection options
HansHofman
Re: Danfoss LC-13
Thnx.
Any idea when will this be implemented ?
Hans Hofman
gizmocuz
Re: Danfoss LC-13
Post by gizmocuz »
Don't forget, this is an open source project, made by people in their spare time
Probably tomorrow, but i can not prommise, the work around is good enough for now
gizmocuz
Re: Danfoss LC-13
Post by gizmocuz »
Not tested (my powernode does seem to ignore the protection settings, or maybe it is for manual operation only)
Beta #3626 now has the protection class in the settings of the node
HansHofman
Re: Danfoss LC-13
Works perfect on the Danfoss !!
Thnx
Would it be possible to set a maximum/minimum temp so users can change this to the max/min level.
I know its not an option of the Danfoss but it the Domoticz couls control the temp and set it back to the max/min level if exceeded.
Abbadon
Re: Danfoss LC-13
Post by Abbadon »
I cant test that becauses 'events' are not working for me. Try to make event:
if value of thermostat is higher than (for example) 26
then set value to 26
and the same solution for lower temp
Egregius
Re: Danfoss LC-13
Post by Egregius »
Mine is controlled by PHP:
<?php
$Set = setradiator($TLiving, $RLiving);
if($RLivingZZ!=$Set) {Udevice($RILivingZZ, 0, $Set);}
if($RLivingZE!=$Set) {Udevice($RILivingZE, 0, $Set);}
if($RLivingZB!=$Set) {Udevice($RILivingZB, 0, $Set);}
First the desired setpoint for the valves is calculated based on the current room temperature and the dummy room setpoint.
Then whenever the valve has a different value than that it's updated.
HansHofman
Re: Danfoss LC-13
I set the protection level to no operation possible.
The Danfoss Thermostat is locked.
Next day the settings are not saved in the database the 900 is see screenshot.
The Danfoss Thermostat is not locked.
Version: 2.3678
Build Hash: 2351e80
Compile Date: 2015-11-23 09:14:59
Abbadon
Re: Danfoss LC-13
Post by Abbadon »
same for me, even when i change it on ozw config page still is unprotected
