[MyDomoAtHome] Bêta version in nodeJS Topic is solved
epierre
Post by epierre »
DEBIAN PACKAGE:
an betaversion as a debian package on Raspbian (no automatic startup yet), works well on debian.
http://www.e-nef.com/domoticz/mdah/node ... latest.deb
==>> SEE HERE FOR INSTALLATION: https://github.com/empierre/MyDomoAtHome/tree/nodejs
on Raspbian, please install first to have a stable nodeJS :
http://www.e-nef.com/domoticz/mdah/npm_2.14.7_armhf.deb
http://www.e-nef.com/domoticz/mdah/node ... _armhf.deb
on all other, version 4 is required (testing/unstable are fine):
curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
sudo apt-get install -y nodejs
you need to edit /etc/mydomoathome/config.json containing(change your ip !):
  "app_name": "MyDomoAtHome",
  "domo_path": "http://192.168.0.28:8080",
  "port": "3002"
it runs on port 3002 and App name is "MyDomoAtHome Dev", so you can run legacy and beta at the same time.
FYI new install is in /usr/share/mydomoathome/
TESTING/SUPPORT:
preffered method: https://mydomoathome.slack.com/messages ... s-testing/
==> Please mail me on [email protected] with your email to get an invite
SYNOLOGY PACKAGE:
a very alpha alpha version as a debian package (NOT TESTED):
https://github.com/empierre/MyDomoAtHom ... noarch.spk
UPDATES:
- faster than the legacy perl dancer on a pi B
- sorted out the armv6 nodejs situation (raspbian is compiled for armv6 and works for armv7 too (not the opposite)), specific packages needed available here: http://www.e-nef.com/domoticz/mdah/
- all is there except graphes
CURRENT ISSUES:
- debian package: auto startup ok
- Docker to be tested
- graphs not yet implemented
- synology package: first untested version for all arch
- synology: define where to place configuration file
- have the package hosted on raspian archive
Last edited by epierre on Wednesday 02 March 2016 23:27, edited 11 times in total.
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
epierre
Re: [MyDomoAtHome] Bêta tests
Post by epierre »
current issues:
- dependencies not installed
- run on startup ?
epierre
Post by epierre »
updates:
- sorted out the armv6 nodejs situation (raspbian is compiled for armv6 and works for armv7 too (not the opposite)), specific packages needed available here: https://github.com/empierre/MyDomoAtHom ... ejs/binary
current issues:
- debian package: auto startup not possible as is on wheezy class raspbian
- actions/graphs not yet implemented
- synology package: first untested version for armada375
kinghuzi
Post by kinghuzi »
Hi.. can you add x86 support for syno spk
epierre
Post by epierre »
kinghuzi wrote:Hi.. can you add x86 support for syno spk
I will, but since I do it manually I add the architecture manually... what is you so I make it ?
jumbotroll
Post by jumbotroll »
You can use:
arch="noarch"
and it's arch independent
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
epierre
Post by epierre »
jumbotroll wrote: You can use:
arch="noarch"
Thanks Jumbotroll, it is done !
epierre
Post by epierre »
@kinghuzi @jumbotroll have you tested it yet ?
raym
Re: [MyDomoAtHome] Bêta version in nodeJS
Post by raym »
Hi epierre, will this nodejs version eventually replace the existing mdah version? If so, am I able to test on Ubuntu?
epierre
Post by epierre »
raym wrote:Hi epierre, will this nodejs version eventually replace the existing mdah version? If so, am I able to test on Ubuntu?
yes it will, I've not yet finished, others things went in the middle... too much time one one thing and many solicitations and in the end priority management :D
you can test it, it covers all information but does not yet manages actions (no switches, no graphs...). I still have not tested whether it works fine on raspbian (non systemd), but on ubuntu it is fine !
deennoo
Post by deennoo »
Thx for this, which nodejs did you use ?
What about homebridge from sdcard img who need node 0.12.1?.
As it tooks me 3 mounth to make it finally works, i dont want to break it by updating MDAH.
http://domo-attitude.fr
epierre
Post by epierre »
if you have nodejs 0.10 nothing to change, only raspbian is on.0.6 and is thus broken for everything...
raym
Post by raym »
Thanks for your reply. It sounds exciting and I look forward to testing soon.
Where can I find the install procedure for Ubuntu and similar?
Thanks again.
epierre
Post by epierre »
Hi All,
I've restarted yesterday, .deb not updated, but on/off is tested working.
epierre
Post by epierre »
version 0.0.13 is open for testing, no graphes though...
modify the config file as fitted, report bugs to github, and discussion here !
epierre
Post by epierre »
version 0.0.14 is open for testing, no graphes yes.
Debian package available.
epierre
Post by epierre »
0.0.15 tested working on debian with systemd
deennoo
Post by deennoo »
Have you try it on a regular Synologie ? Dunning DMS 5
epierre
Post by epierre »
@deenoo it will, it was too high a target to start, so I prefer to make it more MVP and then extend si ut will be tested first before expending.
also syno has more needs, you don't mess with its filesystem... so specific strategy for it to be done
deennoo
Post by deennoo »
OK !
Just start an xpenology before purchase a real syno, i saw that be can made a debian chroot part. Homebridge can be set and running on it, so i was hoping doing the same for MDAH.
