How to download data
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Hi All,
I would like to downlaod data from my energyconsumption to an excel sheet.
Is there a how to available?
Or could somebody tell me how to do this?
thnx for your help
Egregius
Domoticz version: v2024.7
Re: How to download data
Post by Egregius »
You could use a tool like Adminer and export the desired table as CSV.
Or, the graphs have an option to save as CSV.
JuanUil
Post by JuanUil »
Thnx for your reply
but where can I find the table on my raspberry PI?
Egregius
Post by Egregius »
You have to install Adminer or another SQLite tool and open the domoticz.db database.
Isn't the export of the graph enough?
gizmocuz
Post by gizmocuz »
'SQLite expert personal' on windows is a great program
JuanUil
Post by JuanUil »
Thnx guys
found it and downloaded it.
rjobaan
Domoticz version: 2022.1
Post by rjobaan »
Is it not possible to save it in domotticz it self. I see the option csv but that is not showing everything?
Where can I find domotics.db?
Egregius
Post by Egregius »
In your domoticz installation folder.
On a Pi by default in /home/pi/domoticz
rjobaan
Post by rjobaan »
Does anybody has the datamodel and explanation of the columns in domoticz.db?
JuanUil
Post by JuanUil »
so a small howto:
in Domoticz go to settings tab backup/restore
- backup your dbase
- open it in sqlite
- open the older dbase also in sqlite
- export the desired table of the latest dbase to csv
- copy the new data from the older database
- paste them in the csv
- save it
- delete the table in the latest dbase
- import the csv file in the latest dbase
- restore the newest dbase in domoticz
Maybe a point of attention:
Don't delete the header data
Sometimes the csv file has a format for the date as 03-02-2020
Most time the dateformat in the dbase is as 2020-03-02
So change the format in the csv accordanly to the format in your database.
finished! :D
succes!!
Jan
polomora
Domoticz version: 2023.1
Post by polomora »
Hello All,
I just found this thread while searching for the same: how to export the DB data to CSV/Excel.
Regarding the previous replies above in this thread:
Regarding the in-graph export of the DB data reply. The CSV export of the graph relates to the timeframe of the graph. Thus on the daily chart, the export is done using 5-minute data, but only the data for the latest 24-hours is exported. For other timeframes, the export is done using daily data. The export the entire DB with a resolution of 5-minutes is impossible.
Regarding the "small howto" reply. I think this is a copy/paste from another post. What do these steps mean?
Domoticz version: 2025.1
You are digging up a really old topic.
Better read this if you want to export data for reporting to Excel: https://www.domoticz.com/forum/viewtopic.php?t=30725
The amount of days data of the daily graph is depending of your log settings in menu setup settings.
