gizmocuz wrote:Could you post your sketch ?
I've used Your
very source code example above and the "incoming" routine is never ever called. So, no function.
Meanwhile I've had great problems connecting my sensors on the lower floors to my controller. I've tried a lot,
like reflashing the controller (wasn't sure it had the latest version of mySensors running). Wouldn't work.
So I had a look at some of the EEPROMS of my Arduinos, especially the first part where the Node ID and the
Parent ID was stored. As I wrote I have the controller and one repeater on 1st floor, the energy meter on
ground level and the water meter and another repeater in the cellar. In the EEPROMs I found stuff like
the meter on ground level connecting to the repeater in the cellar which in turn connects to the repeater in the
roof and then the controller. The connection resulting took ages (if it worked at all) and was at best sporadic.
So I reprogrammed the EEPROM of my meter manually, setting it to the appropriate route and this has been working
for the past two hours.
Concerning my original problem I have made up a work-around by writing the values into the Arduino's EEPROM in
case of a power failure and retrieve values afterwards when rebooting. SInce that works for me I'll leave it at that
for now. But since the problem of retrieving values from the controller will definitely come up again I'd like to
look into that further. I suggest to write some minimal code example, try that and using something like the nrf-sniffer
log the resulting traffic. Maybe someone can make something of it. I didn't understand this, really.
My Gateway is on the first floor, the water meter in the cellar, no repeater, as the gateway is almost on top of it
Lucky You
I never tried to build a repeater... i could try this, but i dont think it changes anything, it should just pass all messages through
Maybe You
should try this. Eventually You might come up with a solution. Who else would?
Make sure you are on the latest domoticz version
Always, Gizmocuz. Always
Thanks,
Christoph
