I keep getting confused with my power reports, they are showing fex 81.769.
Is there a reason for there being three digits behind the dot?
Does someone need that level of info, or can it be hidden somewhere in the reports?
Numbers after decimals in power meter
stlaha2007
- Target OS: -
Re: Numbers after decimals in power meter
Hi Alfredo,
I see you have not got a reply yet.
Just reading my electricitymeter for a few days. Therefor missing specific details. Anyway the following is what i have seen here.
My Electricitymeter only displays kWh. Seems that, according to your example, you are getting Watt or Wh into Domoticz.
Mine records the total Watts per hour. And hence seen 3000 and 12000 etc on the day graph. And 3 kWh in the reports
Grtz
Stephan
Sent from my D6503 using Tapatalk
Grtz
Stephan
Forgot to make a reply here myself, I'm currently seeing the following values:
12304.561 kWh, Today: 10.233 kWh
Why is there three decimals? Is so much level of detail really necessary? Easier for the eyes with fewer numbers...
