Add cam on V2.3537 not working?
pluggin
Post by pluggin »
I'm adding a IP cam inside "Add new camera" option and when use TEST CONNECTION all works fine I can see cam streaming.
But when try to see streaming clicking the cam icon a new windows open but nothing happend.
Any clues?
Kind regards.
Razberry + 4 Eversrping HSM02 + 2 Aeotec Multi-Sensor + 1 Aeotec Micro Dimmer + 4 Aeotec Micro Smart Energy Switch, 2nd + 1 Remotec ZXT-120 + 1 Aeotec Smart Energy Monitor + 1 Everspring SE812 indoor Siren + 2 fibaro motion sensor + Aeotec water sensor
gizmocuz
Re: Add cam on V2.3537 not working?
Post by gizmocuz »
Dont think this has to do with the build number of domoticz
what is your snapshot url ? (that should be the url that grabs an image from the cam)
pluggin
Post by pluggin »
gizmocuz wrote:Dont think this has to do with the build number of domoticz
Thanks for your reply...
Domoticz version V2.3530
I define the cam with the following values:
Enabled: YES
IP Address: 192.x.x.x.
Port: 80
Username: admin
Password: ••••••
ImageURL: videostream.cgi?user=admin&pwd=XXXXX
Make Test Connection and can see the cam image wih no problems.
Then assing the CAM to a previous sensor and when click the CAM icon beside the sensor a new frame appear but no image in it.
So why is functon inside the "Edit Camera" and not clicking the sensor icon?
I dont have this issue with previous version.
gizmocuz
Post by gizmocuz »
What type of hardware is your camera ?
pluggin
Post by pluggin »
gizmocuz wrote:What type of hardware is your camera ?
Its a WiFi IP CAM Polaroid. Let me know if you need more info. I dont have the manual, sorry.
regards
