Domoticz uptime on the dashboard. Topic is solved
It would be nice to have a Domoticz "uptime" on the dashboard.
If there is a problem with Domoticz I use monit to restart Domoticz.
By the "uptime" I could figure out if that happened recently and have to investigate why the restart took place.
SweetPants
Re: Domoticz uptime on the dashboard.
Uptime will only show you how long ago domoticz was restarted for the last time. What if this happend more times?
You can get more information from the monit log file /var/log/monit.log
I use the HTML interface daily and Domoticz is running fine for days or even weeks.
I would like to see on the interface if there was a restart.
If I see a recent restart then I could investigate monit.log and others for the reason of the restart.
Now I have to check monit.log every once in a while (or daily) and find out there there where a lot of restarts 5 days ago.
safi78
- Domoticz version: LastBeta
Or have monit send you a message with Pushover? There's a very easy script for that (just google monit and pushover).
Works like a charm for me
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
jackslayter
- Domoticz version: stable
hi, add a new text dummy and this script
and chmod +x uptime.sh
#!/bin/sh
#uptime.sh
pid=`ps -ef |grep 'domoticz -daemon' |grep -v grep |awk '{print $2}'`
updz=`ps -p $pid -o %t | tail -1 | sed -e 's/^[ \t]*//;s/[ \t]*$//' | awk 'sub( "...$", "" )'`
itime=`uptime | awk '{print $1}' | awk 'sub( "...$", "" )'`
min=$(uptime | grep -ci min)
day=$(uptime | grep -ci day)
if [ $min -eq 1 ] ; then
uptime=`uptime | awk '{print $3}'`
uptime2=`uptime | awk '{print $4}'`
elif [ $day -eq 1 ] ; then
uptime3=`uptime | awk '{print $5}'`
fi
curl "http://IPADRESS:PORT/json.htm?type=command¶m=udevice&idx=TEXTIDX&nvalue=0&svalue="$itime"%2c%20up%20"$uptime"%20"$uptime2"-"$uptime3"%20Dz%20"$updz""RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
I use telegram, and thats works perfectly. I know.
BUT. recently Domoticz was restarted frequently so I got a lot of alerts.
So thats why I suggest an "uptime" on the dashbord.
In my opinion it does not hurt anybody to add such a feature.
EDIT:
The above script is a good solution too (thanks), but takes up the place of a button on the dashboard.
EDIT:
pluggin
this is my script for uptime
#!/bin/bash
pid=`ps -ef |grep "domoticz -daemon -www"|grep -v grep |awk '{print $2}'`
updz=`ps -p $pid -o %t | tail -1 | sed -e 's/^[ \t]*//;s/[ \t]*$//'`
val=$(echo ${updz/-/day(s)%20})
curl -s "http://IP:PORT/json.htm?type=command¶m=udevice&idx=100&nvalue=3&svalue=$val" > /dev/null
I use a TEXT sensor for display the value
#!/bin/bash
Razberry + 4 Eversrping HSM02 + 2 Aeotec Multi-Sensor + 1 Aeotec Micro Dimmer + 4 Aeotec Micro Smart Energy Switch, 2nd + 1 Remotec ZXT-120 + 1 Aeotec Smart Energy Monitor + 1 Everspring SE812 indoor Siren + 2 fibaro motion sensor + Aeotec water sensor
Tnx, for the sensor script.
Found it in Setup -> About.
Thats good for me too.
Was it always there?
- gizmocuz
No, it was added a few days ago (did not know about this thread... so it was a coincidence
stlaha2007
- Target OS: -
The Setup/About is strange.
Running domotics for more dan 16000 days.. Started begin of July
Guess it reads a wrong value...
The script of Pluggin seems correctly reading current pid and runtime of it. As Domoticz will change pid when a restart accurred.
Sent from my D6503 using Tapatalk
stlaha2007
- Target OS: -
Found it and checked it... However this is what About says:gizmocuz wrote:No, it was added a few days ago (did not know about this thread... so it was a coincidence
About Domoticz
Version: 2.3530
Build Hash: 9eef872
Compile Date: 2015-11-01 11:41:18
Uptime: 16755 Dagen, 19 Uren, 39 Minuten, 55 Seconden
Seems that the format isn't correct or using some other timecode/timesource.
According to uptime:
Time 20:48:40 up 9 days 7:29, 3 users...
9 days 7 hours 29 minutes comes close to restart around 14.00h.
- proohu01
Is there a way to use this uptime value into a LUA script variable?
I have a couple of switches that send me a picture using Telegram. I alway get a lot of messages when the system is rebooted or when I update (restart) Domoticz. I would like to be able to change my LUA scripts so it doesn't do anything if the uptime is less than a minute.
Pi 2 B | Pi Camera | PiFace 2 | RFXtrx433E (KaKu + Oregon Scientific) | Plugwise (9 Circles) | Aeon Z-Wave stick (Fibaro - dimmers, sockets, RGB, screens/blinds) | RFXMeter (Kwh/water/gaz) | WOL | Onkyo Receiver | RTC | Hikvision | Netatmo | Satel Integra
Kjakan
- Domoticz version: 2024.2
I want to know about this to.
UptimeInMinutes or similar would be a nice feature.
- proohu01
A standard method would be a very nice addition indeed? Any chance of getting this into Domoticz as a feature? UptimeInMinutes sound good to me.
In the meantime, I cooked up some lua code that works for me now...
n = os.tmpname ()
os.execute ("var=$(ps -eo pid,args |grep 'domoticz -daemon' | grep -v grep |awk '{print $1}') && echo $(($(cut -d '.' -f1 /proc/uptime) - $(($(cut -d ' ' -f22 /proc/$var/stat)/100)))) > " .. n)
for line in io.lines (n) do
UptimeInSeconds = line
os.remove (n)
UptimeInSeconds = tonumber(UptimeInSeconds);
-- print('Domoticz has been running for '.. UptimeInSeconds .. ' seconds')
if UptimeInSeconds < 90 then
print('Domoticz uptime is less than 90 seconds')
commandArray['SendNotification']='Domoticz uptime is less than 90 seconds'
return commandArrayPi 2 B | Pi Camera | PiFace 2 | RFXtrx433E (KaKu + Oregon Scientific) | Plugwise (9 Circles) | Aeon Z-Wave stick (Fibaro - dimmers, sockets, RGB, screens/blinds) | RFXMeter (Kwh/water/gaz) | WOL | Onkyo Receiver | RTC | Hikvision | Netatmo | Satel Integra
MacJL
- Target OS: OS X
Why not adding a counter device for uptime in motherboard sensors?
It would be quite simple, can be used with blocky/scripts, and would have an history
