I hope anyone can help me. I’m trying to integrate my Bticino domotic environment with OpenWebNet with DomoticZ app. I’ve achieved to control on/off lights and raise/lower the blind to the end, but I can’t guess how to control light intensity on a dimmer or raise/lower blind up to a certain percentage. The app seems to support this features, but I haven’t found where to configure them.
Now I’m creating a Dummy Hardware, where I configure a script with the required commands to on/off a light or raise/low a blind, but I can’t guess how to configure light intensity or blind percentage.
Can anybody help me??
light intensity on DomoticZ
Re: light intensity on DomoticZ
Did you manage to make some progress with OpenWebNet? If so, can you share your code here please, I'm interested
Another possible solution is to ask the folks on My Open Community to ask for dimming lights:
http://www.myopen-legrandgroup.com/comm ... fault.aspx
I'm trying to integrate my Bticino domotic environment with domoticz (OpenWebNet) but without success.
You could explain to me how can you add lighting and blinds?
This is what I get in the log, and the devices do not work:
2016-03-29 16:24:16.655 COpenWebNet : connected to: 192.168.0.98:20000
2016-03-29 16:24:16.658 COpenWebNet : received=*#253287476## : PASSWORD FRAME
2016-03-29 16:27:28.263 User: Admin initiated a switch command
2016-03-29 16:27:28.268 COpenWebNet : sent=*99*0## received=*#*1##
2016-03-29 16:27:28.270 COpenWebNet : sent=*2*1*92## received=*#625643304##
2016-03-29 16:27:43.085 User: Admin initiated a switch command
2016-03-29 16:27:43.090 COpenWebNet : sent=*99*0## received=*#*1##
2016-03-29 16:27:43.092 COpenWebNet : sent=*2*2*92## received=*#744407162##
Can you help me?
Thanks.
Can you help me?
Thanks.
- emme
- Domoticz version: latest
that kind of reply from the WebNet server means that you need authentication before proceeding.
To avoid this you have in put the domoticz IP Address in the whitelist of your OpenWebNet server
Once done you will be able to issue commands and operate blinds...
but I cannot operate lights
"We always done this way"
