Domoticz log and failed attempt (to use fail2ban)
manuloup
Post by manuloup »
Currently, when someone tries to connect and fails, here is what we get in the logfile :
2015-10-30 17:32:16.616  Error: Failed login attempt for 'toto' !
Would that be possible to add the IP for this kind of failed attempt, so that we can create a rule for domoticz with Fail2Ban and trap the IP in the domoticz logfile ?
Manu
Rapberry PI B+ (RaspBian), RFXtrx433E USB 433.92MHz Transceiver, AEON LABS Controler Z-Wave, Aeon Labs Z-Stick S2, Everspring ST814 Temperature Sensor, Everspring SF812 Smoke Detector, 2x Fibaro Wallplug, Aeon Zwave Miniremote , Xbee Teleinfo USB
gizmocuz
Re: Domoticz log and failed attempt
Post by gizmocuz »
Added in beta #3507
manuloup
Post by manuloup »
Thanks a lot ! I will create the rule for fail2ban and will make a tutorial here.
manuloup
Post by manuloup »
Here we go :
1 - edit the file jail.conf in /etc/fail2ban/ and add the following section :
 [domoticz]
enabled  = true
port     = 8080
filter   = domoticz
logpath  = /var/log/domoticz.log
maxretry = 3
findtime = 3600
Modify the port and logpath according to your settings.
2 - add the domoticz.conf filter in /etc/fail2ban/filter.d
vi /etc/fail2ban/filter.d/domoticz.conf
 # Fail2Ban configuration file for domoticz
# Author: Emmanuel Chanteloup
# $Revision$
[Definition]
# Option:  failregex
# Notes.:  regex to match the password failures messages in the logfile. The
#          host must be matched by a group named "host". The tag "<HOST>" can
#          be used for standard IP/hostname matching and is only an alias for
#          (?:::f{4,6}:)?(?P<host>[\w\-.^_]+)
# Values:  TEXT
failregex = .* Error: Failed login attempt from <HOST> for user '.*' !
# Option:  ignoreregex
# Notes.:  regex to ignore. If this regex matches, the line is ignored.
# Values:  TEXT
ignoreregex =
3 - restart fail2ban
 sudo /etc/init.d/fail2ban restart
All done !
To do a quick test :
 vi toto.txt :
 2015-11-03 18:35:51.908  Error: Failed login attempt from 37.130.158.115 for user 'toto' !
then run the following command :
fail2ban-regex  toto.txt /etc/fail2ban/filter.d/domoticz.conf
you should see :
Success, the total number of match is 1
I also did a try from my cellphone. After 3 unsuccessful attemps, my ip is banned :
 root@raspberrypi:/etc/fail2ban# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
fail2ban-domoticz  tcp  --  anywhere             anywhere             multiport dports 8080
fail2ban-ssh  tcp  --  anywhere             anywhere             multiport dports ssh
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain fail2ban-domoticz (1 references)
DROP       all  --  37.140.158.148       anywhere
RETURN     all  --  anywhere             anywhere
- to remove the ip :
 root@raspberrypi:/etc/fail2ban/filter.d# iptables -D fail2ban-domoticz -s YOUR_IP_HERE(37.140.158.148 for me) -j DROP
I am not banned anymore :
Chain fail2ban-ssh (1 references)
I hope it is clear for you now and that I helped you a bit. Do not hesitate to tell if I forgot something.
Cheers :)
ThinkPad
Post by ThinkPad »
manuloup wrote:Here we go :
Thank you very much, was looking for this, to configure on my Ubuntu VM running Domoticz. Will try it soon!
To make more people benefit from it, i have also created a wiki page for it: http://domoticz.com/wiki/Automated_bann ... iple_times
But what i don't understand, at the step 'Testing the new setup' you do vi toto.txt. But what is this 'toto.txt' file and why is it named like that?
Is a .txt file created for every username that tries to login or so :?:
And which file do you mean by the 'jail' file? Here: https://www.upcloud.com/support/install ... ntu-14-04/ they mention NOT to use jail.conf, but instead create a jail.local file and using that. Any advice about that?
By the way, is the regex still correct? The login attempts seem to be logged in a different way in my case (v2.3542):
domoticz@domoticz-vm:/etc/fail2ban/filter.d$ cat /var/log/domoticz.log | grep 'Failed'
2015-11-10 18:35:08.105  Error: Webserver: Failed authentication attempt, ignoring client request (remote addresses: 188.xxx.64.xxx)
2015-11-10 18:35:51.651  Error: Webserver: Failed authentication attempt, ignoring client request (remote addresses: 188.xxx.64.xxx)
2015-11-10 18:35:51.811  Error: Webserver: Failed authentication attempt, ignoring client request (remote addresses: 188.xxx.64.xxx)
2015-11-10 18:36:00.245  Error: Webserver: Failed authentication attempt, ignoring client request (remote addresses: 188.xxx.64.xxx)
2015-11-10 18:36:00.365  Error: Webserver: Failed authentication attempt, ignoring client request (remote addresses: 188.xxx.64.xxx)
(i put the 'xxx'in myself)
Your failregex seems to search for
, so it is a totally different message. Also the username isn't mentioned anymore, only the IP.
I think it should be more like this:
failregex = Error: Webserver: Failed authentication attempt, ignoring client request (remote addresses: <HOST>)
I'm not sure if round brackets need escaping, if true then this would be better:
failregex = Error: Webserver: Failed authentication attempt, ignoring client request \(remote addresses: <HOST>\)
I will try later, with 'fail2ban-regex' you can test the regex to see if it matches.
Egregius
Domoticz version: v2024.7
Re: Domoticz log and failed attempt (to use fail2ban)
Post by Egregius »
I have this in jail.conf:
[DEFAULT]
ignoreip = 127.0.0.1/8 192.168.0.1/24
bantime  = 3600
maxretry = 1
backend = auto
banaction = iptables-allports
mta = sendmail
protocol = all
port	= all
chain = INPUT
action = route
[domoticz]
enabled  = true
filter   = domoticz
and in filter.d/domoticz.conf:
# Fail2Ban configuration file FOR Domoticz Failed login
# Author: Egregius
[Definition]
failregex = Error: Failed login attempt from <HOST>
ignoreregex =
And in action.d/route.conf:
[Definition]
actionban   = ip route add <blocktype> <ip>
actionunban = ip route del <blocktype> <ip>
[Init]
blocktype = blackhole
The advantage of 'ip route add blackhole' over the standard fail2ban action is that the packets are dropped at first level where they arrive, they don't even get to the firewall anymore.
From then on, your ip just doesn't exists anymore :twisted:
Tested and confirmed by typing wrong user/pass on mobile connection (easiest to get new ip).
Or set bantime to a short time for test and watch the fail2ban log.
ThinkPad
Post by ThinkPad »
Thanks for sharing!
But why is my error message/regex different than yours, and from 'manuloup' :? I'm running v2.3542 (i thought, not sure).
Egregius
Post by Egregius »
I'm on Rpi v2.3558...
Last edited by Egregius on Wednesday 11 November 2015 13:21, edited 1 time in total.
ThinkPad
Post by ThinkPad »
I will update tonight and see if the error message changes...
Egregius
Post by Egregius »
Just updated to latest beta v2.3570
2015-11-11 13:37:18.117  Error: Failed login attempt from 178.145.160.129 for user 'test' !
fail2ban with above filter:
2015-11-11 13:37:20,439 fail2ban.actions: WARNING [domoticz] Ban 178.145.160.129
ThinkPad
Post by ThinkPad »
Thanks, makes it clear i just need to update :)
What about the 'user' part? The tutorial from manuloup does something with the username shown in the Domoticz error message, but you don't seem to do anything with that in your regex.
Banning on IP is fine by me, i don't understand why the username needs to be logged, do you?
Egregius
Post by Egregius »
In the logfile you could see of you're victim of dictionary attack. User root, admin, administrator, etc. But that doesn't bother me, I block them instantly after one failed attempt.
After unban and second try within 2 weeks they're blocked for a year.
ThinkPad
Post by ThinkPad »
That's not needed for me either, just ban the @*#($@*(#$ :twisted:
I just updated to v2.3573 (i suddenly remembered i can also SSH with my phone to the VM over VPN and call my update script) but the message is still the same?
It still shows:
Error: Webserver: Failed authentication attempt, ignoring client request (remote addresses: xxx.xx.xx.xx)
I tested by trying to login with admin/admin about 3-4 times, untill the Domoticz page displayed "Domoticz offline".
I don't understand why i get a different message. I run on a different platform (Ubuntu virtual machine x86, you on a Raspberry), but that shouln't matter i guess?
Egregius
Post by Egregius »
3-4 times means you'll have maxretry set at 3.
Don't know about the message. Maybe Ubuntu/Rpi difference?
Doesn't mather much, just difficulter for the wiki.
Trying to have fail2ban sent telegram now :roll:
ThinkPad
Post by ThinkPad »
It seems my message is old, the webserver code contains the message in the way you see it. Look at: https://github.com/domoticz/domoticz/bl ... r.cpp#L837
What i thought of, maybe it has something to do with the login method. You can change that in the Domoticz settings, under 'Website Protection'.
I use Basic-Auth. Don't remember exactly why, i thought it had something to do with stability of the Android app.
Maybe with the 'Login Page' method (which is the default if i remember correctly) it will display the message in the way you see it (IP + user).
I will try switching to 'Login Page' methode and login with wrong credentials a few times.
Edit: Yup, that was the cause for a different message to be displayed. When i switched to 'Login Page', i saw a message like you posted.
Good to know, so we can put both regex'es in the fail2ban config in the wiki, so it applies for everyone' situation (if you use default login method or Basic-Auth). Luckily fail2ban supports multiple regex'es to search for :D
I think the final regex should look like this:
I will try tonight with both authentication methods that Domoticz offers, and see if i can get fail2ban to trigger in both situations, with the above failregex. I will edit the wiki when i get it working :)
ThinkPad
Post by ThinkPad »
I got it working :) The round brackets needed escaping btw (putting a backward slash in front of them, see the wiki for final regex).
However, i got some questions:
Under: http://domoticz.com/wiki/Automated_bann ... live_setup the original tutorial mentions an IP. In my case (testing over 3G), a hostname is added to the firewall blocklist.... (static.kpn.net). This is something that is problematic for unbanning, because for the unbanning command it needs an IP.
Some parameter that i haven't configured correctly?
For now i just used sudo iptables --flush fail2ban-domoticz, but that flushes the whole fail2ban-domoticz part of iptables i guess...
djoeney
Post by djoeney »
This is a really nice security enhancement!
At the moment i'm using nginx as a reverse proxy for the use of SSL certificates. I want to implement fail2ban only I'm having some issues if i would use the domoticz log i always see "Login successful from 127.0.0.1 for user '######"'
Will try to find out if the source IP could be given from nginx to domoticz.
Compute RPi 2 : Domoticz latest beta, Synology : Domoticz tested beta on failover system.
Peripherals RFXCOM - RFXtrx433, Z-Wave.Me ZME_UZB1 USB Stick,P1 cable on smartmeter, Logitech Harmony Hub, 3 IP camera's
ThinkPad
Post by ThinkPad »
ThinkPad wrote:I got it working :) The round brackets needed escaping btw (putting a backward slash in front of them, see the wiki for final regex).
I'm still having problems with this. When i try to lock myself, the hostname is still being added. I also tried it on a Ziggo business internet connection, the hostname (same as i see on http://ipinfo.io) is added to iptables. I just want the IP-address to be added, instead of the hostname. When i try to unban the hostname, it says it hasn't found anything. When i run the unban command with the IP-address, it works....!?
tlpeter
Post by tlpeter »
I followed the wiki but fail2ban does not want to start.
This is the error when i do sudo fail2ban-client start
WARNING 'findtime' not defined in 'ssh'. Using default value
WARNING 'findtime' not defined in 'dropbear'. Using default value
WARNING 'findtime' not defined in 'pam-generic'. Using default value
WARNING 'findtime' not defined in 'xinetd-fail'. Using default value
WARNING 'findtime' not defined in 'ssh-ddos'. Using default value
WARNING 'findtime' not defined in 'apache'. Using default value
WARNING 'findtime' not defined in 'apache-multiport'. Using default value
WARNING 'findtime' not defined in 'apache-noscript'. Using default value
WARNING 'findtime' not defined in 'apache-overflows'. Using default value
WARNING 'findtime' not defined in 'vsftpd'. Using default value
WARNING 'findtime' not defined in 'proftpd'. Using default value
WARNING 'findtime' not defined in 'pure-ftpd'. Using default value
WARNING 'findtime' not defined in 'wuftpd'. Using default value
WARNING 'findtime' not defined in 'postfix'. Using default value
WARNING 'findtime' not defined in 'couriersmtp'. Using default value
WARNING 'findtime' not defined in 'courierauth'. Using default value
WARNING 'findtime' not defined in 'sasl'. Using default value
WARNING 'findtime' not defined in 'dovecot'. Using default value
WARNING 'findtime' not defined in 'named-refused-tcp'. Using default value
WARNING 'filter' not defined in 'domoticz'. Using default value
ERROR  /etc/fail2ban/filter.d/.conf and /etc/fail2ban/filter.d/.local do not exist
ERROR  Unable to read the filter
ERROR  Errors in jail 'domoticz'. Skipping...
ThinkPad
Post by ThinkPad »
Did you Google that error already: https://www.google.nl/search?q=WARNING+ ... ot+defined ?
Seems quite easy to fix.
