Events Sleep/Wait command
SilasAT
Post by SilasAT »
Hello, we want to control a heater with the help of eventes (Blockly) but we are missing a Sleep/Wait command were we can define how many ms or seconds we want to wait before proceding to the next block. All help would be appreciated.
Silas :D
tozzke
Domoticz version: Stable
Re: Events Sleep/Wait command
Post by tozzke »
you could create an extra dummy switch with a switch off delay and use that in the next 'else if'-block
Egregius
Domoticz version: v2024.7
Post by Egregius »
Or you use php for scripting. Usleep and sleep are standard functions for microseconds or seconds wait time.
SilasAT
Post by SilasAT »
Can you explain how these methods works?
Egregius
Post by Egregius »
You mean in PHP? Simple, just add sleep(5) where you want the script to sleep 5 seconds. Or usleep(500000) for half a second.
But that requires that your whole script is in PHP offcourse.
SilasAT
Post by SilasAT »
But we are creating it in the GUI :-) So can we make a combination of php and GUI?
raym
Post by raym »
Hi, I've been trying to understand this myself lately. I realise putting delays in LUA scripts is not recommended but is it OK to put delays in a php or bash script (for example)? This won't block DZ from processing other requests will it?
What's the recommended approach for putting delays between device calls?
Thanks.
grelle
Post by grelle »
I have a similar problem and maybe we can get an answer that suits us both...
My 1-wire counter seemes to post the same thing twice with in milliseconds. This makes my LUA script trigger twice and destroy my actual watt calculation. Gaaaah, why is 1-wire posting twice and why can't I use the sleep function I have tried in my LUA script ?
2015-11-11 19:31:09.043 (1-Wire) RFXMeter (Total Energi)
2015-11-11 19:31:09.271 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_counter_vp.lua
2015-11-11 19:31:09.138 (1-Wire) RFXMeter (VP Energi)
2015-11-11 19:31:09.332 (1-Wire) RFXMeter (Total Energi)
2015-11-11 19:31:09.610 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_counter_vp.lua
2015-11-11 19:31:09.502 (1-Wire) RFXMeter (VP Energi)
--Domoticz Script to get medium actual energy between energy counter readings and puts it on a dummy device
--First create a dummy energy meter and two user variables as numbers.
--Then enter the details below
--Name of the real energy counter
energyCounter = 'VP Energi'
newValue = tonumber(otherdevices_svalues[energyCounter]) * 10
--ID of the created dummy energy meter with the new actual value
dummyEnergyMeterid = 65
hour = 3600
--The names of two user variables to keep track of previous value due to wrong values from dummy in otherdevices_lastupdate and other$
userVariableTimestamp = 'LastEnergyTimestamp'
userVariableLastCount = 'LastEnergyCount'
if devicechanged[energyCounter] then
        --calculate new actual value
        actual = ((newValue) - tonumber(uservariables[userVariableLastCount])) * hour / ((os.time()-uservariables[userVariableTimesta$
        --update dummy energy meter
        commandArray[1] = {['UpdateDevice'] = dummyEnergyMeterid .. "|0|" .. actual .. ";" .. newValue}
        --update user variables
        commandArray[2] = {['Variable:'..userVariableTimestamp] = tostring(os.time())}
        commandArray[3] = {['Variable:'..userVariableLastCount] = tostring(newValue)}
        -- print("DummyEnergy: " .. actual .. " W, " .. newValue .. " kWh")
function sleep(n)
        n = 1
        os.execute("sleep " .. tonumber(n))
Sweden / Östersund
tlpeter
Post by tlpeter »
Never mind, didn't work well
