Everspring SE812-1 Domoticz
movi28
Post by movi28 »
Hello everybody,
I can't configure my Siren Everspring SE812 to my Domoticz on a raspberry PI with domoticz.
I see them on my controller but the config info don't come to my domoticz.
Any idea ?
regards,
Vince
movi28
Re: Everspring SE812-1 Domoticz
Post by movi28 »
Any Idea ?
olivier93
Post by olivier93 »
I have exactly the same issue. I see them on my controller but the config info don't come to my domoticz and i see se812.xml file under config. Please do you resolve your problem?
Futhermore i can't see any device in tab device attach to my siren. i think it's because he don't find config file?
I join a screenshot to explain my problem.
Thanks a lot
Capture d’écran 2015-10-25 à 12.11.05.png (207.24 KiB) Viewed 1821 times
Derik
Post by Derik »
push the button many time..
So he wakeup...
olivier93
Post by olivier93 »
I push the button several time on the siren but unfortunetly the configuration on domoticz doesn't display. Have you this problem too?
Thanks a lot
Kind Regards
mamouth
Post by mamouth »
Hi!
I've got a similar trouble.
After a couple of hours, the little green check mark at the end of the line becomes a red exclamation point.
Then, i can not send any command anymore to the siren.
When I reboot the siren (removing the batteries), i can see it healthy again in domoticz... but only for a while :-(
An idea ?
Thanks a lot.
Kind Regards.
mamouth
