Qubino thermostat ZMNHIA2 compatibility
Thibthib02
Is this QUBINO module supported by Domoticz?? If not, how to create it??
Thank you for your support.
Thibthib02
Re: Qubino thermostat ZMNHIA2 compatibility
Nobody to help me?
xDespujols
Hello
I use this module in Domoticz.
I create a xml file to use it.
For use it, i can set domoticz update version to "beta".
I have a problem with setpoint fonction. It seems that are not operational.
How can publish my xml file in domoticz source ?
Xavier
Xavier
Robert
Hi xavier.
Did you make some progress by using the qubino thermostat module zmnhai2? Module is reconized but i have no clue how it should work. Set point seems not to work . ( latest stable version 22563) I can read the temp.
I have the thermostat 'set point' and thermostat ' Mode ' (auto)
By the tab 'temperature ' I receive the temperature'
Kind regards
Robert
Kind regards
Robert
juankar
- Domoticz version: 4.
Hello
Will anybody answer anything about compatibility of Qubino ZMNHIA2 with Domoticz?
juankar
Nobody use this device?
meslow
Have some problems with Qubino on/off thermostat ZMNHIA2 too.
I can't use SET_POINT.
Event if the temperature reatch the SET Point value more Hysteresis, the ZMNHIA2 stay ON
- bbqkees
- Domoticz version: 4.1x
Are you seeing the setpoint as a device in Domoticz?
- bbqkees
While i was working on another Z-Waveconfig file, I also compared the thermostat manual with the OpenZWave config file and the config file is incomplete and full of errors.
F.i. parameters 11, 12, 60, 61 are missing. Might be more problems in this file.
Association part is also completely wrong.
And some default values and min/max are also wrong.
So best thing to do first is to edit this config file so that it reflects the manual perfectly.
And then replace the config file as mentioned in the OpenZWave instructions etc.
(And remove/reinclude the node)
You cannot expect this device to function properly if the config is erroneous.
meslow
I just finished updating ZMNHAI2 config file with all parameters.
Just need to try it later today, i'll give some news right after.(Hope it work's
File available here : ZMNHIA2.xml (Replace the original one for testing purpose)
Thank's bbqkees for pointing potencials problems
meslow
Updating config didn't solve the problem .
Envoyé de mon 6045Y en utilisant Tapatalk
- bbqkees
You also need to remove some cache files.
But as soon as the config is correct and it is still not working you at least removed one potential cause by yourself.
meslow
After various try the problem remain the same.
Changing the value doesn't the device configuration.
Changing the value doesn't even generate any log. Any other change does.
Hope somone finally figure out
waveguerilla
Hi, same problem for me with same device.
fabreg
Hi, same problem for me with same device, again ...
i try with your xml ... but no result ...
- bbqkees
Maybe you can ask Qubino directly.
dawsmac
Has there been any progress on this device, I have installed and config the set-point but noticed that the control to switch on the device come under the Utility (Auto / Off ) and no option for a normal switching command ? Probe is pulsing in with Temp. Maybe I have missed something
Cheers
Rich
Cheers
Rich
- StephaneG
I suggest a cause and a fix for your problem there:
viewtopic.php?f=31&t=7956#p71252
Regards,
Stéphane
Regards,
Stéphane
