Logitech Media Server
cyberclwn
Domoticz version: 2024.4
Re: Logitech Media Server
Post by cyberclwn »
Eduard wrote:
cyberclwn wrote:btw, it is on purpose the status of the device changes from "Aan" (On) to "Audio" after a 20-30 seconds ?
It's because the plug-in uses an interval to 'pull' the status of the players. By default this interval is 30 seconds. You can change this in rhe hardware-srtting of the LMS.
Right, but i mean, why does it change to "Audio"? I know it is playing Audio, it can't play Video. So it's not adding much new :lol:
If i pause the player, it says "Paused", i can understand that. If i stop the player, it says "Stopped", so following that logic, why not make it say "Play" when it is playing ? :)
Or have it show play-mode. Like "Play (Random)" "Play (Repeat)"
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
qwerk
Post by qwerk »
please let me ask a stupid question,
i have added the media server in the hardware segment, it never shows any clients, I have severall.
the only differences, I use another port and I use a loginname and password ( added those in the remote address line)
please advice
Eduard
Post by Eduard »
qwerk wrote:please let me ask a stupid question,
please advice
What's in the logfile after you start the LMS-hardware?
qwerk
Post by qwerk »
please advice
2015-10-09 13:25:26.258 Logitech Media Server: Worker stopped...
2015-10-09 13:25:26.259 Logitech Media Server: Worker started...
cyberclwn
Post by cyberclwn »
please advice
Hey,
Just checking, but since you have setup security in the LMS, did you also setup blocking of ip-addresses ?
IN LMS you can setup that only certain ip-addresses can connect to it.
Eduard
Post by Eduard »
please advice
What results do you get with
curl 'http://<SERVER-IP>:<SERVER-PORT>/jsonrpc.js' --data-binary '{"id":1,"method":"slim.request","params":["",["serverstatus","0","999"]]}'
Eduard
Post by Eduard »
New test version available! (For testers who are able to compile from source)
(Will commit to next beta soon :D )
New:
* Add Blockly support (On/Off/Playing/Pause/Stopped) Both reading & setting are available
* Add Set events in LUA (On/Off/Play/Pause/Stop/Set Volume)
Example:
commandArray['SqueezeBox']='On'
commandArray['SqueezeBox']='Play'
commandArray['SqueezeBox']='Set Volume 30'
Changes:
* AUDIO state changed to PLAYING
Known issues:
* Switching on/off of player does not update device status immediately, but after the interval-timeout ;(. Worked before so trying to find the bugger...
Now working on:
* Known issue(s)
* Wiki ;)
How to update:
cd ~/dev-domoticz
git pull
make
For starters: search this thread how to start compiling from source.
Thanx for your testing & suggestions :D
Enjoy!!
qwerk
Post by qwerk »
What's in the logfile after you start the LMS-hardware?[/quote]
2015-10-09 13:25:26.259 Logitech Media Server: Worker started...[/quote]
[/quote]
{"id":1,"result":{"info total artists":17560,"other player count":0,"info total songs":94685,"player count":7,"version":"7.9.0","lastscan":"1444439228","info total genres":279,"sn player count":0,"players_loop":[{"power":"1","ip":"192.168.3.137:46219","seq_no":"8","displaytype":"none","model":"squeezeplay","name":"Badkamer","playerid":"00:8c:2b:36:e6:07","canpoweroff":1,"uuid":"94c2edb8f22cf0fe5b72029660f01ed6","isplayer":1,"connected":1},{"connected":1,"isplayer":1,"uuid":"e88f06399030c78fe4e468a70456e09f","canpoweroff":1,"playerid":"00:04:20:2b:80:72","name":"Box","displaytype":"none","model":"baby","seq_no":"23","ip":"192.168.3.113:42327","power":0},{"displaytype":"none","name":"Box UE","model":"baby","ip":"192.168.3.103:56695","power":"1","seq_no":"3","isplayer":1,"connected":1,"playerid":"00:04:20:2d:6c:5d","uuid":"8021027d69bc4570b22f556ead7d2ec9","canpoweroff":1},{"uuid":"580b335e71a87d9959a945e588ab4005","canpoweroff":1,"playerid":"00:04:20:22:16:1e","isplayer":1,"connected":1,"seq_no":"4","ip":"192.168.3.115:35244","power":"1","model":"fab4","displaytype":"none","name":"Wekker Aren"},{"uuid":"56b89b05a886988ef68c1831bce1dbc3","canpoweroff":1,"playerid":"00:04:20:23:97:2f","connected":1,"isplayer":1,"seq_no":"7","ip":"192.168.3.112:38785","power":0,"displaytype":"none","name":"Touch","model":"fab4"},{"canpoweroff":1,"uuid":"1bae90140478e238c88b3c08979ade91","playerid":"00:04:20:1a:e8:d1","isplayer":1,"connected":1,"seq_no":0,"power":"1","ip":"192.168.3.118:37971","name":"Controller 01","displaytype":"none","model":"controller"},{"connected":1,"isplayer":1,"playerid":"00:04:20:23:67:cb","canpoweroff":1,"uuid":"09946d09f90e6af9a6e74826c997c4a3","name":"reserve touch","displaytype":"none","model":"fab4","power":"1","ip":"192.168.2.69:55939","seq_no":"92"}],"info total albums":6412,"uuid":"c266c443-9783-4323-9b5c-09b9076a7f6b"},"params":["",["serverstatus","0","999"]],"method":"slim.request"}
this looks fine, I guess
can you tell something from this?
I addedd username and password of course
Eduard
Post by Eduard »
qwerk wrote: this looks fine, I guess
Model 'baby', 'fab4' and 'controller' are surely supported right now, so you should have at least 3 players added to you LMS hardware.
I will do some test with username & pwd to try to replicate your issue and report back to you.
cyberclwn
Post by cyberclwn »
Eduard wrote:New test version available! (For testers who are able to compile from source)
New:
Example:
Changes:
Known issues:
Enjoy!!
Looking good.
Showing "Playing" now indeed, i like :)
Will test the lua-scripts later on.
Thanks again !
cyberclwn
Post by cyberclwn »
Eduard wrote: * Add Set events in LUA (On/Off/Play/Pause/Stop/Set Volume)
Example:
Btw, what name is put there, i guess the name of the player ?
Eduard
Post by Eduard »
Example:
Or the device-name (if it is the same as the player-name)
Immo
Post by Immo »
Would it be possible to add support for Android squeezeplayer?
Eduard
Post by Eduard »
Immo wrote:Would it be possible to add support for Android squeezeplayer?
Sure!
What model(s) do you see with
Immo
Post by Immo »
I get the following response, it's android tablet in the bedroom to control domoticz, I figured it would also be fun to use it to stream audio to it :)
pi@domoticz ~ $ curl 'http://lms.here/jsonrpc.js' --data-binary '{"id":1,"method":"slim.request","params":["",["serverstatus","0","999"]]}'
{"params":["",["serverstatus","0","999"]],"method":"slim.request","id":1,"result":{"other player count":0,"info total albums":1052,"player count":1,"version":"7.9.0","players_loop":[{"seq_no":0,"playerid":"50:01:bb:32:a9:ab","displaytype":"none","connected":1,"ip":"192.168.1.121:49304","model":"squeezeplayer","name":"Bedroom Squeezeplayer","uuid":null,"isplayer":1,"canpoweroff":1,"isplaying":0,"power":"1"}],"uuid":"54cc6d45-3618-4102-a689-302279ee8a73","sn player count":0,"info total artists":4659,"info total songs":11823,"lastscan":"1444255359","info total genres":116}}
Cheers!
Eduard
Post by Eduard »
Immo wrote:{"params":["",["serverstatus","0","999"]],"method":"slim.request","id":1,"result":{"other player count":0,"info total albums":1052,"player count":1,"version":"7.9.0","players_loop":[{"seq_no":0,"playerid":"50:01:bb:32:a9:ab","displaytype":"none","connected":1,"ip":"192.168.1.121:49304","model":"squeezeplayer","name":"Bedroom Squeezeplayer","uuid":null,"isplayer":1,"canpoweroff":1,"isplaying":0,"power":"1"}],"uuid":"54cc6d45-3618-4102-a689-302279ee8a73","sn player count":0,"info total artists":4659,"info total songs":11823,"lastscan":"1444255359","info total genres":116}}
Will add it in next version
Immo
Post by Immo »
Great!
Thanks a lot, will report how it works.
Eduard
Post by Eduard »
(Will be available in next beta too :D )
New:
* Up-to-date with Domoticz/master-branche
* Enabled support for models 'squeezeplayer' & iOS App iPeng
* Added state 'Disconnected' when device (or App) is unavailable
Fixed:
* Switching on/off player didn't update device status immediately, but after the interval-timeout
Enjoy!!
jumbotroll
Post by jumbotroll »
New:
Fixed:
Enjoy!!
Synology packages Updated to domoticz V2.3338 ;)
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
pvm
Domoticz version: 4.10538
Post by pvm »
Eduard wrote:...
New:
Nice job, updated and integrated this into my home control
On/off detection works fine! Image
Eduard wrote: Changes:
* Add notifications to LMS players (on/off/play/pause/stop)
* Add LMS-player(s) as notifier (send notifications to your players display :D)
Should this be in the current beta? i do not see this in the notification settings
Users browsing this forum: palnic and 1 guest
